Old 02-04-2013, 10:29 AM   #85
Coaster
Coaster's Avatar
Drives: Civic
I found this on Yahoo for removing the springs safely without a spring compressor. Is it a good way?
"Loosen up the bolts that fasten the coil springs to the car.
There will be 2 to 4 bolts on the top and the bottom of each coil spring. Using a wrench or ratchet and extension, loosen the bolts at the top and the bottom. Do not remove the bolts yet. There is probably tension on the spring. Removing the bolts now could cause the spring to pop loose and cause you and/or your vehicle damage.
Raise the jack a little at a time while checking the coil springs.
The idea here is to raise your vehicle enough to take the pressure off of the coil springs. When you see the springs start to extend a little, this means that they are no longer holding weight up. The weight of the lower part of the vehicle is stretching the springs. You do not want to fully extend the springs because you do not want recoil when you remove the bolts. Now, let the jack back down until the springs appear to be neither compressed nor extended.
Very carefully remove the lower bolts from the coil springs.
The next step is to return underneath the vehicle and remove the lower bolts. Even if the spring recoils a little, it should not be a problem because the top bolts will still be holding it in place. When the lower bracket and bolts are removed, finish removing the top bolts. The spring should now be able to slide out and down from your vehicle. Remove one spring at a time and replace it before removing the other spring."
http://voices.yahoo.com/how-replace-...42.html?cat=27
Removing the spring is the trickiest part.
[ame="http://www.youtube.com/watch?feature=player_embedded&v=kY56ib3I-ew"]http://www.youtube.com/watch?feature=player_embedded&v=kY56ib3I-ew[/ame]
Coaster is offline   Reply With Quote
Old 02-04-2013, 11:00 AM   #86
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The springs in our cars are installed over the damper (aka a coilover), unlike that video. In this case you remove the damper and spring as one unit as then disassemble it. You can rent spring compressors for free in many auto parts stores.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-18-2013, 01:26 AM   #87
2013BRZ
2013BRZ's Avatar
Drives: 2013, Galaxy Blue Silica, Limited
Great guide!
Regarding the front installation, the cable clamps for the abs wiring harness in the beginning do not need prying out, you can unbuckle them with a flathead.
Had trouble getting the nut of the shock, a local shop did it cheap for me in 30 mins, otherwise, no problems encountered.
2013BRZ is offline   Reply With Quote
Old 02-28-2013, 02:30 PM   #88
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
Well, I didn't know about the "special tools" required and now my right rear strut is damaged. Looks like I spun the center shaft out. Is there any way to fix this or am I just screwed and need a new strut?
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
Old 03-03-2013, 11:44 AM   #89
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
If it's damaged you'll need new ones. They can't be repaired.
Fizz is offline   Reply With Quote
Old 03-03-2013, 12:53 PM   #90
cruzinbill
Drives: Argento 6spd FR-S
Nope, you are screwed
cruzinbill is offline   Reply With Quote
Old 03-04-2013, 01:29 PM   #91
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Yeah i figured.
Owner's Journal
Old 03-04-2013, 06:10 PM   #92
cruzinbill
Yeah i figured.
lemme know if you need help, not sure if youre a rookie in that area or not.
Old 03-04-2013, 10:22 PM   #93
Moshpit37
FR-S Owner!
Moshpit37's Avatar
That I am, good sir. But I'm a quick learner. It was a $115 mistake, but one I don't expect to be making again. I bought a Kobalt Xtreme Axcess socket/ratchet set so I can break the nuts loose properly this time. Now I'm just waiting for my new strut to come in to the dealership.
Owner's Journal
Old 03-05-2013, 12:37 AM   #94
cruzinbill
Could have been a strut upgrade opportunity lol, well maybe. How much did it end up being for an oem one?
nvm, guess that was the 115. ya not really worth doing all 4 then.
Old 03-05-2013, 02:11 AM   #95
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Yeah I wish I was able to upgrade all 4, but just can't justify that kind of cash right now. Trying to get ready for autocross and I need a helmet and strut braces first.
Owner's Journal
Old 03-23-2013, 04:36 PM   #96
sinigang_guy
sinigang_guy's Avatar
Drives: argento frs; 90 mustang gt
currently stuck with removing the rear strut. i removed the 2 bolts before step 42, but i cant shake the strut loose from the lower control arm.
any thoughts?
sinigang_guy is offline   Reply With Quote
Old 03-23-2013, 11:43 PM   #97
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
You need to force the wheel hub down. I did it with two planks of wood arranged in such a way as to not bend disk brake backing plate.
86•BRZ is offline   Reply With Quote
Old 03-25-2013, 03:32 PM   #98
philstar
philstar's Avatar
Drives: Argento FR-S
Is it possible to just buy the specialty service tools (SST) somewhere?
If not I guess I will go with getting the pass through socket set and crowsfoot sockets/wrench to torque properly.
philstar is offline   Reply With Quote
Replacing the Scion FR-S seats bloomy116 Scion FR-S / Toyota 86 GT86 General Forum 36 11-09-2012 12:41 PM
Installing TRD Parts / Locating a good shop Re~Mix Engine, Exhaust, Transmission 9 06-12-2012 12:05 PM
T1R Coil-over suspension AJ PwR Brakes, Suspension, Chassis 33 05-29-2012 10:07 PM
Handling: Camber Attainable with Struts. Your Experiences? skeeler Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-09-2011 04:07 PM
