08-19-2015, 11:35 PM | #9269 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Lol did something similar inadvertently Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
08-19-2015, 11:50 PM | #9270 |
Wow! Try this map
Wow! Try this and tell me it isn't just a fluke. I took a 5 minute drive and tried to make it stutter, hard throttle, then let off fast. Then I tried the low-load in manual mode and 1st gear I went up to 5000 and let off, no stutter, and it's fast and loud as hell. Try this with my AVCS tune changes, it seemed to be just the right amount of boost.
The Following 2 Users Say Thank You to KoolBRZ For This Useful Post: | LucidMomentum (08-20-2015), Sojhinn (08-20-2015) |
08-20-2015, 11:57 AM | #9271 | |
No Money, No Problems
Man you guys are making the wait for the procede unbearable. I plan to put the order in this weekend, and if I'm lucky I can get it installed before my trip to Pismo on the 29th. I also have a trip to LA labor day weekend and a Dyno appointment for next month, so I know I'll have it before those, at least. In the meantime, I'm having way to much fun putting cars in my rear view mirror more quickly because I have the torque to do so at the low end now. Last edited by LucidMomentum; 08-20-2015 at 01:56 PM. |
The Following User Says Thank You to LucidMomentum For This Useful Post: | TM (08-20-2015) |
08-20-2015, 02:44 PM | #9272 | |
I'll load things today or tonight. Sent from my iPhone using Tapatalk
08-20-2015, 06:09 PM | #9273 |
Drives: 2016 Raven FR-S
@fenton Any chance you could post the updated wait list? Might I also suggest a Google Docs file we can just pop in to check on?
Thanks! |
08-20-2015, 06:45 PM | #9274 |
There WAS a torque dip when i drove my AT with ESC and Procede. The torque dip is now gone. Only someone else with an AT would understand this, but this new map makes driving in "D" fun! Passing people on the freeway is soooo easy. I know it gets better mileage in manual mode, but who cares about mileage when they're having fun. Using boost below 3500 rpms makes the cost of the procede totally worth it, So what if the ESC is working all the time. It's spinning all the time anyway. The only time I'm not boosting is when I'm slowing down. Now Sport mode is a real hoot. I'll need to put my Michelin PSS's on the back if I'm going to use Sport mode much.
The Following 2 Users Say Thank You to KoolBRZ For This Useful Post: | LucidMomentum (08-20-2015), Shinobu's Smile (08-21-2015) |
08-20-2015, 07:32 PM | #9275 | |
Ugh forgot my laptop at work. Delaying things for a day. Sent from my iPhone using Tapatalk
08-20-2015, 07:34 PM | #9276 | |
Any chance you take a video of the voltmeter? I'm curious how the hell you are keeping charge up. And I mean this in a crazy can't believe... I'm jelly mode. Sent from my iPhone using Tapatalk
08-20-2015, 11:55 PM | #9277 | |
Drives: 86 A00I
I can say though: the voltmeter doesn't show any reduction at what I'm guessing is values below -50 or thereabouts in the procede map, I assume in that low load area the recharge can match the depletion. I'm not using any aux charger either. |
The Following User Says Thank You to dtek For This Useful Post: | Gums (08-21-2015) |
08-21-2015, 12:02 AM | #9278 | |
Full throttle Electric Supercharger Build Thread
Which cells because to me it should be a good quarter of the lower left area. Haven't tried it though... Sent from my iPhone using Tapatalk
08-21-2015, 12:21 AM | #9279 | |
Drives: 86 A00I
08-21-2015, 12:24 AM | #9280 | |
Crazy... @Robftss can you chime in? Because to me this is a significant change from our normal operating procedures. Sent from my iPhone using Tapatalk
08-21-2015, 12:26 AM | #9281 |
Look at the image a couple posts above. You've got a range like 5 cells by 5 cells before it starts to drain. I got the aux charger robftss posted a link to. I didn't get it to recharge quicker so much as to heal abused batteries. @dtek is right about the volts not dropping. I'm getting better fuel economy too. Make sure if you run this map that you calibrate the throttle. If it's not calibrated you might not be getting full boost, or worse yet, might have trouble slowing down.
If I say yes, will that make you think I understand?
08-21-2015, 12:31 AM | #9282 | |
With the mapping are you getting more of an exponential curve or is it diagonal in nature in the movement of the blue square. Sent from my iPhone using Tapatalk
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
