04-17-2014, 07:34 PM | #1065 |
Drives: 2013 FRS
OpenFlash Manager will not allow you to load up a ROM with CAL ID different than your original ROM. But ALL the ROMs, regardless of labelled CAL ID (700C, 900C, etc,) are all based upon the A01C ROM file. So you may see some disparity when comparing the CAL ID labelled in the file you loaded and the the CAL ID reported when your OFT queried your ECU (in ECU Info) function.
The Following User Says Thank You to Shiv@Openflash For This Useful Post: | Blu-by-U (04-17-2014) |
04-17-2014, 07:44 PM | #1066 |
Pharmasaurus Magnificus
Ok, so right now ive loaded Stage1 A00C, so I should switch to A01C? It seems to have let me load it fine, so you mean it should not have?
2013 FRS 6MT (Delivered 5/12/12 - 1st86!)
AEM CAI / Magnaflow Catback / OFT / OFH / e85 2015 Nissan GTR |
04-17-2014, 09:26 PM | #1067 | |
Fanboy
Drives: 2013 ultramarine frs
tablet says a01c perfectly fine all the tunes are based on the a01 fix anyway. It is idiot proof.
I'm done helping those who won't help themselves.
TL;DR: -Duke |
The Following User Says Thank You to FrsDuke For This Useful Post: | Shiv@Openflash (04-18-2014) |
04-18-2014, 09:10 PM | #1068 |
I'm planning to buy a Viper remote start + security system -- any idea if this and OFT will interfere with each-other? Will I be able to flash safely?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
04-18-2014, 09:44 PM | #1069 | |
Drives: 2014 Scion FR-S
Sent from my GT-N5110 using Tapatalk |
04-19-2014, 02:59 AM | #1070 |
I've never had one of these before but it's my understanding that you can get a bypass transponder that activates when you hit the remote start.
04-19-2014, 09:24 AM | #1071 |
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
My OFT was scheduled to be delivered today... mail is here and no OFT.
USPS must have screwed up.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe 2006 Saab 9-3 2.0t 1997 Honda Accord Coupe 1995 Honda Prelude VTEC |
04-19-2014, 10:25 AM | #1072 | |
Drives: white out project fr-s
clutch switch is bypsased BTW. just gotta remember to leave it in neutral!! |
04-19-2014, 01:08 PM | #1073 | |
Sent from my SM-N900T using Tapatalk |
04-19-2014, 03:20 PM | #1074 | |
Drives: 2013 Scion FRS
Interesting. I have the same set up. But because these alarms are integrated with the ecu. The. Alarm it self will sense if the car is in gear and won't start. Maybe it's the same with yours?
04-19-2014, 07:55 PM | #1075 |
ive purposely started my car with the viper in gear and it does start. i still need the original key tho to prevent the wheel from locking....which has happened where i forget to insert the key to the ignition after i remote start it, as soon as i turn the wheel, it would lock on me...
04-19-2014, 08:03 PM | #1076 |
Some Dumb Guy
Drives: wanting an Acabian
It's coming. Enjoy when the time comes.
She said it was her or the car. Longest she had ever seen.
04-19-2014, 08:05 PM | #1077 |
Yep. Stuck in Athens 30 minutes from here... which, ironically, is where I was playing soccer this morning.
04-20-2014, 01:52 PM | #1078 |
I was looking at the TSB for Idle Stability, which refers to "engine idle RPM decrease / instability when the A/C system cycles off".
I have noticed that going on - actually dad noticed it the other day - but I don't consider it a major issue because I've had other cars that acted similar when the A/C cycles on/off. Anyway, the solution appears to be a reflash of the computer. So... My question is: Does the OFT flash make any change to the idle stability issue? Whether it does or not, it seems pointless to go get the reflash at the dealer if I'm just going to be flashing again with the OFT. Or maybe I just don't have any idea what I'm even asking... which is certainly possible. LOL. Thanks.
Tags |
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest |
Similar Threads | ||||
Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 03:48 AM |
Tablet Install | ThugNasty | Electronics | Audio | NAV | Infotainment | 4 | 04-13-2013 03:15 PM |
Blutooth OBD II and a 9.7 tablet.. | Scooby South | Electronics | Audio | NAV | Infotainment | 10 | 12-16-2012 08:11 PM |
7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 11:53 AM |
