Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-14-2013, 09:52 AM | #43 | |
You're putting context in our mouths that never existed. I never said there was a conspiracy. Believe me, Airaid isn't the first manufacturer/vendor to post results that don't resemble real world testing, or that have been.... exaggerated a little. No, I won't tell you one intake is better than the other. Because, after a tune, they all perform within a couple HP of each other anyway. The difference really is how hot the air being consumed is. Without a tune, however, is a different story. Look, you can cop the little attitude all you want. How many intakes have you independently tested? More than myself? Please, paste the links to all your unbiased reviews and tests. I don't really care which intake comes out on top anyway, as it will be useless for my goals. I just happen to like the 86 and want people to have real information available so that they may make their own, *gasp* educated choice. |
The Following User Says Thank You to 2forme For This Useful Post: | Sportsguy83 (02-14-2013) |
02-14-2013, 10:09 AM | #44 | |
Drives: 2013 Scion FR-S AT Asphalt
Since we both like the 86 and we both want people to have real information available, in my eyes, we should be working together not bickering. I know that you have spent a ton of time and money testing different parts for these cars and I don't discount your efforts or background one bit. That said, why not help out and provide what information you (or anyone else) have so that I can refine this. Scott
The Following User Says Thank You to naikaidriver For This Useful Post: | LeeMaster (02-14-2013) |
02-14-2013, 10:11 AM | #45 | |
The Following User Says Thank You to 2forme For This Useful Post: | naikaidriver (02-14-2013) |
02-14-2013, 10:23 AM | #46 | |
SLO NO MO
The BRZ/FRS stock intake system is well-engineered. There are few gains to be had by doing anything aftermarket with them. The intakes that noticed the most power gains achieved them not by opening up airflow (the typical exercise undertaken when you add a performance intake) but by manipulating AFR. This function can also be done by an ECU tune. I'm not here to fanboy one intake over another - Personally, I think stock is the way to go with a drop-in if performance/efficiency is the only thing you're after. Full diclosure: I own the AirRaid as well as the AFe. I swapped out the AirRaid because I didn't like the aesthetics and the whole loose screws coming undone situation thing left a bad taste in my mouth. I went with the AFe because it looks good, sounds great, and I got a fantastic deal on it at a time when someone was going to buy my AirRaid essentially washing my cost out. Unfortunately, shortly before he was to buy the intake, someone dyno'd the AirRaid on here and determined that it was actually losing power instead of gaining power. He pulled out of the deal and now I still have it. Oh and to answer your question directly - no, I do not think a tune will negate all of the gains. Let me put it this way - if a stock car with an Injen gets +13 HP, and a stock car with an ECU tune gets +15 HP, a stock car with an Injen + ECU Tune won't see +28 HP, because they ultimately are both doing something with AFR that affects power output. I did not mean to imply that a stock car with Injen and ECU Tune ends up with +0 HP, but it would most likely be somewhere closer to +15 than +28. |
The Following 4 Users Say Thank You to Foobar For This Useful Post: |
02-14-2013, 10:45 AM | #47 | |
Because of the changes and infinite variables that tuners bring to the table with programming engine management to work with modifications, Intake, headers, cat backs and such, I deliberately left that out. From my experience, most people don't go to tuners after installing aftermarket parts on their cars which I agree with 2forme can result in not seeing the maximum potential of any mod and even worse, dangerous AFRs resulting in engine damage. Aside from manipulating AFR by changing volumetric efficiency and MAF placement, intakes don't do much and the factory intake on the 86 is remarkably well designed as shown by the stark similarities in dyno numbers from just changing the filter element and changing the whole intake. All things being equal, if I were to have added drop-ins to the chart they would have made all aftermarket intakes look like a monumental waste of money. Anyway, I can see that I have some serious editing to do to my disclaimers and that it is worth mentioning drop-ins now. This was intended to be a work-in-progress so I appreciate any help the more experienced tuners and testers can provide. (PS. Sorry for the grumpy reply earlier... I really shouldn't post anything before my morning cup of coffee.) Scott
The Following 3 Users Say Thank You to naikaidriver For This Useful Post: |
02-14-2013, 10:46 AM | #48 |
Drives: 2013 Hot Lava Scion FRS
The Following User Says Thank You to Saab2Frs For This Useful Post: | tripjammer (02-25-2013) |
02-14-2013, 10:56 AM | #49 |
SLO NO MO
02-14-2013, 10:59 AM | #50 |
02-14-2013, 11:00 AM | #51 |
02-14-2013, 12:15 PM | #52 |
Initial G
Drives: 13 FR-S, 15 BMW 228i
The only way to really tell is to have someone do an intake shoot-out.
Get a group together and take donations, pick 10 intakes to test out, figure you need to raise about $5000 to pay for the intakes and the dyno time, less if someone fronts the money and sells the intakes after the shootout. Wouldn't that be grand? |
02-15-2013, 05:22 AM | #53 | |
Drives: Corolla
Their probably was a small problem with his dyno but either way his results open and closed were basically the same minus 1-2 whp. Which isnt a big deal. You post as if it you do it with the hood closed it wouldnt see any gains at all. Get over it bro. He gave us a dyno for the Injen intake and proved your wrong. The results in the end show that it is a minimal difference. The torque is a little off but whats important is that it doesnt really fucking matter hood open or closed. Now the AFR is a different story but the point is that it has been shown that it doesnt really make that big of a difference open or closed. I personally wouldnt get any of the intakes on the market besides a true CAI like Perrins or FA20 clubs. If I did go with the Injen I would only get it if I got it tuned for but might as well just get Perrins CAI they plan to release that requires a tune. In the end if you get an intake for power your just doing it wrong. Very few intakes produce anything better than a drop in for the brz/86 but people like the sound/throttle response which is a reason why people get an intake. Last edited by ChaChas345; 02-15-2013 at 05:33 AM. |
02-15-2013, 05:59 AM | #54 |
I Love custom Turbo kits
Drives: Limited BRZ
Everyone who wants to get their money's worth... so yes, a LOT of people care
The Following User Says Thank You to Sportsguy83 For This Useful Post: | 2forme (02-15-2013) |
02-15-2013, 06:45 AM | #55 | ||
I mean, hell, I don't even have an intake on my car anymore (because it doesn't fit ). I'm going to be putting my AFE up for sale soon. Last edited by 2forme; 02-15-2013 at 06:57 AM. |
The Following User Says Thank You to 2forme For This Useful Post: | Sportsguy83 (02-15-2013) |
02-15-2013, 07:04 AM | #56 |
Drives: none yet
[QUOTE=Saab2Frs;734558]I always ride with my hood open.QUOTE]
yes, so do I always dyno my cars while at freeway speeds..... the reason they dyno with the hood open is to simulate the wind going in the engine bay while the car is moving. if some of you didn't get that maybe you should put a wind speed sensor under your hood and go for a drive. there is wind movement at speed and most of the underhood air isn't scorching hot everywhere. |
Similar Threads | ||||
royal purple coupin at pepboys $25 dollar off 5 quarts | Xdragonxb0i | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 02-08-2013 10:05 AM |
AEM Cold Air Intake, It's here... real gains? | Esoteric | Engine, Exhaust, Bolt-Ons | 1 | 12-30-2012 02:34 AM |
Yen to Dollar conversion link | whataboutbob | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 08-31-2012 11:51 AM |
1000 dollar deposit first in line for a whiteout FR-S | TougeFR-S | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-20-2012 10:58 AM |
3.5 Million dollar Supercar Crash + a Prius | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 17 | 12-05-2011 05:27 PM |
