08-14-2020, 10:24 PM | #939 |
Drives: Q5 + BRZ + M796
I had ordered a 75mm pulley from Harrop USA. They didn't have the belts. I got an invoice for wire transfers, but did a credit card transaction over the phone with Chris. I like the Gatorback style belts, so I am going to see if I can find a 4060960 version and see if it'll fit. Technically, it is only a 5mm difference in length.
Just for reference: I found stock numbers for Continental OE/Elite belts in 4060960 (96.0''), 4060965 (96.5''), 4060967 (96.7''), 4060969 (96.9'') and 4060970 (97.0''). No other in between sizes. Looks like the Gatorback (old Goodyear) and Elite models might be phasing out.
08-21-2020, 12:24 AM | #940 | |
Drives: 2015 BRZ CWP
75mm pulley 6PK2445 85mm pulley 6PK2453 90mm pulley 6PK2465 |
The Following User Says Thank You to byun For This Useful Post: | Irace86.2.0 (08-21-2020) |
08-21-2020, 09:10 PM | #941 |
I got a 2440 one. 5mm difference. I’ll have to see if it works on the 75mm pulley just as good.
08-23-2020, 08:30 PM | #942 |
Drives: 2015 brz
What’s the best oil cooler for the kit besides the Harrop oil cooler?
08-23-2020, 10:06 PM | #943 |
Define best
08-24-2020, 09:29 AM | #944 | |
I found a set of non fog light plastic grills, and cut away all the plastic between the "grills" for max air flow, and then vented behind the cooler into the front wheel well. I've also fitted a small electric fan (wired into the water cooling fan circuit) to help during lower speeds. |
08-26-2020, 05:53 AM | #945 |
Drives: 2015 BRZ Limited
Guys! It's 50 state emissions legal now! They just dropped the news on their instagram. I can't find any other reference to it being CARB approved though. I imagine websites and other media will be updated shortly.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
The Following 2 Users Say Thank You to FunnyGopher For This Useful Post: | Irace86.2.0 (08-26-2020), strat61caster (08-26-2020) |
08-26-2020, 09:08 AM | #946 |
Don’t kid! Really?!?
08-26-2020, 09:10 AM | #947 |
The 2440mm fits fine with room to spare on the 75mm.
08-26-2020, 09:27 AM | #948 |
08-26-2020, 11:40 AM | #949 | |
Drives: 2017 BRZ w/PP
what headers and exhaust do you have on it? this is a similar setup that im thinking about going to next year with power id be looking for. also can it be turned for 93 for places that dont have sheetz? |
08-26-2020, 12:48 PM | #950 | |
85mm is probably the limits on 93. You could do 75mm, but I don’t know how safe it would be or how much overhead there would be for pulling timing. There would be minimal gains changing the pulleys from 85mm to 75mm on 93, so any tuning for 93 would only be there in case you were stranded without E85. A boost controller would be better, IMO, than having to change pulleys or having to pull large amounts of timing, but there is still extra heat generated from over-spinning the blower.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | byun (08-27-2020) |
08-26-2020, 01:20 PM | #951 | |
not sure how i missed that post. but thank you. i have e85 around me the issue is when i head eat there is only 93. i guess once i get my bonus i can always give them a call and see what they have to say |
The Following User Says Thank You to Breadman For This Useful Post: | Irace86.2.0 (08-26-2020) |
08-26-2020, 08:05 PM | #952 | |
Drives: RX-7 / BRZ
It will cost more but ecutek cam controll the factory bypass valve. You could have a low boost map that operates bleeding boost. Or your can opt for a 3 port and bleed boost through port #3. There is also a way of doing this with a boost controller or even easy pro's gauge controller which os specifically for that. https://easyperformance.com/products...ost-controller
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
The Following 2 Users Say Thank You to Kiske For This Useful Post: | Breadman (08-27-2020), Irace86.2.0 (08-26-2020) |
Similar Threads | ||||
HKS Supercharger owners thread | wbradley | Forced Induction | 1048 | 10-12-2023 08:03 PM |
JDL turbo kit owners thread | yomny | Forced Induction | 1346 | 08-29-2023 11:07 PM |
P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 02:50 PM |
**Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
