Old 12-09-2014, 10:03 AM   #1023
razo
Originally Posted by Jive Turkey View Post
you won't fit a 255. hell some meaty 245's won't even fit.
This mostly because of springs (and not coil overs), right?
razo is offline   Reply With Quote
Old 12-09-2014, 10:08 AM   #1024
razo
I currently run Michelin pilots 235/35 square with advan tc3 +45 and fits well.
EName:  ImageUploadedByTapatalk1418137728.586978.jpg
Size:  225.6 KBxcept I had to bend the rear brake line guards inward because on sharp turn it would rub agin the wheel slightly.
Old 12-09-2014, 10:18 AM   #1025
frslee
Just drive it
Drives: 13' FR-S
@razo I see 245 35 18
frslee is offline   Reply With Quote
The Following User Says Thank You to frslee For This Useful Post:
texasbound972 (12-21-2014)
Old 12-09-2014, 01:58 PM   #1026
razo
Oops sorry. You're correct
Old 12-09-2014, 07:09 PM   #1027
GT86NZID
GT86NZID's Avatar
Drives: GT86 '14, F10 '15 & AMG GTS '16
After some photoshoot session
GT86NZID is offline   Reply With Quote
The Following 2 Users Say Thank You to GT86NZID For This Useful Post:
JonAvalon (12-09-2014), Quentin (12-27-2014)
Old 12-13-2014, 09:00 PM   #1028
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
Would anyone happen to know if Falken ZE950 (245/45/17) on stock STI Series.Blue rims would fit on everything stock?
Without rubbing anything?
I have no mods on suspension, coils or anything. Just stock.
Any help would be appreciated!
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 12-13-2014, 09:33 PM   #1029
fx35s
Drives: 2013 Subaru BRZ
Question for you guys!
I think I read somewhere from the forum that Hankook Evo12 is thinner(more like narrower in width?) than comparable tires from other brands.. is that true?
I ordered a set of Gramlights 57c6 in 17x9 40+ and I wanted to know if I could fit 255/40/17 instead of 245/40/17 all around.
Any help or advices on proper tire fitment would be appreciated!
fx35s is offline   Reply With Quote
Old 12-13-2014, 10:37 PM   #1030
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
255s should fit at et 40. Will fit for sure if you have coils.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
fx35s (12-13-2014)
Old 12-13-2014, 11:35 PM   #1031
fx35s
Great! Thanks for the info. So I guess I'll join you guys on a meaty tire thread in the coming spring?! :P Can't wait.
The Following 2 Users Say Thank You to fx35s For This Useful Post:
BlaineWasHere (12-14-2014), Jive Turkey (12-15-2014)
Old 12-24-2014, 11:39 AM   #1032
JEFFSTYLE
hi
JEFFSTYLE's Avatar
Drives: 2013 BRZ Limited
Send a message via AIM to JEFFSTYLE
Rays Gram Lights 57xtreme 18x9.5 +40 powdercoated bronze
255/35/18 Dunlop Direzza zII
Fortune Auto 500 v4 Coilovers
Thanks for all the useful information in this thread! It really helped me make my tire choice!
JEFFSTYLE is offline   Reply With Quote
The Following User Says Thank You to JEFFSTYLE For This Useful Post:
fx35s (01-04-2015)
Old 12-24-2014, 10:42 PM   #1033
10Stars
Drives: 14 Subaru BRZ Limited WRB
Looks good man! I wanted to do that same setup.
What suspension do you have on?
10Stars is offline   Reply With Quote
The Following User Says Thank You to 10Stars For This Useful Post:
JEFFSTYLE (12-26-2014)
Old 12-24-2014, 10:47 PM   #1034
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
What's your setup as far as suspension? Also are you running LCA's?
texasbound972 is offline   Reply With Quote
The Following User Says Thank You to texasbound972 For This Useful Post:
Old 12-24-2014, 11:04 PM   #1035
texasbound972
USMC
Need some help. Want to run the widest tire possible in the rear without too much poke. I'm currently on KW V3's with a Vorschlag top hats. I also want to stick with 17" wheels. Car is currently getting a short block built by Crawford Performance and I didn't get my alignment done due to the engine blowing up the day after the coils were installed.
Old 12-25-2014, 05:03 PM   #1036
BlaineWasHere
Grip>Drift
Drives: FRS
You'll really need 18s to go 265/275 wide. 255s is pretty much as big as you can go on 17s.
What's your power goals? 255s all around might yield the best handling results regardless.
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
