DIY (Do-It-Yourself) Guides For all DIYs. |
06-27-2022, 10:28 PM | #85 | |
Drives: Scion FR-S
Rattle problem solved!!!! |
07-22-2022, 02:44 PM | #86 |
A.K.A. Starlord
Drives: 2015 Series.Blue
Anyone know if there is any reason NOT to make a replacement piece out of aluminum so that I don't need to worry about taking it apart again later on down the road? Or do we know for a fact that the Hyundai one is more durable and won't have the same issue? Also, WTF is the purpose of this part anyway? Is there a reason the two halves don't directly connect? Is this for NVH reduction or what?
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
07-22-2022, 04:10 PM | #87 | |
chicken tonight
07-23-2022, 01:35 AM | #88 | |
Drives: MR2, Sliver BRZ
Always looking to tinker with something..
07-23-2022, 10:45 PM | #89 |
Drives: 2013 Brz
Thanks for the guide, it worked perfectly! That annoying rattle is finally gone.
08-06-2022, 02:01 PM | #90 | ||
A.K.A. Starlord
Apologies if this has already been stated, but I wanted to further add some information I hadn't seen mentioned:
OP provided the following link to the Hyundai part on Amazon: https://www.amazon.com/gp/product/B018WNMSBK The part number it claims to replace is 563152K000FFF. That IS, as far as I'm aware, the proper part number. If you read some of the comments on that listing, you'll find this very informative comment: Quote:
So I went to the dealership, and asked for the same part number. The part number is indeed the same, but this one has HNBR stamped on it, and feels MARKEDLY difference. It's actually softer and more flexible than the interim part. This is odd because the info above says that it has a higher durometer hardness than the original, so I'm wondering if the "first revision" (4P) part somehow wildly overcompensated and went too hard, and maybe that caused its own issues, and so they backed off to the HNBR version, which is softer than the 4P, but harder than the original? It's all a bit confusing. So I looked up the actual TSB: https://testing-public.carmd.com/Tsb...118786/5003566 In the TSB, it states: Quote:
I also want to point something else out that nobody seems to have mentioned, which is that this part does NOT fit quite as perfectly as a replacement as it sounds like it does. It does fit, but you have to force the motor back onto the assembly. That's because the center punch-out on the Hyundai part isn't as bit as the raised section in the steering shaft assembly, meaning the fins don't go all the way down and bottom out the way the factory part does. I guess everyone has just been forcing the two halves back together and calling it a day, but it's just not as perfect of a replacement part in terms of fitment as I had expected.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. Last edited by Stang70Fastback; 08-07-2022 at 06:40 PM. |
The Following User Says Thank You to Stang70Fastback For This Useful Post: | MJones_RB (01-18-2023) |
08-08-2022, 09:42 AM | #91 |
Drives: Brz WRB - Europe LHD
The official Subaru SB is this: SB22-036, issued on April, 2022.
Repair Kit part no. is 34595CA000 and contains 1 Rubber Spring, 1 Spacer, and 2 tightening bolts for Power Steering Motor, estimated price 21/25$ About other noises to column there is the SB SB22-024-1 that well explain how to solve.
The Following 6 Users Say Thank You to Trap63 For This Useful Post: | DocWalt (08-31-2022), ermax (05-03-2023), MJones_RB (01-18-2023), sato (01-09-2023), Ultramaroon (08-24-2022), whataboutbob (07-11-2023) |
08-08-2022, 12:53 PM | #92 |
A.K.A. Starlord
I actually wound up putting the OEM part back in. I HATED how the Hyundai part didn't fit properly.
08-24-2022, 09:02 PM | #93 | |
Drives: Asphalt FR-S
Sent from my Pixel 6 Pro using Tapatalk |
01-06-2023, 07:10 AM | #94 |
Drives: Toyota 86 GTS
Successful fix buttttt
Hi everyone,
Today I successfully replaced the EPS coupler and the rattle is gone. So what of an ordeal for me but super happy!!!! However, when I test drove I noticed the steering feel had changed in two ways: 1. Slightly but noticeably heavier 2. Steering wheel no longer goes back to centre. Ie a very slight turn to the right will keep that angle and not come back to centre. What could have possibly gone wrong, what can I check? Many many thanks!! |
01-09-2023, 04:17 PM | #95 |
Meow
Drives: GT86, Volvo 996
That's.... weird.
When I did mine, the car was immediately back to "normal" behavior. I did get an EPS warning light, but I put that down to the car stalling and being re-started during a turn (my car stalls very easily for the first few miles after an ECU reset), it turned off after 5-10 seconds and never came back . Steering feel and centering haven't changed a bit. I think you might either have placebo effect, or have done something wrong. Good luck in finding the cause if that issue! |
01-18-2023, 12:09 PM | #96 | |
Drives: '13 BRZ TLM Spec
Since this affects so many cars, and is a potential safety issue; binding steering, locked steering, etc. everyone that has experienced it should report it to the NHTSA: https://www.nhtsa.gov/report-a-safety-problem#index PS: The repair kit listed in the European Serice Bulletin shows in the U.S. parts system, it is orderable, but none are currently in stock in the U.S. P/N: 34595CA000 MSRP: $29.42
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
The Following User Says Thank You to Opie For This Useful Post: | Trap63 (01-21-2023) |
01-21-2023, 03:38 PM | #97 | |
In Europe no recall but only service bullettin.....maybe NHTSA will help us too...
01-22-2023, 05:05 PM | #98 |
Drives: 2013 frs red
Mine was replaced by a steering column expert. I don't think the bushing is anything special and may be used by Hyundai as well. Toyota parts guy told me my car didn't have eps then told me the eps wasn't serviceable. It's bad enough having a slow sports car but even worse having to deal with slow parts guys.
The Following User Says Thank You to Lantanafrs2 For This Useful Post: | Opie (01-25-2023) |
Similar Threads | ||||
Is building a motor necessary for FI on this motor? | Irace86.2.0 | Forced Induction | 44 | 02-27-2018 01:19 PM |
Shifter Rattle and Replacement | boredom.is.me | Issues | Warranty | Recalls / TSB | 19 | 04-27-2015 04:29 PM |
Seized motor!! What STX mods should I do while I have the motor out?? | BlaineWasHere | Tracking / Autocross / HPDE / Drifting | 27 | 12-11-2014 02:39 PM |
Silicone coupler or similar that is 4" I.D., and 1 inch Thick... (SOLVED) | Sportsguy83 | Engine, Exhaust, Transmission | 11 | 06-18-2014 11:29 PM |
