Old 02-02-2018, 09:32 PM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Lightbulb Fuel Lines: OEM Hard lines into LS fuel rail
I was going to mimic what most have done and reuse the stock quick connect lines, into a Y and that into the LS fuel rail. The problem is I had to sell one of my stock quick disconnect fuel lines with the flex fuel kit (long story short, I had one of the very first FF kits before nice AN hard lines were a thing).
Anyone that has made something other than using the quick disconnect lines can share their ideas?
What is the size of the stock hard lines?
What is the size of the LS rail line?
What type of fitting should I use on the stock hard lines?
I picture in my mind using some type of line on the stock hard lines going into an AN6 female, this into a 6AN Y and form the Y, AN female into whatever the size of the LS fuel rail quick disconnect is....
Not going for the most expensive/ prettiest setup, but also going for something proven to work, not the cheapest either....
Old 02-03-2018, 08:09 PM   #2
Sportsguy83
Drives: Limited BRZ
No one?
Old 02-05-2018, 08:05 AM   #3
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
Rubber fuel injection hose from hard lines.
I used 5/16" hoses to -6AN and then into -6AN Y
5/16" to -6AN
https://www.summitracing.com/parts/sum-220769n
-6AN Y
https://www.summitracing.com/parts/sum-220107b
wutsaiu is offline   Reply With Quote
Old 02-05-2018, 08:55 AM   #4
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I used these on my old VW hardline to convert to AN. Never had an issue and it was like that for years. it bites hard into the hardline and sealed perfect, I took it apart when I parted the car out.
https://www.summitracing.com/parts/e...AaAlBIEALw_wcB
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Sportsguy83 (02-05-2018)
Old 02-05-2018, 08:10 PM   #5
Sportsguy83
Drives: Limited BRZ
Thank you!
Old 02-05-2018, 10:07 PM   #6
wrxdriver2002
Drives: 2015 Subaru BRZ
I used a combination of the fittings on this page:
http://vibrantperformance.com/catalo...1347_1429_1435
And these fittings, where I couldn’t use quick disconnects:
http://vibrantperformance.com/catalo...oducts_id=2736
I also repurposed the vent hard line for a return line and the other two hard lines as fuel feeds. From the dual Waldron 460’s in the radium hanger, it goes from 8an into two 6an via an aeromotive Y, Then each into hardline as a 6an. Each hardline feeds one fuel rail directly.
wrxdriver2002 is offline   Reply With Quote
The Following User Says Thank You to wrxdriver2002 For This Useful Post:
Sportsguy83 (02-06-2018)
Old 02-06-2018, 09:29 AM   #7
Sportsguy83
Drives: Limited BRZ
Thank you!
Old 07-21-2018, 07:41 PM   #8
Ashikabi
Ashikabi's Avatar
I was curious about this exact thing. You're saying you used the port injector hardline for one fuel rail and the direct inject hardline for the other rail correct?
Old 07-21-2018, 08:08 PM   #9
wrxdriver2002
Yes and I used the vent line for return
Out of the oem fuel pump hanger, they Go to a Y, so it was really easy to do this without hardly any modification.
Old 07-21-2018, 08:19 PM   #10
Ashikabi
Ashikabi's Avatar
I wasn't planning on using a return system so that won't be an issue for me. Did you just leave your evap canister open then?
Old 10-08-2018, 06:16 PM   #11
Sportsguy83
Drives: Limited BRZ
For the fuel hard lines I ended up using: Russell Push-On EFI Fittings 644123 (click image)
The Following User Says Thank You to Sportsguy83 For This Useful Post:
FRSToyota86 (01-31-2019)
Old 10-08-2018, 06:46 PM   #12
wooly35
Drives: 2014 Scion FR-S LS3
I did away with the hard lines and ran two stainless steel braided lines for the fuel and the return. I tried reusing the stock hard lines and ended up having leaks.
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
The Following User Says Thank You to wooly35 For This Useful Post:
Sportsguy83 (10-08-2018)
Old 03-15-2019, 01:27 AM   #13
Merc
Drives: Subaru brz 2013 LS1 swap
Little off subject but I've got my fuel lines y'd into one and fuel pump controller bypassed. Tried draining the old fuel from the tank with the pump but it stopped after about 7 gallons. I had a just filled tank when the fa20 engine blew a year ago so that about half a tank. I know the tank has a bit of a saddle shape but it should have some system to get the fuel from the other side. Am I missing something?
Merc is offline   Reply With Quote
Old 03-15-2019, 07:18 AM   #14
Ashikabi
Ashikabi's Avatar
There is a cross over pickup somewhere. I just read about it a few weeks ago. Hopefully you can find it here in the Engine Swaps area or the poster may chime in
How difficult is it to replace brake hard lines? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 05-27-2017 11:39 PM
Point in the fuel rail cover? manonastick Engine, Exhaust, Transmission 5 12-11-2016 06:47 PM
Vacuum lines - Hard or SS braided. GsxrMe Forced Induction 8 03-02-2016 07:27 AM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
frs low fuel rail pressure ? 15,000 miles j0hnnybk01 Issues | Warranty | Recalls / TSB 10 03-04-2014 03:03 PM
