BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
View Poll Results: How would you rate the design of the 2nd gen? 1 lowest & 5 highest | |||
1 | 19 | 7.20% | |
2 | 25 | 9.47% | |
3 | 62 | 23.48% | |
4 | 104 | 39.39% | |
5 | 54 | 20.45% | |
Voters: 264. You may not vote on this poll |
11-20-2020, 07:00 PM | #617 |
Everybody gets onto the torque vs power bandwagon and often ignore all the other factors involved in acceleration. Weight, gearing, final drive, wheel size and aero all come into play. Change any one of those enough and you can change the whole feel of a car without even touching power or torque. To say simply that power or torque alone is more important ignores the big picture. They are all part of the formula
11-20-2020, 07:01 PM | #618 |
It is supposedly a double wishbone but they called the current that as well and it is actually a wishbone and a double link.
Other than that not much.
11-20-2020, 07:13 PM | #619 | ||
Drives: 2018 BRZ
11-20-2020, 07:15 PM | #620 | |
Drives: 2013 Firestorm FR-S
Isn’t this an issue of needing to shift to 3rd to hit 100kph? Another shift will cost you one sec for sure. I think the twins can just barely hit 60mph in two shifts right?
2013 Firestorm FR-S, MTX, build date 1/13.
11-20-2020, 07:34 PM | #621 | |
https://www.edmunds.com/car-reviews/...alkaround.html
The Following User Says Thank You to Tcoat For This Useful Post: | Ohio Enthusiast (11-21-2020) |
11-20-2020, 08:18 PM | #622 |
1st86 Driver!
the specs I've seen show the MT requires a shift to 3rd in 0-60, the AT can do it in 2nd, at least with the 2013. Not sure if that changed later as they tweaked things.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following User Says Thank You to Dadhawk For This Useful Post: | Spuds (11-20-2020) |
11-20-2020, 08:30 PM | #623 |
Never tried but I feel I could have pulled it off in the FRS. The 86 with the changed final drive not a hope in hell.
11-20-2020, 08:38 PM | #624 | |
Drives: ‘16 4Runner, ‘19 Corolla HB
FR-S was 58mph at redline in 2nd per my calculations. 86 would have been closer to 52mph at the top of 2nd. While it hurts the 0-60 numbers, I miss the short gears on the twins. My current car will do ~70 in 2nd and the steps are just too big with 1:1 being 4th and a 3.7 final drive. Gearing is so important for making a car engaging to drive. Sent from my iPhone using Tapatalk |
11-20-2020, 09:01 PM | #625 |
Site Moderator
Drives: Supra
About the same time at Tokyo.
https://global.toyota/en/detail/1739...659.1605923917 https://media.subaru.com/pressreleas...ils-subaru-brz |
11-20-2020, 09:20 PM | #626 | |
Drives: 2013 frs red
11-20-2020, 09:22 PM | #627 |
112kw is low too
11-20-2020, 09:29 PM | #628 |
1st86 Driver!
I've done it on a taxiway with the AT (advantage of a small airport with zero traffic most the time I'm there). It definitely hits 60 right before the redline in 2nd, but only just before redline. Didn't time it though.
11-20-2020, 10:16 PM | #629 |
Looking back at the videos and ride along videos I’m thinking the engine might be a bit under rated given the power i’m seeing put down with two in the car. At least it appears the car isn’t over rated. Possible the torque is closer to 200tq at the crank? In any event a flater tq curve and more torque should make for a faster car and better magazine numbers.
11-20-2020, 10:23 PM | #630 | |
Drives: 2017 Toyota 86
That's all technical though, the experience and joy of doing it isn't worth the effort more than a couple times. |
The Following User Says Thank You to anticubus For This Useful Post: | Tcoat (11-20-2020) |
Similar Threads | ||||
2022 Subaru WRX Spy Shots via Car and Driver | R_E_L | Other Vehicles & General Automotive Discussions | 232 | 01-03-2023 01:23 PM |
2017 BRZ Hig Res - Courtesy Subaru Global Media | Trap63 | BRZ First-Gen (2012+) -- General Topics | 10 | 07-11-2016 09:53 AM |
Subaru global brz web page | Gaen | BRZ First-Gen (2012+) -- General Topics | 4 | 06-15-2012 01:32 AM |
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show | C-Bone | BRZ First-Gen (2012+) -- General Topics | 39 | 03-24-2011 09:22 AM |
FT-86 makes UK debut at Goodwood Moving Motor Show | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 28 | 07-09-2010 02:57 PM |
