08-11-2014, 04:25 PM | #981 |
Drives: 2014 Scion FRS (Ultramarine)
The Following User Says Thank You to solus For This Useful Post: | Sportsguy83 (08-11-2014) |
08-11-2014, 04:30 PM | #982 |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I have heard of no-gasket setups working well. And yes, the surfaces would need to be machined flat, and to a very fine roughness. I think it could work. The flange on the manifold is 1/2 inch, and the turbo itself is not really prone to warpage. If I have to take it apart again ( most likely will ), it may be something I try.
08-12-2014, 01:55 AM | #983 | |
Drives: 2013 Toyota 86 GT
I chose it over the Perrin due to the larger pipe diameter pipe (although I believe perrin now offers a three inch) and I've got several FI friends who have had issues with the Perrin not getting enough airflow through it. Not a problem so far with the Mishimoto. I have another CAI setup which is the Kansai intake scoop, basically a carbon Fibre HKS snorkel, with additional pieces to divert air to the scoop for the main grill. I was running this with modified stock air box (the whole front behind the larger scoop is cut away) with a cosworth panel filter. This works extremly well, but I was having some issues with my intake pipe coming off the turbo. My mechanics thought it was because that setup was too rigid so we're trying the mishimoto to give a little more flex and fixes the problem (plus it gives more room for my oil cooler fittings). |
The Following User Says Thank You to JD86 For This Useful Post: | Draco_PR23 (08-12-2014) |
08-12-2014, 11:24 AM | #984 |
Fiebru
Drives: Scion FR-S and Integra Type R
I am considering the Mishimoto CAI to give room to my oil cooler lines too but I am running Robispec radiator.
I know I don't have much space and it will probably be a tight fit or I might need to modify the radiator support.
Current Cars:
2017 White Platinum Ford Fiesta ST 2013 Raven Scion FR-S 2012 Spruce Mica Toyota Tacoma TRD Off-Road 2000 Phoenix Yellow Acura Integra Type R |
08-12-2014, 01:11 PM | #985 |
With the Mishimoto intake, does the mounting point interfere with the intercooler hardpipe in that area?
08-12-2014, 02:31 PM | #986 |
Ridge Racerrrrrrrrr
I kind of wonder if we will ever see a header upgrade with this kit, I do not know how they would make it fit, but things like flex joints would be nice..
The Following 2 Users Say Thank You to SkAsphalt For This Useful Post: | Draco_PR23 (08-12-2014), OICU812 (08-12-2014) |
08-12-2014, 03:25 PM | #987 |
I would also like to see 1/2 inch flanges that resist warping and better fit the available gaskets. IMHO, the port opening on the current flange is too large, making it troublesome to get a seal.
08-13-2014, 12:50 AM | #988 | |
Personally I was just going to bend the bracket to suit, or even cut it off as the pipe is wedged in so tight that I don't think it's going to go anywhere. I'm changing out my intercooler some time this week so when I have the bumper off I'll play around with how it's sitting. |
The Following User Says Thank You to JD86 For This Useful Post: | FrX (08-13-2014) |
08-14-2014, 01:34 PM | #989 |
BoostedBRZ
Drives: Turbo BRZ
I'm planning to get this kit within the next year, but budget is the biggest thing for me. lol just gotta save up.
Plus, I want Drift Office to tune my car but I'm from Chicago... Do you guys E-Tune? :/ I've heard way too many horror stories from all the tuning places in Chicago. |
08-16-2014, 10:36 PM | #990 |
Drives: 2014 Pearl White BRZ
Question:
Anyone running engine/tranny mounts with their AVO setup? I am tempted to try out the STI mounts - http://www.racecompengineering.com/i...-brz-fr-s.html The concern is that if we put anything in that goes lower than stock - the overpipe is going to start rattling again. I would need something that does not go lower at all - I am looking for more clearance underneath rather than less. Any help is appreciated! Thanks. Here's a look under the hood of my BRZ |
08-17-2014, 04:00 AM | #991 |
Living the dream
Drives: Fensport AVO Turbo GT86
I am using the TRD uprated mounts, as well as the 3" AVO turbo outlet and over pipes. No rattling / contact issues at all
08-17-2014, 08:27 PM | #992 |
08-18-2014, 12:58 AM | #993 |
08-18-2014, 10:17 AM | #994 |
I am using the Perrin mounts. The over-pipe (Private Label 2.5") contacted in one spot:
I had to "adjust" it some with a hammer to clearance it enough. |
Tags |
avo, avoturboworld |
Similar Threads | ||||
Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 04:26 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
