Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
01-13-2016, 11:49 AM | #1 |
Drives: 2015 Series.Blue
Emergency dead car!
My car died I hooked it up to jumper cables nothing happened it's push start and when I hit the button absolutely nothing happens. Need help!! Should I go change the battery?? Reconnect the wires??
01-13-2016, 12:04 PM | #2 |
Drives: 2015 CWP BRZ Limited
Reconnect which wires?
The Following User Says Thank You to jawn For This Useful Post: | Tcoat (01-13-2016) |
01-13-2016, 12:04 PM | #3 |
Killed Scion
Drives: 2013 FR-S Whiteout
Did you try disconnecting and reconnecting the battery?
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
The Following User Says Thank You to MisterSheep For This Useful Post: | Tcoat (01-13-2016) |
01-13-2016, 12:17 PM | #4 |
Did you check the battery in the fob or at least try the backup method in the owner's manual? I believe you just touch the fob to the metal ring around the button but am not positive.
01-13-2016, 12:28 PM | #5 |
I did try to hold the key to the button nothing. Reconnect the battery connection wires. I did not try that yet
01-13-2016, 12:32 PM | #6 |
not a twin owner
Drives: 2016 Veloster Turbo DCT
Wait, did you disconnect your car's (supposedly dead) battery from the car? You should not do that.
01-13-2016, 12:45 PM | #8 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
LOL, what is going on..
Anyway, quick excerpt from the manual that might help: |
01-13-2016, 01:40 PM | #9 |
Drives: 2013 FR-S 10 series [755]
if I install my intake,do i need to do the step above?
01-13-2016, 01:48 PM | #10 |
Drives: 2014 FR-S
I don't know what's real anymore.
The Following 6 Users Say Thank You to kbye For This Useful Post: | 8R6 (01-13-2016), brandonblt2 (01-15-2016), El Guapo (01-13-2016), PandaSPUR (01-13-2016), tcroft91 (01-15-2016), wireman957 (01-14-2016) |
01-13-2016, 01:49 PM | #11 |
Drives: Full race 4cyl boxer
I just installed a new battery in my car last weekend. (BRZ pushbutton start)
I did not have to do anything at all special. It even remembered my radio presets and phonebook. Just be smart and do it quickly |
01-13-2016, 01:56 PM | #12 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Is your battery clean (the terminals)?
Have a voltage meter/battery tester tool? like this Did you re-tighten battery terminals? Try starting car with a different battery? Can you take battery to local autoshop/O'rilleys/NAPA etc for testing? Did you try reading the manual? Did you recently do any car mods? Are your fuses ok? Do you have a tool to check them? Do any of your electric dependent items work like ac input? Lights? Car beeps? I dont own a push start model (just not a big fan of all electric), but these are things I would check. Later on, id check starter, alternator, etc... Keep us posted!~ Yes, so ecu re-programs itself. Just unplug one cable while you work installing it. I know some people dont do this, they just plug and play.
The Following User Says Thank You to Packofcrows For This Useful Post: | Kkobe2 (01-13-2016) |
01-13-2016, 03:10 PM | #13 |
Drives: 10 Series #974 6m/t
If you are referring to removing the negative terminal to do the install then no you don't have to worry. I have removed the negative terminal many times and it's good to go once i put the negative terminal back on.
01-13-2016, 04:05 PM | #14 |
Thanks guys!
Similar Threads | ||||
Bad Emergency Jack? | JDMenrique | Issues | Warranty | Recalls / TSB | 35 | 11-27-2015 07:55 PM |
Emergency brake button?? | Borzy | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 10-13-2015 08:18 PM |
EMERGENCY I NEED HELP PLEASE | kiname | Southern California | 25 | 07-09-2014 11:41 PM |
ECUTEK ECU Emergency | gdrider77 | Software Tuning | 6 | 12-18-2013 02:28 PM |
Emergency help!! | Howardwei | Engine, Exhaust, Transmission | 3 | 08-16-2013 04:42 PM |
