04-03-2019, 07:56 PM | #113 |
Drives: Subaru BRZ
Super excited! Any idea what spring rates you are planning on using for track, street, double-duty applications, coupled with alignment and suspension setting recommendations?
04-03-2019, 08:34 PM | #114 | |
FT86Club Official Vendor
Drives: Miata, GT350, FR-S
Most cars are setup up very different from the direction we are going. So the parts and setup we offer might be new compared to what the 86 community is doing now. Current plan is to offer two basic spring packages. A Sport Touring version for best possible daily driver ride quality, some canyons and occasional HPDE or autocross. The other will be our Race package with much higher rates. The Race kit will still work as a daily driver, probably riding about as well as OEM but have the capability of handling 1.5g worth of tire on a bumpy race track with some downforce. There will also be the option of custom rates but we tend to steer people away from that unless they really understand what they are doing.
The Following 2 Users Say Thank You to 949 Racing For This Useful Post: | Code Monkey (04-03-2019), strat61caster (04-04-2019) |
04-03-2019, 08:48 PM | #115 | |
04-03-2019, 08:50 PM | #116 | |
04-03-2019, 09:16 PM | #117 |
Quick look at the new touchscreen controller for Xida ACE shocks.
[ame="https://www.youtube.com/watch?v=24CrPhh3JgE"]https://www.youtube.com/watch?v=24CrPhh3JgE[/ame]
The Following 2 Users Say Thank You to 949 Racing For This Useful Post: | Code Monkey (04-03-2019), DustinS (04-08-2019) |
04-03-2019, 11:09 PM | #118 | |
Drives: 2013 FR-S, 2007 Acura TL 5AT
So, it seems like these will be handled similar to the Miata Xidas? A user can opt to run standard shock mounts or option the 949 coaxial mounts/camber plates? If one already has a set of, say, RaceSeng camber plates, you would theoretically just need to have the correct size spring adapter (I'm guessing 2.25" based on the Miata ones.) If using standard rear mounts, I would guess you'd just need a cup style spring adapter for centering. Also, nice to see the front is inverted. I think everyone who came from the Miata community to the 86(myself included) is pretty damn excited to see these come into existence.
2013 FR-S Raven, AutoX/Track/Daily Driver
Build: Angel's Dual Duty FR-S Build YouTube: Angel Christov |
04-03-2019, 11:25 PM | #119 |
Yup, any top mount, including OEM. 2.25" springs front and rear. Like we do with our Miata shock, we will provide spring locators to work with the OEM mount.
We have a set of Raceseng plates on Blub now. When researching all this I saw that the stack height for the various camber plates on the market were all over the place. And only one or two were close to OEM. Getting optimum bump travel is critical for this platform as it is for many others. But it is impossible to fine-tune that bump travel with a lighter, cooler running, full stroke fixed length assembly without knowing the stack height of the camber plate. That's why we designed the adjustable strut flange. That gives us full OEM shock stroke which you do not get with a two-piece, length adjustable coilover. So best of both worlds and in terms of both versatility and functionality. This shock has some features which will allow quite a bit more camber then OEM without the use of camber plates. More details on that to follow.
The Following 5 Users Say Thank You to 949 Racing For This Useful Post: | AngelGT86Racer (04-03-2019), churchx (04-04-2019), Code Monkey (04-04-2019), Shark_Bait88 (04-04-2019), Takumi788 (04-04-2019) |
04-08-2019, 10:23 AM | #120 | |
Drives: None
04-08-2019, 10:31 AM | #121 | |
Drives: None
Having an ego in a hobby sport is insane. Frankly having an ego in anything in life where one is not the best is insane. It took me a long time to figure it out but we can all learn so much more if we had a growth approach to everything we do in life. Keep kicking ass and I look forward to the development of the car! |
04-10-2019, 01:17 PM | #122 | |
ND platform was designed, ground up to be a 2 seat roadster using entirely new parts pretty much everywhere except the engine, which was a retuned version of the Mazda 3 engine. Engine almost all behind front axle centerline 50/50 weight distribution Double wishbone suspension Extensive use of aluminum and thin gauge steel in tub Transmission, brakes and diff all engineered just for the ND 86 is a parts bin special. -53% weight on nose -Engine almost entirely ahead of front axle centerline -Struts in stead of wishbones because H4 engine config restricts space for control arms. -Rear steer (rack behind axle) leftover from front drive architecture. -Generally all repurposed drivetrain, brakes and suspension parts from FWD Subaru Don't misunderstand me, we love the 86 and it's a very well engineered sports coupe. Faster than an S2000 with equal mods, despite the S2000 being a truly ground up sports car. But the 86 was not designed from the ground up as a sports car. Many design compromises because of the parts they were forced to use top remain within the development and production cost targets. Like the 911, which was deigned using leftover beetle parts, the 911 has become something very special. So no shame in being a parts bin special. In this sense, the ND has more in common with a typical Ferrari, being designed from a clean sheet to be a 2 seat sports car. When we first sat an pre-production build 86 in our shop Spring 2012, I was disappointed to see the huge gap from the rear plane of the engine to the firewall. The reason? Leftover rear steer from a FWD Subaru. Then we drove it May 2012
The Following 5 Users Say Thank You to 949 Racing For This Useful Post: | churchx (04-10-2019), finch1750 (04-10-2019), MaverickMonk (04-10-2019), mistople (04-10-2019), RedReplicant (02-12-2023) |
04-10-2019, 01:57 PM | #123 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Would be interesting if that's how the Xidas turn out |
04-10-2019, 02:40 PM | #124 | |
Drives: Fr-s
I, for one, am glad you have you aboard the train and look forward to future developments. As long as we are speculating on spring rates I'm guessing somewhere in the 500f/600r range
The Following User Says Thank You to redlined600 For This Useful Post: | Shark_Bait88 (04-10-2019) |
04-12-2019, 03:34 AM | #125 |
The nice thing about being a parts bin car, was the extensive aftermarket support already available when the car launched. Our rear subframe is 95% identical to *current* WRX and STI. So your selection of adjustable arms is quite large, subframe inserts were available from day one... etc. Calipers and pad shapes are carried over from other mass produced Subarus.
On the flipside, the ND and previous Miatas have full alignment adjustability from the factory. Granted, I've become a bigger fan of turnbuckles over eccentrics since owning an FR-S and installing aftermarket arms. Also, nice to know you guys measured 53% front weight bias. When I measured mine, it came out to 55% front.
04-12-2019, 11:10 AM | #126 |
Ours was 54%, but I was quoting factory specs to avoid arguments
The Following User Says Thank You to 949 Racing For This Useful Post: | AngelGT86Racer (04-12-2019) |
Tags |
6ul, 949 racing, blub, xida |
Similar Threads | ||||
LED Blub Diffuser? | Chimera | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-07-2016 12:24 PM |
Project Mu Racing 999 brake pads | CSG Mike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 11-15-2013 03:55 PM |
Project Kics R40 racing lug nuts | HighbreadEH3 | Wheels and Tires | 0 | 09-03-2013 01:49 PM |
The Enjuku Racing Project FR-S! | Enjuku Racing | Announcements, Contests, Giveaways | 12 | 07-19-2012 11:54 AM |
