Old 10-18-2021, 12:58 AM   #729
kennwin
Drives: 2013 Scion FR-S 10 Series #832
odd LTFT
Hey guys. Been reading up on this forum alot and similar threads that had high ltft. I seem to still not figure out why I have oddly positive LTFT up to 20% at times. My first tank of E85 ran great, but my second tank has thrown my different numbers where my IAT has been running insanely hot (sometimes like 30-40 degrees higher than ambient while just driving normally) and my LTFT has been increasing positively like crazy off throttle. Never ran above ±10%. Could someone check if my AFRs are okay? I have a data log under light throttle and cruising on the way home.
TRD intake, JDM TRD catback exhaust, rest is stock
https://datazap.me/u/kennwin/log-163...g=0&data=1-2-9
kennwin is offline   Reply With Quote
Old 10-18-2021, 04:24 PM   #730
Purist
Purist's Avatar
Drives: Subaru BRZ
What tune do you have?
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 10-18-2021, 07:18 PM   #731
kennwin
Running on the Stage2PlusE85 V4 canned tune, verified that I am on the tune.
Old 10-18-2021, 07:39 PM   #732
Purist
Purist's Avatar
Drives: Subaru BRZ
Can't help you man. Steve99 is a guru at this stuff.
Less More
Old 10-19-2021, 02:35 AM   #733
steve99
Drives: FT86
IAT and MAF are in same sensor in intake, check the sensor os mounted correctly and the o ring isnt damaged , check plug is firmly in socket on maf\iat sensor
Old 10-19-2021, 05:45 PM   #734
kennwin
Ran the car this morning, LTFT stabilized around +6%. Must have had weird fuel in the lines, but everything is running normal now. No codes, misfires, or knock. IAT is still hot compared to ambient, I'll have to look into that. MAF/IAT sensor was secured.
Old 10-22-2021, 04:43 AM   #735
Purist
Purist's Avatar
Drives: Subaru BRZ
Are you in Oz? United E85 is super reliable.never had an issue. Ever.
Less More
Old 10-30-2021, 07:32 PM   #736
kennwin
I am in california
Old 10-30-2021, 07:39 PM   #737
Purist
Purist's Avatar
Drives: Subaru BRZ
I am in california
I'm sorry. Not to put to fine a point on it but the E85 here is guaranteed 85% and 107 octane. Spoilt huh.
Less More
Old 06-26-2022, 12:50 AM   #738
Samba86
Samba86's Avatar
Drives: 86 GTS
Just gone E85 and I thought I'd ask a few nooby questions (hoping Steve99 might chime in). Running 4.03 S2+ canned tune with United ethanol (only mod is a Tomei catless UEL). The engine feels so refined, and throttle response has improved greatly, but from the look of the exhaust tips I'm running quite rich.
I'm new to data logging, but here's a pic after a cold start (guessing I've done 150km on E85 so far.) I know a proper data record and upload will be needed, but am I looking ok so far?
https://i.ibb.co/PjgfS6n/IMG-7546.jpg
2. Steve, do you recommend I download the appropriate Wayne Rom and begin his process?
3. When in the live logging mode, the back button on my tablet doesn't respond. Normal?
4. Final one, there was talk about E85 compatible oil way back in this thread. For the Aussies among us, any recommendations?
Cheers, all. BTW, if there's a way to give back (patreon or the like) I'd appreciate if someone can point me in the right direction
Samba86 is offline   Reply With Quote
Old 06-26-2022, 10:09 AM   #739
Espi
Espi's Avatar
Drives: 17 BRZ
You can get tunes from steve himself here
https://www.facebook.com/profile.php?id=100009796213855
I run 2 custom tunes one E85 and 93 for different times of the year both custom tuned by Steve99
cheers
Espi is offline   Reply With Quote
The Following User Says Thank You to Espi For This Useful Post:
Samba86 (06-26-2022)
Old 06-26-2022, 06:36 PM   #740
steve99
Drives: FT86
Can do custom tunes if needed
Oil run a SN or better rated full synthetic in warm Australia climate id go 5w30
Penrite Enviro full synthetic or Nulon long life you can get those at Autobarn or Supercheap auto
Old 06-26-2022, 09:51 PM   #741
Samba86
Samba86's Avatar
Drives: 86 GTS
Thanks so much for the info, Steve. Appreciated
Old 06-27-2022, 05:06 PM   #742
snivy666
snivy666's Avatar
Drives: '16 FR-S
Hey yall, wanted to hear thoughts on running v4 stage 2+ e85 tune on stock headers? I’m worried about long-term usage of this catch-all tune.. the older canned tunes had EL-specific e85 tunes but the new v4 is for ALL headers, so I’m worried about whether its just not a good idea to use a tune not optimized for stock headers
snivy666 is offline   Reply With Quote
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 04:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
