07-16-2014, 02:24 PM | #911 |
Drives: 2013 "AVO Orange" FR-S
Illustration of the hose routing with our breather tank:
The left port on intake manifold is where the line goes to the OEM pcv - an upgraded pcv needs to be fitted in that line. |
07-16-2014, 02:31 PM | #912 | |
Negative Mass
Drives: Orange Metallic AVO Turbo GT86 6MT
Based on Paul's reply as well I assume you meant the hose I pictured. I will look into acquiring and installing a check valve. Sent from my iPhone using Tapatalk
Build thread for my Lovely Lady.
07-16-2014, 02:36 PM | #913 |
I Love custom Turbo kits
Drives: Limited BRZ
Yes, I meant the hose you pictured.
07-16-2014, 03:54 PM | #914 |
NASA SpecE30 Racer
Personally, I would install the check valve in the hose that goes from the back of the intake manifold to the center of your Crawford AOS right under Perf part of Performance. Then you can leave the line going to the PCV alone.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
The Following User Says Thank You to King Tut For This Useful Post: | Sportsguy83 (07-16-2014) |
07-16-2014, 04:10 PM | #915 |
Drives: 2013 GBS BRZ Limited
Exactly what I was trying to describe to him earlier. My question is where to put the oil reservoir breather. AVO's diagram does not show it, supporting my theory that they run it straight to the oil cap. Should I attempt to do something along those lines, or tee it into the crank breather the Crawford already uses as a drain back? Will that drain enough to support the overflow AVO is warning us about under extended high rpm conditions?
07-16-2014, 04:14 PM | #916 | ||
Drives: Limited BRZ
07-17-2014, 05:27 PM | #917 |
Negative Mass
I can try. Something tells me that run is going to end up being made entirely of hose clamps. I don't know how big check valves usually are but it's only 5" of PCV hose sticking on to a couple of bungs that are probably 1" each.
07-17-2014, 05:31 PM | #918 |
They're quite small, just make sure they're pointed with flow being allowed to go from PCV to Intake Manifold
The Following User Says Thank You to protpibe For This Useful Post: | nataku (07-17-2014) |
07-17-2014, 05:47 PM | #919 | |
Negative Mass
Is that the kinda thing my local auto parts store is gonna have lying around? Browsing the internet gives me all kinds of check valves unrelated to vacuum system in a car. Sent from my iPhone using Tapatalk
07-17-2014, 05:55 PM | #920 |
Depends on the auto parts store I guess lol. I just ordered it online because it's easier
http://www.ebay.ca/itm/3-8-10mm-One-...vxp=mtr&_uhb=1
07-17-2014, 05:56 PM | #921 | |
Negative Mass
07-17-2014, 05:57 PM | #922 |
I'm pretty sure 3/8" is the right size, you may want to double check before ordering
07-17-2014, 05:58 PM | #923 |
Negative Mass
When I picked up additional PCV hose at NAPA they said it was 1/2" when I showed them what came with the Crawford. With a tight clamp the 1/8" difference might not matter but I'll try to find 1/2" first.
07-17-2014, 06:01 PM | #924 |
I just ordered 2 of each to be on the safe side lol
Tags |
avo, avoturboworld |
Similar Threads | ||||
Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 04:26 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
