03-03-2012, 12:54 PM | #85 | |
Toyobaru Obsessed
Drives: 97' Civic Coupe
It's simple: cover your ass and don't bring your car in with shoddy work done to it and sure as hell don't bring it in with mods that would make the dealer think the problems are caused by your aftermarket parts. Lots of manufacturers have a list of approved oils and filters that they recommend be used. If you buy some autozone brand name oil filter and the thing cracks and your motor seizes, of course you may have an issue. If you use OEM filters or approved filters and something goes wrong, you have a case against the company who manufactured the part. Dealers don't have the time or resources to do investigations on specific cars, if they call you out and deny coverage it's likely they are bluffing and just don't wanna foot the cost. If this happens get Toyota or Subaru corporate involved and I guarantee your problems will be solved. As with anything it's all about being educated and making smart decisions. A lot of people don't want to mod their cars because of warranty coverage. That's fine...your loss. I for one make a good relationship with my dealers and make sure I am up front and honest about my intentions for the car. I recommend everyone do this. If you think you are going to be modding your car ask your salesman or the service manager their thoughts on this subject. If they downright tell you they have no tolerance for modifications then go to an other dealer. This is a tuner's car, it is unreasonable to think that people will be leaving them 100% stock and bringing them into the dealer for every tiny service.
03-03-2012, 01:22 PM | #86 | |
Drives: 2013 Subaru SWP BRZ Limited 6AT
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
03-03-2012, 01:31 PM | #87 | |
Drives: 2013 DZE/01 (sold for MX5 ND1)
It's completely subjective, but I enjoy the boxer rumble, just as I preferred the feel of my SV650's V-twin over parallel twins. |
03-03-2012, 03:12 PM | #88 |
Enjoy it, destroy it.
Drives: Datsun Racing Hen
Needs more power, better tires, and better suspension.
03-03-2012, 06:18 PM | #89 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
As a mechanic:
- I'm not worried about the length of the sway bar end links. That's fine, par for the course in this day and age. However... - I don't like where the swaybar itself is mounted. way over the subframe, behind the engine, most likely sandwitched against the body, shitty place to replace bushings. - I'm not fond of where they put the crank sensor. I mean come on, on the flywheel end? under the intake? REALLY!? That's the best you could come up with? - Stop talking about belt replacement people, it's a CHAIN. - Routing the oil pressure through, and mounting the filter on the timing cover is a novel idea, great for accessibility, should provide for a bit of passive cooling as the oil flows through a relatively colder part of the engine. - Quad electric cam phasers, glad to see this engine won't be as leaky as the EJ25 with it's plethora of oil pressure switches and vvt solenoids. - Looks like there's enough clearance between the valve covers and the body to change the plugs without too much hassle. as long as I can get my 1/4 drive air ratchet in there I'm happy. - I'm not a fan of two piece heads like that on a boxer, it's just one (two) more oil seal that can fail. - Hub/bearing units up front! Yay! (can't make out the rears) - Moderately easy front ball joints. I would have liked to see them bolted onto the control arms a la toyota, but still they're rather accessible, I'll have more than enough room to attack that top bolt with an impact wrench. - The accessory drive is kind of busy with a zillion idlers, but at least it's accessible, so no worries here. - Old school u joints on the driveshaft. Not really modern like current CV driveshafts, but cheaper to service. - That looks like the kind of (front) control arm bushing that likes to become unstuck from it's sleeve, but at least they look like they'll be easy to press out of the control arms without actually removing them from the car. etc... |
03-03-2012, 09:59 PM | #90 |
Drives: 1989 240sx- sold 2004-honda pilot
i want to take this put a seat and a steering wheel and make a crazy ass go-kart outta of it!
03-04-2012, 12:58 AM | #91 |
Seņor Member
Drives: 2005 Holden Monaro aka Pontiac GTO
Excellent thread... some very informative posts, so thanks to those folks contributing.
I just dig how low the engine sits. |
03-04-2012, 10:37 AM | #92 |
Drives: Civic Si sedan
03-04-2012, 10:51 AM | #93 | |
Drives: 2013 Firestorm FR-S
03-04-2012, 11:10 AM | #94 |
That Guy
Drives: 2013 asphalt FRS MT
hmmm, I just noticed the two holes in the crank pulley. They look like weight balance holes. That doesn't bode well for underdrive pulleys. (please don't take this as an opportunity to explain why I shouldn't use an underdrive pulley, that was descussed extensively in another thread)
RZNT4R, I was hoping the sway bar mounting brackets will be in the wheel well and not under the firewall.... Damn that's not much better. A ratcheting wrench should fit the clearance around the bolt, but it looks like the front frame will have to be lowered in order to replace the bar. |
03-04-2012, 02:23 PM | #95 | |
Registered you sir
Drives: 99 impreza coupe
The holes in the crankshaft are not there to make it lighter. They provide a passage of better oil distribution/lubrication. |
03-04-2012, 03:21 PM | #96 | |
Brillo, there isn't much to really go wrong from what I can see, from experience (I'm NOT the ultimate authority) I think subarus are rather reliable, more than mazdas and nissans anyway, the test is going to be assembly and sealing quality. That huge timing cover could be a huge leak waiting to happen if it's not assembled properly, and cam box and valve cover seals, because oil can't drain back into the pan by gravity, there are always small pools that remain in the low sides of the heads. The rest of the components look very ordinary/simple so everything should be fairly straightforwards. |
03-04-2012, 03:37 PM | #97 | |
That Guy
as for the rest of your post... |
03-04-2012, 05:42 PM | #98 |
Drives: Put Put
I'm certainly not a mechanic, and at most I know how to do an oil change... but from what you guys can see, is there any places that might seem prone to structural problem? Or for the most part, it seems pretty solid in the long run?
Similar Threads | ||||
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 856 | 06-14-2018 02:53 PM |
Subframe/Drivetrain Thoughts.... | TrackDog | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 11-10-2011 10:53 PM |
Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 08:55 AM |
Drivetrain experts! Name this car! :) | aspera | Engine, Exhaust, Transmission | 200 | 08-15-2010 11:41 PM |
