11-12-2015, 01:49 AM | #953 |
Drives: 2013 Scion FRS
I don't think anyone here would endorse cruising at 7300rpm though.
ScreamingElectron - SnakeShit |
The Following User Says Thank You to riboyster For This Useful Post: | justinco (11-12-2015) |
11-12-2015, 02:11 AM | #954 | |
The Following User Says Thank You to steve99 For This Useful Post: | justinco (11-12-2015) |
11-12-2015, 02:23 AM | #955 |
Hey Steve, could you take a look at todays charts when you get a chance? Updated the post with my dyno chart on it with the new links. Kinda scared. I don't think my car is detecting knock or lowering IAM.
11-12-2015, 02:41 AM | #956 |
Drives: JAWS
How many miles do you have on the latest tune? The car won't register FLKC or lower IAM for a while after flashing. Also, why are you scared? Your AFR looks pretty spot on and LTFT is in good ranges on that recent 2nd gear wot run.
11-12-2015, 02:50 AM | #957 |
Plugged it in while driving yesterday at some point and got a CEL, had to clear. So I'm thinking it isn't yet listening for knocks. Scared because my torque curve is acting different than it did yesterday (specifically around 7k)
Yesterday = Blue Today = Red. I think I need to wait for it to pull some timing again before I can accurately log stuff.
11-12-2015, 03:18 AM | #958 | |
Drives: JAWS
Also, are you doing these logs in the same exact place at similar temperatures? I wouldn't read into a virtual dyno too much. The datalog is whats important. |
11-12-2015, 03:20 AM | #959 |
Sounds good. I've already got my corrected timing .bin from yesterday's results ready. Just wanted more data before I commit to a flash
11-12-2015, 03:43 AM | #960 |
Drives: UK GT86
Unless you're using Virtual Dyno on the same road under similar conditions it is, essentially, useless. I note that one of your pulls is labelled as downhill so that immediately renders it unreliable (in VD at least).
@JB86'd what do you mean that FLKC isn't immediately active? AFAIK so long as you're in the FLKC region it should be active, FBKC should also be the same. As far as I know there is no learning or similar, although I could be wrong.
.: Stealth 86 :.
11-12-2015, 04:29 AM | #961 |
Same spot on the road, same conditions every time. Barely downhill, and I've adjusted the dyno to compensate.
11-12-2015, 08:11 AM | #962 | |
new log look good no knock good ltft afr good. maybe you had bit of bad fuel last time ?? but all ok now |
11-12-2015, 11:43 AM | #963 | |
Drives: FR-S Whiteout
Good luck!
Intent > Content
cowardice is the mother of cruelty. |
11-12-2015, 01:53 PM | #964 | |
btr.life
Drives: 2022 GR86
Thanks.
11-12-2015, 02:40 PM | #965 |
Drives: JAWS
@Kodename47 That's my bad, I meant IAM will not drop immediately after, although FLKC may still be active and learning.
11-13-2015, 02:46 AM | #966 |
Not sure that it's learning or active. The only indication I have that it is active is that it's transmitting a single value for the duration. It won't move on my trouble areas yet, so there's definitely nothing to learn.
Similar Threads | ||||
OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 12:29 AM |
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 10:21 PM |
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 04:43 AM |
OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
