Old 12-20-2016, 07:11 PM   #883
Heat Sinker
Drives: 2016 FR-S
Very new to tuning. To much to grasp in a few days. Can someone confirm this is correct.
I will be puting in a 2.75" Perrin Intake this weekend in my 16 FR-S.
I used these numbers provided by the forum
And placed them in the Rom program.
The saved it as a new file back into the OTS file where the original Stage 1 93 Tune was found.
*To change car to the new tune do I need to return to stock first?
Thank you in advance
Sent from my SM-G930P using Tapatalk
Heat Sinker is offline   Reply With Quote
Old 12-20-2016, 11:15 PM   #884
steve99
looks ok
no you don't need to flash to stock first just flash the new tune. previous tune will be erased then new one written.
that perrin scaling will get you in the ball park but your likely going to need to log and tweak it a bit.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
choiboie (12-23-2016), Heat Sinker (12-21-2016)
Old 12-23-2016, 02:05 AM   #885
choiboie
Drives: 2013 Fr-S UltraMarine
U may need to scale your maf with and aftermarket intake
choiboie is offline   Reply With Quote
Old 12-30-2016, 01:33 PM   #886
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
I'm running Stage 1 on 93, is it right that my gas mileage went to chit? I'm doing 16/23 now on good days...
carsebuco is offline   Reply With Quote
Old 12-30-2016, 03:47 PM   #887
alxtheoreo
alxtheoreo's Avatar
How long are your commutes & do you have any additional engine mods (or heavier wheels & tires)?
I can tell you from my experience, my MPG went down once I started shorter commutes to work. I used to average 27MPG, now I average 19MPG on stg2-93 UEL (was 22MPG on stg1-93).
Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
Old 12-30-2016, 03:55 PM   #888
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Yes, short commutes as usual. I used to get the standard 21/30 before OFT, with no other mods. Not that I'm gonna stop using it, but if there's a way to improve it, why not?
Old 12-30-2016, 04:10 PM   #889
alxtheoreo
alxtheoreo's Avatar
True. It may be the cause of colder temps & winter blend gasoline.
Someone else should chime in...
The Following User Says Thank You to alxtheoreo For This Useful Post:
carsebuco (12-31-2016)
Old 12-30-2016, 05:06 PM   #890
churchx
churchx's Avatar
Drives: 2014 GT86
Winter MPG may also be affected by higher rolling resistance of winter tires. And of course with sum of all those factors.
Old 12-31-2016, 03:55 AM   #891
Basti
Basti's Avatar
Umm guys, I didn't find anything on this elsewhere so here goes :
Thinking of reducing tire diameters to a size which go below the state permitted tolerances and thus gonna have to adjust the speedo reading. Can I do that using oft?
Basti is offline   Reply With Quote
Old 12-31-2016, 09:13 AM   #892
churchx
churchx's Avatar
Drives: 2014 GT86
IIRC no. But then again speedo lies on about the all new cars since 199# something. With smaller wheels it will just lie more. Why not simply drive with some navigation app and see real speed by gps at few common speeds you drive on public roads & then just remember those few numbers? (eg. highway speed/city speed/common speed reduce speed).
Old 01-03-2017, 11:55 AM   #893
renfield90
The Stig's German cousin
I started getting poorer gas mileage once I installed the header and tune. You have to realize the OEM tune was designed to hit fuel economy targets first (don't forget CAFE) and then safely maximize power at the given fuel economy. The OFT tunes unlock additional power without regard for fuel economy.
There's a thread on here where people were modifying their OFT tunes to try and extract better economy while keeping some of the gains if that's important to you. But remember, you're fighting basic physics - an ICE makes power by igniting fuel, so all else being equal it makes more power when more fuel is used, and vice versa.
Old 01-03-2017, 12:08 PM   #894
Nah
Drives: 2013 Scion Frs 6mt
I still get 20 city and I'm full 2.5 uel header back exhaust. If you're getting poor mpg it's most likely due to a fueling error aka LTFT... scale your MAF and watch mpg go up. If you wanna take it a step further play with VVT and maximize VE. Every car is different and once you get the MAF curve correct. You're good.
Nah is offline   Reply With Quote
Old 01-03-2017, 10:49 PM   #895
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
What was the solution to this?
well nothing, as the OFT unit got DROPPED on the ground during the process, and is no longer working right... i guess i'll need to get a new one.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 01-03-2017, 11:09 PM   #896
steve99
Just replace screen
http://www.ft86club.com/forums/showthread.php?t=111532
screen available here
http://www.ft86club.com/forums/showp...0&postcount=17
Teseo (01-03-2017)
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
