Old 04-02-2021, 11:48 AM   #9087
ThucP
Does anyone know what tool is needed to remove the oil dip stick to replace the oil?
ThucP is offline   Reply With Quote
Old 04-02-2021, 12:43 PM   #9088
ls1ac
ls1ac's Avatar
Allen wrench, I do not use the included dip stick after the first time. Find a flat spot and get a good reading when full. Then use a small screw driver all the way in and mark it. then go home and put the car where you usually store it. Use the screw driver again and see if the level has changed. If it has then remark the screw driver and you have a dipstick that will work at home and is easy to use.
The Following User Says Thank You to ls1ac For This Useful Post:
NIKOLA (01-19-2022)
Old 04-02-2021, 10:15 PM   #9089
jflogerzi
jflogerzi's Avatar
Also don't over tighten the dip stick.... Ask me how I know
2013 Series 10 FRS #553
Old 04-03-2021, 02:35 AM   #9090
Ads
Drives: 86
How did you end up repairing it and how did it hold up? Also, what were your main reasons for returning to NA in the end?
Ads is offline   Reply With Quote
Old 04-14-2021, 09:23 PM   #9091
Tormenta
Drives: Fr-s
hello FRS team,
Here is my fully built FA20 with turbo kit (partial see link for details), with ECUTEK down and mid pipes etc.
If in Houston LMK instead of shipping we can meet and help install it.
https://www.ebay.com/itm/164618578080
thank you
Tormenta is offline   Reply With Quote
Old 04-18-2021, 03:54 AM   #9092
kev0
Drives: '14
@86TOYO2k17 You got some sort of catch can/AOS installed? Can I see how you set yours up? I know it's a bit different with automatic trannies so I want to see yours as a reference. TIA
kev0 is offline   Reply With Quote
Old 04-27-2021, 01:57 AM   #9093
Noodle86
Drives: 2015 RS1
anyone know where to get replacement parts for the 210, I've been searching and I just don't have the time to read thru 650 pages just mainly lookin for intake tube. Also is there a gasket between the supercharger and manifold? I purchased this and unsure why they were separated in the first place cause its also missing the bolts but that's easy enough to figure out.
Noodle86 is offline   Reply With Quote
Old 04-27-2021, 03:20 AM   #9094
kev0
Drives: '14
I have a spare intake tube I can sell ya. I replaced it cause I suspected it to be leaking but it wasn't the issue. I bought a new one from Sprintex for $130 shipped but was too lazy to swap it back out and return it. PM me if you want it for much less than what I paid for, of course.
Also there are 4 O-rings that go between the SC and the manifold. The sizes are BS144 O-Ring (63.17 ID x 2.62 CS). I know this because I had to replace mine back then as well and that's what the Sprintex rep told me.
Just look for em online and make sure they can withstand high temperatures.
The Following User Says Thank You to kev0 For This Useful Post:
Noodle86 (04-27-2021)
Old 04-27-2021, 03:26 AM   #9095
Noodle86
Drives: 2015 RS1
awesome thanks a lot! will look into it tomorrow trying to get this all pieced together properly and just been reading thru the threads and taking pictures lol
Old 05-07-2021, 12:43 PM   #9096
cthulhu87
Drives: 2014 White FR-S
Intercooler brackets
Is there anywhere I can buy a set of brackets for mounting the intercooler that comes with the 210 intercooled kit? I've got a used kit on the way missing the brackets, and if I can avoid having to get something made myself that would be great.
Edit: I've got the brackets handled, but now. I'm confused about where I can get the rectangular o-ring type seals for between the SC manifold and the head. I mistakenly thought it would use the same type of seal as the oem intake manifold. Now I've ordered what I thought would be the right thing from Jon bond performance, but what I received was round o-rings. Are there supposed to stretch into the rounded rectangular channels on the bottom of the SC manifold?
cthulhu87 is offline   Reply With Quote
Old 05-19-2021, 02:24 PM   #9097
Finsky
Drives: BRZ 2014
Hey, does anyone know where I can find an IAT relocation plate ? Abbey Motorsport and Nameless don't make them anymore ...
Thanks
Finsky is offline   Reply With Quote
Old 05-24-2021, 08:22 AM   #9098
sqd
sqd's Avatar
Drives: '13 SWP GT86
What oil are you guys using for your superchargers?
Since my unit was serviced by Jon Bond I got their "Tribodyn SC oil" in it. But I don't have enough left to replace my oil, and wondering if adding a different type of oil is even a good idea?
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 05-24-2021, 10:17 PM   #9099
Ads
Drives: 86
From the Sprintex manual:
Drain and replace supercharger oil every 50,000 km or 30,000 miles. Use a quality fully synthetic SAE 75W-90 gear oil, specifications: API GL5, MT1 such as: Redline 75W90 NS gear oil (factory fill), Castrol Syntrax Universal Plus 75W-90, Lucas synthetic SAE 75W-90 gear oil or equivalent. It is critical not to overfill the supercharger gearbox as damage will occur. Fill with exactly 157 millilitres or 5.31 us fluid ounces.
Check the oil level with the dipstick provided in the supercharger assembly. Tighten the dipstick fully before checking the oil level.
http://www.sprintex.com.au/wp-conten...1000-v1r40.pdf
As long as it is fully synthetic and matches the specs required, you shouldn't have any issue with any reputable brand of your choice.
The Following User Says Thank You to Ads For This Useful Post:
sqd (05-25-2021)
Old 05-25-2021, 04:41 AM   #9100
kev0
Drives: '14
You guys just stick a syringe and tubing into your SC until you hit the bottom and then suck everything out, right? I need to change mine and I'm nervous about doing it for the first time lol.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
