12-25-2014, 05:31 PM | #1037 |
USMC
Drives: 2013 FR-S 6-MT Raven
We I'll probably be close to 500 hp. I know there are 17x9.5 wheels but not very many choices.
12-25-2014, 06:38 PM | #1038 | |
Grip>Drift
Drives: FRS
It's also about wide enough tires that don't have super tall sidewalls on 17s. Why do t you want 18s??
12-25-2014, 06:39 PM | #1039 |
USMC
Tires are less expensive. I don't know, I was under the impression that the bigger you go the more show it is and not as much performance.
12-26-2014, 01:45 AM | #1040 |
Drives: Raven FRS
wheel & tire noob
After reading through the entire thread I think I may get it or I've just confused myself lol. Figured, I'll just ask specifically what I'd like to know.
The wheels I like are 18x9.5 and come in both a +35 and +40 offset. I planned on lowering the car on TRD springs only. Will a square setup work w/ out any rubbing issues (mainly in the front, since that's where it seems the issue lies) or the need for other modifications like fender rolling, etc? If so, what would be the meatiest tires I could use (once again, I'd like a square setup instead of staggered) to go along w/ them? If the 9.5 is too wide for the front to fit w/ TRD springs as opposed to coils, what would be the best staggered setup I could get to work (wheel & tire)? Thanks for the help in advance & I apologize for the noob questions. It's been a long couple days lol. Loving everyone's pics & setups. The whole meaty tire look is absolutely amazing. |
12-26-2014, 02:01 AM | #1041 |
USMC
On the eibach pros I had there was less than half an inch between my wheel and strut. I have the xxr 535 17x8.25 on 245's.
12-26-2014, 03:35 PM | #1042 | ||
hi
Drives: 2013 BRZ Limited
Thanks guys, I'm running Fortune Auto 500's v4 with roller bearing upgrade. stock LCA's. |
The Following User Says Thank You to JEFFSTYLE For This Useful Post: | texasbound972 (12-26-2014) |
12-26-2014, 04:05 PM | #1043 |
Drives: 2014 Subaru BRZ
Will this fit stock? Also, I'm planning on getting Hotchkis springs to lower the car about an inch, hence why I have a 1inch drop. I just want to know, with the amount of poke, do I have to worry about the tire hitting the fender? It is a +20 offset wheel that I want.
12-26-2014, 04:55 PM | #1044 | |
I like to eat!
I have three square sets. Stock, 18x8s with 225s and 18x9.5s with 255s. I will probably try the staggered setup in 2015 for shits and grins at an autocross or two. |
The Following User Says Thank You to Pete156 For This Useful Post: | BRZ Stefan (12-27-2014) |
12-26-2014, 06:48 PM | #1046 |
Drives: 2JZ FRS
Even with 265 hankook rs3's my 525whp/415tq is absolutely useless. Also have a set of 255 nitto nt05's on 17x9 and they are useless as well. At 400whp, I could manage by peddling. I have Mickey Thompson et street radials for the rear for next season. I'm over the rolling burnout game lol
The Following User Says Thank You to spitfire481 For This Useful Post: | texasbound972 (12-26-2014) |
12-26-2014, 10:17 PM | #1048 |
Drives: 2JZ FRS
I had 265/35/18 on 18x9.5 et43 and a 275/35 should have cleared I believe. -2 camber front, -2.2 rear
12-27-2014, 09:05 AM | #1049 |
Grip>Drift
Drives: FRS
Yes, that's about the widest you can get with just suspension mods and no fender mods. Good luck!
12-27-2014, 02:02 PM | #1050 | |
Similar Threads | ||||
Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
