01-09-2015, 02:00 PM | #113 |
Drives: FR-S 10 #103 AT
@moto-mike
Have you considered getting a reduction gear assembly made? The kind of thing where the crankshaft turns a large pulley, but not absurdly large, and welded/bolted to that pulley is a smaller pulley that drives the blower? That way the blower gets a normal sized pulley mounted on it and you eliminate the whole clearance issue. Manipulating the ratio on the reduction pulleys tweaks the final ratio.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
01-15-2015, 07:49 AM | #114 |
Drives: GT 86
BUMP
01-15-2015, 08:26 AM | #115 |
That Guy
Drives: 2013 asphalt FRS MT
01-17-2015, 09:07 PM | #116 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
A little update. I'll start with this datalog snippet: This is a typical drive on pump gas, you can see the CPS voltage is .68 or about 12% e content (pump is 8-12 percent here). Difference from the last datalog is that we pushed the cruise and low load ignition timing higher to get better economy. So far so good. Some context: "Knock Retard" is not a terribly useful parameter, but "Ign. Correction Fine" is more indicative of knock events. Under load, there are NONE which is awesome. Under part throttle low load you see just a bit. The significant thing here is that this pattern is no different than any other FI kit that retains good drivability. So 8 psi or 19 psi it will look the same. Most importantly the IAM is staying at 1. This is awesome. I'm sure in the warmer weather it will move a bit, but even still there is no appreciable knock. You can see the learned correction is not dropping, and there are no negative regions. Understand that this car has an extremely sensitive knock sensor, and the only way it is close to 0 is if the car is totally stock, or if it was turned down or disabled. We have it fully compensating on this tune and throughout the rev/load range. Conclusion from that is that even on pump gas you have nothing to fear. The kit has about 1800 miles on it now, and we'll keep driving it as much as possible until the 15 WRX gets here. From what we're seeing there people are getting those DIT motors to 30 psi on pump gas with slightly lower CR, it makes sense that we can approach 20 on this motor with the BRZ and not have a instant block ventilation. |
The Following 4 Users Say Thank You to Xero-Limit For This Useful Post: |
01-17-2015, 10:15 PM | #117 |
WUB WUB
Drives: 2013 Firestorm
subbed. definitely interested in this one.
01-18-2015, 06:09 AM | #118 |
That Guy
So your still running about e12 ish. Any guesses on the effective octane rating of that mixture? Is the power still significantly higher than the 210 at the same pressure?
Thanks for taking the plunge and doing this testing Mike. |
01-18-2015, 09:44 AM | #119 | ||
Power is significantly higher than the 210, but at the same pressure the two will be fairly close. It feels faster than the 210 on e85. Quote:
The Following 5 Users Say Thank You to Xero-Limit For This Useful Post: | Boofneenee (01-18-2015), Calum (01-18-2015), Chad86 (02-06-2015), CK_Bladesmith (01-18-2015), Dream20b (01-18-2015), sam69 (01-18-2015) |
01-18-2015, 09:59 AM | #120 |
Drives: GT 86
Will you be doing an off the shelf tune for the 335 Mike and would it be suitable for Ozzy 98 ultimate fuel ?
Apparently this is the equivalent of your 93/94 fuel I believe . |
The Following User Says Thank You to sam69 For This Useful Post: | Chad86 (02-06-2015) |
01-18-2015, 10:49 AM | #121 |
That Guy
Thanks for the explanation on the octane. Any new thoughts on the feasibility of running this on 91 octane?
The Following User Says Thank You to Calum For This Useful Post: | Chad86 (02-06-2015) |
01-18-2015, 01:01 PM | #122 | |
I think its possible. It didn't need any changes at all after putting 92 in it, so I don't see it being a problem to do on 91. Maybe a few HP down, but otherwise it should run. The 85mm pulley being available makes that even more likely to be the case. |
01-19-2015, 12:04 PM | #123 | |
"This is the mod you are looking for."
The Following User Says Thank You to mid_life_crisis For This Useful Post: | Xero-Limit (01-19-2015) |
02-11-2015, 08:06 PM | #124 |
Drives: GT 86
Any updates Mike as to how the car is going re reliability etc ?
Is mpg still reasonable when cruising and how many miles have you clocked up with the 335 ?? |
02-13-2015, 12:56 AM | #125 |
02-13-2015, 07:18 AM | #126 | |
We always include all the variations at no charge. I build the base maps with everything already included, then it is just a matter of checkboxes for the final order. |
Tags |
500whp or bust, sprintex, sprintex 335 |
Similar Threads | ||||
The new sprintex 335 supercharger | jet86 | Forced Induction | 39 | 11-01-2014 11:27 AM |
Innovate/sprintex SC | rudysaliby | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 10-28-2014 03:14 PM |
Innovate/ Sprintex vs vortech | GeeTee86 | AFRICA | 24 | 04-04-2014 02:38 PM |
Innovate/ Sprintex vs vortech | GeeTee86 | AFRICA | 5 | 03-05-2014 07:26 AM |
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing | TyperRspec789 | Forced Induction | 63 | 12-31-2013 07:39 PM |
