11-02-2014, 09:30 PM | #1107 |
Have you scheduled an appointment with them for them to take a look at the car, or arranged to ship the plate/adapter back to them for warranty inspection?
11-02-2014, 09:49 PM | #1108 | |
Drives: 2014 Scion FR-S|Whiteout
JR and I have shared a few texts today, but it's Sunday and can't expect Oscar Sr and Jr to respond...BUT I appreciate the fact Oscar Jr and you were there to reply immediately to my concerns. Your knowledge helped, but after all that work... it needs to go back for warranty work. I have called Jackson Racing. Let's be honest, it's Sunday and I know SEMA is present. However, I'm confident it will ALL work out
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
11-03-2014, 05:47 PM | #1109 |
Drives: WRB Limited BRZ
Alright so I already been through like 20 pages of this thread and I've read around but I can't really find an answer for this exactly scenario.
So I was planning on buying a supercharger (Vortech or Jackson) and I'm leaning more towards to Jackson mainly because it's cheaper on the website and it looks like it puts out more power but anyways. If I buy the Jackson Supercharger kit with the CARB tune, and then I do an entire exhaust system makeover. Basically just upgrading to a bigger exhaust system and getting a high flow cat. Basically a JDL EL Header with a high flow cat along with the front pipe/overpipe combo also with a high flow cat and probably looking into a 3" nameless catback. I've read around and people are saying you need a tune if you are doing headers and a front pipe etc. But do I really need a tune if I'm running the CARB tune from Jackson? From my understanding if I go with the CARB tune, and I do the exhaust "Makeover" wouldn't I just be helping the engine breathe A LOT better and allowing it to do its job a lot easier. So wouldn't there be no need for a tune, unless I wanna tune it for more power. (Fine tuned) |
11-03-2014, 05:55 PM | #1110 | |
11-04-2014, 04:56 AM | #1111 |
I had leaks at the plate with the Mocal Perrin unit. Had mine apart more times than I can count.
Perrin updated the spacer gasket on their kit, Also the mocal gasket on mine came out after removing and reinstalling several times and never sealed properly again. So 1. Replaced thermostatic plate with new gasket 2. Did not overtighten 27mm nut (no more than 35lbsft) 3. Replaced o ring on spacer 4. Tighten spacer/thermosstatic plate before installing lines. 5. Make sure lines are not pulling downward on plate, leave some slack up top if possible.
The Following 3 Users Say Thank You to Dezoris For This Useful Post: |
11-04-2014, 08:56 AM | #1112 | |
Thanks for this! I pretty much did everything you listed several times Saturday and Sunday. It was frustrating to say the least... I talked to Jackson Racing yesterday and set an appointment to visit the shop Monday. SEMA's all week so they won't have time until then. I've concluded the thermostatic plate seal is not properly sealing, similar to your previous situation. Based on what you said about the seal, I'm thinking it's not suppose to be lose and come out? The Jackson Racing plate seemed fine too, but hard to tell once oil fills up in the cup. I made sure there was any tension from the oil lines so they weren't pulling anything. Any chance you know where to get new seals or did they just replace the entire plate???
11-04-2014, 09:02 AM | #1113 | |
The Following User Says Thank You to Dezoris For This Useful Post: | *LongFella (11-04-2014) |
11-04-2014, 09:36 AM | #1114 | |
Thanks! I've got time with Jackson Racing and I'm hoping they can help out in all this... For now, I'm just monitoring oil temps and running with out the oil cooler mocal plate or extension plate. The oil cooler lines are covered and zip tied away from everything.
11-04-2014, 10:45 AM | #1115 | |
Just wipe after each drive.
11-04-2014, 10:52 AM | #1116 | |
Got it. Everything was thoroughly wiped down prior to sealing them, but I will definitely make sure it is all cleaned before re-installing. I'll be going to Jackson Racing Monday afternoon to have Sr and Jr take a look at everything. I'm hoping they just replace the mocal part and warranty it (if possible). Those o-rings shouldn't go bad in less then a 8 months...
11-05-2014, 12:07 AM | #1117 | |
86 Noob
Drives: Firestorm FR-S
I was hoping to buy the CARB kit so that the only things I had to swap for smog were the headers and MAYBE the op/fp but I could probably slide by with it on. Would you guys be able to tune a higher power tune along side the CARB tune so I could switch back and fourth?
The Following User Says Thank You to Noob4Life For This Useful Post: | CSG Mike (11-05-2014) |
11-05-2014, 02:37 AM | #1118 | |
Just a dude
Drives: Scion FR-S 2013
The Following User Says Thank You to OICU812 For This Useful Post: | CSG Mike (11-05-2014) |
11-05-2014, 02:55 AM | #1119 | |
If it's still not enough power for you, then put back the header and front pipe, and get a custom tune. At that point, you'll already have a complete Ecutek license, so you just need to pay for the tuning time. |
The Following User Says Thank You to CSG Mike For This Useful Post: | *LongFella (11-05-2014) |
11-05-2014, 03:35 AM | #1120 |
Thanks
I'm planning for next year track just did my last event for the year.
I think #1 on my list is an oil cooler. I don't know if I'll ever go FI but I want to plan around that. If I did go FI I'd probably go JR. How much is the thermostatic oil cooler by itself? Is this the oil cooler I should get or something else? Should I also install a catch can? Right now I'm running 5w30 Motul 300V oil. Can I still run this with the cooler or should I go back to 0w20?
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
