Old 03-28-2018, 08:52 PM   #85
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by Xevuhtess7 View Post
I just installed my kit along with a Ptuning washer fluid reservoir and did not have any clearance problems between the two.
Thanks for the information, I'll be able to recommend that to others!
We are working on 2017+ specific mounting as well for those that have the facelifted bumpers.
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
KoreanJesus (04-05-2019)
Old 03-28-2018, 10:38 PM   #86
churchx
churchx's Avatar
Drives: 2014 GT86
VerusEric: how about rather work on something like in TF kit with inlets behind main rad? Such should work no matter what redesign of bumper/foglights these cars may get / with aftermarket bumpers too. (thus if you do, would be nice to see kit with hoses routed in way that wouldn't require modifications to washer reservoir)
The Following 3 Users Say Thank You to churchx For This Useful Post:
Harvie1031 (03-29-2018), JDM4E (03-29-2018), tehShirt (03-29-2018)
Old 01-12-2019, 03:29 PM   #87
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
@VerusEric
Have you guys had a chance to test fit the duct kit to and 2017+ BRZ with the Brembo Performance Pack?
Old 03-04-2019, 01:26 PM   #88
VerusEric
VerusEric's Avatar
Originally Posted by Kiske View Post
@VerusEric
We have not yet but do not see any reason it should not fit. The AP Racing brakes seem to be the thickest rotors to date and they have fit with them. The Stoptech calipers appear to be quite large as well and no issues with fitment on those as well.
Thanks,
Eric
Old 04-10-2019, 08:40 PM   #89
Prax
Drives: 2017 BRZ Inazuma Edition
The dust/heat shield is too small for the stock Brembo brake kit rotors. The plate should cover the full diameter of the rotor. Edit: The effect should still be good, and the cooling should still be effective.
Sent from my Pixel 2 XL using Tapatalk
Prax is offline   Reply With Quote
Old 04-10-2019, 11:38 PM   #90
churchx
churchx's Avatar
Drives: 2014 GT86
The plate should guide most of air to inside of rotor instead of blowing from one side of rotor. Imho even with it not covering whole diameter of rotor it still will do the job by the looks in pic.
The Following User Says Thank You to churchx For This Useful Post:
VerusEric (06-15-2019)
Old 04-18-2019, 11:57 PM   #91
Prax
Originally Posted by JDKane527 View Post
Is the reservoir replaced or modified?
Replaced. An Amsoil oil container can easily be modified to fit. Recommend rotating it 90 degrees from what I have in the image. Uses all grommets, pump, and filler neck.
The Following User Says Thank You to Prax For This Useful Post:
Old 04-19-2019, 12:25 AM   #92
Prax
@VerusEric
Works great on my 2017 with Brembos.
Couple recommendations though:
- use bigger washers for the duct mount, the washers that came in the kit didn't fit over the bolts and the bigger washers hold the duct in more sturdy
- fibreglass mesh works great
- if you relocated your horn for an oil cooler you're gonna have a bad time as the bolt will prevent the duct from getting closer towards the front, you can use the rivet tool bit as a spacer
- I still have to mess with fitment and turn radius, but it seems to me that it works better if you can get the duct to mount further towards the front of the car, as opposed to it fitting with the mount angled backwards (could be wrong, car is still in stands until Saturday)
Old 06-15-2019, 10:51 AM   #93
Evan55
Drives: 06 Exige, 17 BRZ PP
has the mounting been worked out with a plug & play solution for 2017+ BRZs?
Evan55 is offline   Reply With Quote
Old 06-15-2019, 11:42 AM   #94
VerusEric
VerusEric's Avatar
Thanks for the feedback! Awesome job on the retrofitting for washer fluid!
Yes, each kit comes with 2013-2016 and 2017+ fog light mounting at this time. We revised the kits as of 2019 so unless you purchase one from 2018 and earlier, it should come with both.
Thanks,
Eric
Evan55 (06-16-2019)
Old 01-28-2021, 12:05 AM   #95
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
For those with the washer fluid reservoir concern:
-There are two units on the market that can be purchased already. If you'd like another option
Hi Eric and all,
Does the Vortech Windshield Washer Fluid Reservoir clear the brake duct? The PT tuning one is out of stock.
Thanks!
https://www.ft86club.com/forums/show...&postcount=129
botbs is offline   Reply With Quote
Old 01-28-2021, 08:09 AM   #96
VerusEric
VerusEric's Avatar
Originally Posted by botbs View Post
Hi Eric and all,
Thanks!
I can't see where this installs on the link. I would assume it would work with the brake cooling kit though as anything that small and easily accessible would have to be pretty high up in the fender or in the engine bay, which won't interfere with the brake hose.
Thanks,
Eric
botbs (01-28-2021)
Old 01-28-2021, 03:04 PM   #97
86TOYO2k17
Drives: 2017 toyota 86
This is super easy to install can install anywhere and dropped 7lbs (mostly from less fluid)
https://www.chasebays.com/products/c...SABEgJfvfD_BwE
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
botbs (02-01-2021)
Old 02-01-2021, 01:54 AM   #98
botbs
botbs's Avatar
Oh no, I read this too late. I just purchased the PTuning one.
Verus Engineering High Performance Radiator - Gauging Interest VerusEric Engine, Exhaust, Transmission 90 07-08-2023 07:43 AM
Verus Engineering Air Oil Separator - Information and Release VerusEric Engine, Exhaust, Transmission 127 07-08-2023 07:40 AM
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 09:15 AM
Verus Engineering Billet Transmission Beta Tester Run VerusEric Engine, Exhaust, Transmission 62 04-26-2020 01:44 PM
Verus Engineering Carbon Thermoplastic Splitter Components VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 35 11-26-2017 05:23 AM
