10-26-2019, 10:41 AM | #365 | ||
Drives: 2015 FRS - FFR GTM
Did the CF overlay late yesterday. Looks OK,,, weave isn't quite as straight as it might be,, but overall looks OK. Need to add one more coat or resin (surfboard resin not epoxy) then sand and buff.
2015 FR-S - One Day I'll Finish The Swap |
The Following 6 Users Say Thank You to gtpvette For This Useful Post: | Irace86.2.0 (12-08-2019), kask2_6.0 (10-26-2019), SuperTom (01-21-2020), Ultramaroon (10-27-2019), venturaII (01-21-2020), wparsons (10-28-2019) |
10-26-2019, 05:29 PM | #366 |
Drives: 2015 frs
Glad your feeling good enough to get back out in the shop. Intake cover looks good.
The Following User Says Thank You to Zer0 For This Useful Post: | gtpvette (10-27-2019) |
10-30-2019, 12:02 PM | #367 |
Into second week of vacation,, good god I can't wait until retirement. That said,, killing some time and decided to try to mod the fender garnishes before I bought new ones. Just never cared for the emblem and it certainly doesn't go with the car now. Basically cut it out and welded it back in place with a soldering iron. I should of bought the plastic welding kit from Harbor Freight but was too lazy to drive the 25 miles. Hopefully the welds wont crack
The Following User Says Thank You to gtpvette For This Useful Post: | Leonardo (10-30-2019) |
10-30-2019, 01:09 PM | #368 | |
Drives: 14 BSP Edelbrock BRZ
The E85 can be added to both (and I think I already see the flex fuel analyzer in his engine bay. So lots of up front work and cost (although I would have stayed with the stock body to make it a sleeper) but a simpler, more reliable system in the end. I can't wait to see this thing on the road. |
The Following User Says Thank You to toast For This Useful Post: | gtpvette (10-30-2019) |
10-30-2019, 01:22 PM | #369 | |
Drives: 2016 Scion FR-S
If someone made an aftermarket fender garnish exactly like the OEM FR-S ones but without the stupid emblem I'm sure they would sell tons of them. |
10-30-2019, 02:26 PM | #370 | |
When I sanded the area I used a very rough grade of paper but between the body filler and high build primer it'll smooth out. May be a while before I paint it as I need to do the 4 fender flares, spoiler and the garnishes all at once. [ame]http://youtu.be/aIMl9vtRqPg[/ame]
The Following User Says Thank You to gtpvette For This Useful Post: | Infinity (10-30-2019) |
12-08-2019, 11:20 AM | #371 |
Has a storm blow through here a couple weeks back. One of the gusts got hold of the hood and blew it off it's stand,, ended up bending the crap out of both rear corners. I was able to straighten them out but it'll require that the hood gets painted now.
While doing that I came to the conclusion I didn't really like the scoop I made. Knowing that I'll have to paint the hood now,, I want the scoop body color as well and it just wasn't even enough side to side. Opted to start making another the way I made the manifold cover... that is using ribs to set the shape. I made 4 ribs that ran from the middle to the rear then covered them with 1/8" particle board. As you can see it flushes up at the front of the hood. The manifold cover sticks out about 1" so I set this a 1.5" where it peaks. I'll try to fiberglass it today. As a sidebar,,, looks like a Chevy Cowl Induction hood a bit
The Following 2 Users Say Thank You to gtpvette For This Useful Post: | Irace86.2.0 (12-08-2019), Zer0 (12-08-2019) |
12-08-2019, 03:19 PM | #372 |
Drives: 2015 frs
The hood redesign looks good! It looks more like a oem designed hood.
The Following User Says Thank You to Zer0 For This Useful Post: | gtpvette (12-09-2019) |
12-08-2019, 08:18 PM | #373 |
義理チョコ
The first one was cool. This one's way cooler.
The Following User Says Thank You to Ultramaroon For This Useful Post: | gtpvette (12-09-2019) |
12-16-2019, 08:21 PM | #374 |
some progress...…
The Following 4 Users Say Thank You to gtpvette For This Useful Post: |
01-21-2020, 03:08 PM | #375 |
Well the holidays are over thank god.. between the stuff going on before and the projects after (I.E. gave my wife backsplash tile as a gift and had to spend 2 weekends installing it) haven't got much done. The good news is it's time to work on the car again.
Work continues on the scoop. Smoothed it out with some Bondo, blocked with 36 grit and it looks pretty good. As I don't have a garage and the weather's been cold (upper 60's - low 70's) I set up in the yard to spray primer. Will need to come up with some kind of booth when it's time for paint. Blocked the hood scoop after 2 wet coats and most of the 36 grit scratches are gone. Will need to prime then sand a few more times to get them all but it should look good in the end. The rest shown just needs to be wet sanded before paint. Still have the hood to do,, multiple dings, corners bent, clean up the cut out, install latches, sand both sides then prime. Put a couple good coats on the garnish then sanded,, nice and smooth but a little warped from the welding. Should be fine with clips and a little 3M tape though. A shot of the backside shows where I melted it together.
2015 FR-S - One Day I'll Finish The Swap Last edited by gtpvette; 01-21-2020 at 03:23 PM. |
The Following User Says Thank You to gtpvette For This Useful Post: | Infinity (01-21-2020) |
01-21-2020, 06:45 PM | #376 |
Thanks for the update on your fender garnishes! They look about perfect on the exterior!
Is it possible to separate the back piece of black plastic from the fender garnish? It looks like separating the 2 pieces might make the job easier. |
01-21-2020, 09:45 PM | #377 |
I'm not sure what you're asking here. The black plastic attached to the garnish provides the base to attach the clips to,, so it's needed. The melted plastic you see was left overs that I melted to try to attach everything together.
01-22-2020, 08:12 PM | #378 | |
I mean like remove the black plastic, cut out the embossed emblem and weld it back on, and then reattach the black plastic. It looks like it may make the whole process a bit easier. |
Similar Threads | ||||
Should I have just got a new motor? | SoundsOfTheUniverse | Issues | Warranty | Recalls / TSB | 12 | 07-31-2017 07:51 PM |
Seized motor!! What STX mods should I do while I have the motor out?? | BlaineWasHere | Tracking / Autocross / HPDE / Drifting | 27 | 12-11-2014 02:39 PM |
K2 Motor? | Ronin Sascha | Engine, Exhaust, Transmission | 8 | 08-16-2014 06:51 PM |
Does every motor say #1 | sosick | Engine, Exhaust, Transmission | 21 | 05-05-2014 09:28 AM |
MOTOR UNION | David | Southern California | 0 | 06-22-2013 01:32 PM |
