04-29-2014, 03:55 PM | #1135 |
Drives: 2013 FRS
This is my thought as well. If you haver a CEL light and the OFT doesn't read any codes, the CEL is likely caused by something non-ECU related. If you have a 6AT, it's likely the TCU that is triggering a code for some reason.
04-29-2014, 04:02 PM | #1136 |
Drives: 2015 Tacoma
I have a manual, any way of clearing or reading the code?
"Bah Weep Granah Weep Nini Bong"
Old: 2013 Arengto FR-S Current: 2015 Tacoma/2020 Sequoia Pro Future: 2022 CWP Limited Est Delivery 06/22 |
04-29-2014, 04:06 PM | #1137 |
Drives: 2013 FRS
04-29-2014, 04:51 PM | #1138 | |
Drives: 2015 Tacoma
Still under 10k lol Should I flash back to the stock? I will almost certainly throw a code for my catless header before I get there.
04-29-2014, 10:01 PM | #1139 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
Is it common to get knock correction of about 1.7 degrees while on the highway cruising at 3 - 4 k? Most of the corrections pull ~.1 degrees but occasionally I will see .5 - 1.7 deg
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
04-29-2014, 10:47 PM | #1140 | |
Go-Kart Enthusiast
hmm found this just now Q: When should I be concerned about detonation/knock? What are some things to try or items to check? A: This is probably the most difficult question to answer but in general, we consider corrections of ~-2.5 degrees to be “normal” and not of major concern. If DAM is persistently below 1 or 16 and/or corrections 4 | P a g e greater than -2.5 degrees are repeatedly observed to the “Feedback Knock Correction” or “Fine Knock Learning” monitors, this is good reason for further inspection.
FRS
04-30-2014, 03:18 AM | #1141 | |
Drives: UK GT86
.: Stealth 86 :.
04-30-2014, 07:18 AM | #1142 |
Go-Kart Enthusiast
I found that reading from COBB tuning for a WRX. Not sure if the parameters are different with that car
FRS
04-30-2014, 12:46 PM | #1143 |
Tire Destroyer
Drives: Firestorm+snail
Anyone know how to activate flat-foot shifting??
04-30-2014, 12:50 PM | #1144 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
You need to open the map in RomRaider or Tuner Pro and mofify the FFS Delta Table. It is 0 by default which means disabled. To activate it, you set the net to the difference between fuel cut and desired FFS RPM. This means if you have a Rev Limit of 7600RPM and you want FFS to be 4600RPM, you need to set the table to 3000.
The Following User Says Thank You to Luckrider For This Useful Post: | Shiv@Openflash (04-30-2014) |
04-30-2014, 01:37 PM | #1145 |
Drives: FR-S 10 #103 AT
@shiv@vishnu It's understood that you have a lot on your plate right now, what with the upcoming nuptials and trying to wrap up projects for business so you can have a real honeymoon. Having said that, I'm curious what you figure the chances are of the next set of OTS maps being done before your time off? Just curious, not trying to add pressure to your already busy schedule. If they are on the list for when you get back, that's fine, just wondering.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
04-30-2014, 01:43 PM | #1146 | |
Drives: 2013 FRS
The Following 7 Users Say Thank You to Shiv@Openflash For This Useful Post: | Blu-by-U (04-30-2014), FrsDuke (04-30-2014), neutron256 (04-30-2014), robwbright (04-30-2014), Sojhinn (04-30-2014), Turdinator (04-30-2014), wparsons (05-15-2014) |
04-30-2014, 02:29 PM | #1147 |
Drives: 2017 Fiesta ST
Wedding 1.0 is a hopefully final and one-time upgrade, so better put all your efforts into this one!
I think everybody will understand if you take a few days off for this. |
The Following 2 Users Say Thank You to OnkelC For This Useful Post: | Shiv@Openflash (04-30-2014), wparsons (05-15-2014) |
04-30-2014, 02:39 PM | #1148 | |
Oh well, best wishes that the day is everything she's dreaming of. As a buddy of mine pointed out years ago, "it's her day: you're only there because she'd look foolish standing up there with just her girlfriends. The sooner you accept that, the better off you'll be."
The Following User Says Thank You to mid_life_crisis For This Useful Post: | Shiv@Openflash (04-30-2014) |
Tags |
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest |
Similar Threads | ||||
Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 03:48 AM |
Tablet Install | ThugNasty | Electronics | Audio | NAV | Infotainment | 4 | 04-13-2013 03:15 PM |
Blutooth OBD II and a 9.7 tablet.. | Scooby South | Electronics | Audio | NAV | Infotainment | 10 | 12-16-2012 08:11 PM |
7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 11:53 AM |
