#99 |
Grip>Slip
Indeed. Love me some Shaka Smart and VCU.
| The Following 2 Users Say Thank You to xjohnx For This Useful Post: | lbroskee (01-19-2013), Sportsguy83 (01-23-2013) |
#100 |
Post pics of the video when you get it wired up please! The mounting on it is extremely clean, so if the viewing angle is nice I'll probably buy the same unit.
#101 |
Grip>Slip
Will do. I may just do a temporary wire job in the meantime so you can see.
| The Following User Says Thank You to xjohnx For This Useful Post: | lbroskee (01-23-2013) |
#102 |
Drives: 2014 Boxster S; 2015 Macan S
Is there a link to that eBay site? I found one on there for $120. $110 would be even better.
#103 | |
Drives: '13 Boxter S, '13 BRZ(gone)
http://www.al-eds.com/Rydeen-Mobile-...0B-p22239.html They shipped fast and I received it fine, although I can't speak to how well it works yet since I haven't had time to install yet (maybe this weekend). |
| The Following 2 Users Say Thank You to kludger For This Useful Post: | davesrave (01-23-2013), tripjammer (02-25-2013) |
#104 | |
#105 |
Finally installed the Rydeen Duo today after it sat on the shelf for a few months. Very easy install, took about 90 minutes.
#106 |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | tripjammer (01-29-2013) |
#107 |
Grip>Slip
Beautiful day outside today, I'm going to try and finish my install up after work. The amp power wire seems to tightly wound in the loom to get a tap connected to it. Also, the power wire from my camera seems to be of a smaller gauge than the amp wire. I'm afraid if I use a tap there, the tap may actually cut the amp wire, unless i'm missing something.
Right now I'm thinking that I may just extend the power lead and run it to the fuse box so i can tap into the same add-a-circuit that my radar detector is using, unless someone knows of a better way. |
#108 |
I'll be honest I copied the way of the original poster in stripping and doubling up the power wire and shoving it in the same hole as the green amp power wire. I did strip the tape back a bit and was going to use a different method but once this was tiewrapped/taped together and plugged in I could see it wasn't going anywhere.
I usually use these solder sleeve connectors which have solder in the middle which you melt with a heat gun, they work great. I was just going to cut the amp power wire in the middle so I could do a 2->1 junction. But I got lazy. |
#109 | |
Grip>Slip
#110 | |
Drives: 2016 Toyota 4Runner Trail Premium
Pic |
#111 | |
Radio wiring harness guru
Drives: 1996 SVX L AWD
Several cameras work from OEM HU's 6V power lead
I have some great news: The Rydeen Duo and MINy cameras will work from the OEM head unit's 6 Volt camera power supply! Several Subaru owners have confirmed those cameras work.
I've found several other cameras that will work from 6 Volts. Quote:
So the upshot is that with the Duo and MINy, you can easily power the camera by connecting their power lead to my power wire. Anyone who ordered my camera RCA cable or harness without the power lead, let me know (via e-mail) and I can send you just that extra wire.
#112 | ||
Barring that, there is an unused connector near the HU that has +12V Accessory and ground (as well as +12V Battery). You can connect straight to that, or add a relay controlled by the HU's 6V lead so the camera is only powered when needed.
| The Following 2 Users Say Thank You to SVXdc For This Useful Post: | tripjammer (02-25-2013), xjohnx (01-29-2013) |
| DGM BRZ limited on the way? | Coheed | Member's Car Journals | 16 | 04-11-2013 03:09 AM |
| My LR BRZ Limited | epson1 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 11 | 09-08-2012 03:18 PM |
| BRZ Limited Available | JohnATL | Southeast | 3 | 08-12-2012 12:32 PM |
| Want to buy a BRZ Limited AT | kgc | Northwest | 1 | 06-17-2012 12:45 AM |
| DGM BRZ Limited (man) available | Mitchs_86 | BRZ First-Gen (2012+) — General Topics | 6 | 06-14-2012 01:50 PM |
