Software Tuning Discuss all software tuning topics. |
04-10-2020, 03:34 PM | #15 |
Drives: 2013 frs red
But the guy was just looking to compare 0-60 times
04-10-2020, 03:45 PM | #16 |
Drives: GT86 2013
I do care about 0-60 times. Please keep posting them, including list of mods!
It doesn't matter that "most dont't care about it", when some do. |
04-10-2020, 03:53 PM | #17 |
Under 6 seconds with e85 and ofh. Car seems to do better when you dust the tire through first gear. Not practical for normal driving of course
04-10-2020, 03:54 PM | #18 |
Drives: Crapcan
If he wants to compare data then he needs to provide comparable data. Otherwise it is useless info.
Model Year: Transmission: Tire: Mods: Launch Control Y/N, Setting: Timing Method:
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | 86TOYO2k17 (04-10-2020), Lantanafrs2 (04-10-2020) |
04-10-2020, 04:11 PM | #19 |
Drives: 2017 toyota 86
Which is generally either for the purpose of having a pissing contest, or to
Compare and validate the benefits of certain modifications. In either case you need a set standard in which to compare. I’d much rather compare acceleration numbers over dyno numbers assuming the proper criteria is met. Which most do not. |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | Lantanafrs2 (04-10-2020) |
04-10-2020, 04:27 PM | #20 |
Rust bucket enthusiast
I'm sure my best was around 6 seconds. You need to spin a bit to avoid the car bogging out and making sure that you spend the most time possible in the higher part of the powerband. When I was able to do a 0-60, I found that conventional launch control hurt my times. Letting the clutch out while the RPM were on the upswing (rather than bouncing in place) meant the inertia from the flywheel let the wheels spin and not bog because of how slow I was actually going. When I got grippy tires, I could not get a good 0-60 no matter what without risking a broken axle, so I stopped caring. When I went turbo, I couldn't use the first 2 gears anyway, so 0-60 was out of the question. 20 to 60 maybe would've been ok.
The Following User Says Thank You to DarkPira7e For This Useful Post: | nikitopo (04-10-2020) |
04-10-2020, 07:19 PM | #21 |
Drives: 2017 Toyota 86
For the ones who care...Should I post up my previous few runs before OTF tune running all stock ? I only save a few because, they were all about the same.
Now as the car sits.. 2017 86 A few TRD badges 5hp x 3 =15 extra hp lol. 6MT BFG G force comp A2s Muffler delete Gutted stock frontpipe K&N panel filter Takeda torque booster silicone air tube. Modified stock air box along with snorkel mod. Apexl n1 exv coilovers OTF Stg 1 with idle set at 860rpm and rev limit set to 7,950rpm Launch set at 2,860rpm |
04-10-2020, 07:39 PM | #22 |
So what was the time?
04-10-2020, 09:56 PM | #23 |
Drives: '15 BRZ RA
Personally, I like acceleration measurements as a complementary to dyno measurements. You can check below (video at 4:30) how some mature tuners are checking their mods. Don't like to start again a BRZ vs. Cayman comparison, but we can learn from the work of others .
However, it doesn't make much sense to measure times from lunch. You are adding many more parameters to have a meaningful comparison and besides you are hurting your clutch! Acceleration measurements from 2nd gear are usually better. |
The Following User Says Thank You to nikitopo For This Useful Post: | mrg666 (04-12-2020) |
04-11-2020, 10:33 AM | #24 |
Drives: Crapcan
6.5 from his first post.
I think MT or someone did 6.6 or 6.7 in a stock car. They did repeated runs so could have been warm tires and low fuel. I think the 2850 launch is way too low. I was launching mine at 3800-4k.
04-11-2020, 01:24 PM | #25 |
Yeah, I had to launch at 4k
04-11-2020, 07:18 PM | #26 |
I tried launching at 5,500, 4k, 3,860, 3k all too much wheel spin and hit redline to fast to react in time. 2,860 launch seemed to be my sweet spot.
04-11-2020, 08:35 PM | #27 | |
Drives: Crapcan
Lower your rev limit a bit. And let it hit a few times before taking second. Bet you get a quicker time
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Lantanafrs2 (04-11-2020) |
04-12-2020, 11:19 AM | #28 |
Ask yourself this is it the time that matters or the feel? I can drive in a twisty road and go maybe 45 mph tops but the feeling as the car goes through the turns is fun.
For straight line you need FI or v8 and lots of low/mid torque to have fun. Driven plenty of muscle cars and they are great until you hit that turn. For me the more I think about it, it’s the low weight of the BRZ that helps it shine. Driven many fast cars with gobs of power but the weight just makes them pigs in the turns. The BRZ is like a go-kart. |
Similar Threads | ||||
Post roll cage lap time differences | Walldodger | Tracking / Autocross / HPDE / Drifting | 7 | 05-25-2017 01:06 PM |
Long time lurker making his first post. | JNthe86 | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 02-05-2017 11:41 PM |
alright my tenth post so i can officaly post in the marketplace | destiny86 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 02-04-2016 12:49 PM |
Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install | The Sentinel | Engine, Exhaust, Transmission | 92 | 03-09-2015 05:20 PM |
post Your 1/4 mile time!!!!! | PrDarkKnight | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 06-01-2013 09:07 AM |
