07-16-2014, 08:16 AM | #897 |
Drives: dark grey metallic Toyota 86 MT
Got the AVO kit with their breather tank installed by FusionR and MFB. try to PM him.
http://www.ft86club.com/forums/showp...24&postcount=8
07-16-2014, 08:23 AM | #898 | |
Drives: 2013 GBS BRZ Limited
07-16-2014, 10:24 AM | #899 |
Negative Mass
Drives: Orange Metallic AVO Turbo GT86 6MT
I installed a Crawford AOS the same way it gets installed on an N/A car... Did I miss a complication somewhere?
Build thread for my Lovely Lady.
07-16-2014, 10:30 AM | #900 |
You can kinda see mine in this pic. 1 catch can fits in between the factory pcv line with a 1 way check valve. The other can has 2 inlets, one for the stock breather and the other for the oil reservoir breather. It routes back to the intake before the turbo
07-16-2014, 11:57 AM | #901 |
If you do get a hold of the instructions for the AVO Breather tank would you mind forwarding them to me? I either lost mine or didn't get them and have had no luck emailing AVO or my vendor. I got the base NA breather tank instructions from my vendor but not the Turbo version.
Its been sitting on the shelf for a while waiting to be installed lol. |
07-16-2014, 12:11 PM | #902 | |
Drives: 2013 "AVO Orange" FR-S
07-16-2014, 01:01 PM | #903 |
So very similar to the routing I described for my setup. But where does your PCV go if you run the other can to the turbo inlet?
07-16-2014, 01:17 PM | #904 | |
The changes I'm making are using a metal PCV valve, but leaving that can routing alone, adding a 2mmHG opening, 1psi closing check valve on the line between the can and the intake manifold, and either running the AVO oil reservoir breather to a tee in the factory breather to can line or straight to the oil cap. This is the part I'm still trying to figure out. |
07-16-2014, 01:32 PM | #905 | |
Negative Mass
Again maybe I'm missing something but the routing of the PCV lines for the AOS just places it in the middle of the OEM system. I don't understand how it would have the effect you're referring to. The only change I can see is I'm feeding the filtered air directly into the throttle body instead of the turbo. The oil is still going to have to drain to the crankcase regardless of how you route the rest of the system. Please do enlighten me though. If I'm going to cause problems for my oiling system I'd like to fix it. Sent from my iPhone using Tapatalk
07-16-2014, 01:44 PM | #906 | |
- the stock pcv valve leaks - not having one means that every connection between the manifold and the stock pcv (the can itself) is a potential boost leak |
07-16-2014, 01:52 PM | #907 |
It goes back to the intake manifold.
07-16-2014, 01:53 PM | #908 | |
My main goal in posting in this thread was to attempt to get some help from AVO, but they seem to be ignoring me, despite responding to another member's post which quoted my request for assistance. @AVOturboworld please help. |
07-16-2014, 02:00 PM | #909 |
Negative Mass
I was incorrect. I'm feeding to the start of the intake which is obviously better than what I thought. That's the drain to the crankcase correct? Other side has hose going down under A/C compressor. Is this where I should put the check valve or the hose in the first picture? Thanks dudes. Sent from my iPhone using Tapatalk
07-16-2014, 02:18 PM | #910 |
I Love custom Turbo kits
Drives: Limited BRZ
Yes, that is the PCV and you need to install a check valve to prevent pressurizing crank.
Tags |
avo, avoturboworld |
Similar Threads | ||||
Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 04:26 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
