Old 12-31-2014, 09:00 PM   #841
knandez17
Drives: Subaru BRZ LTD GBS
Just got the same issue as pl1ght installing a Borla uel - comes back after clear. Ill follow up with the shop who installed the exhaust system and see what happened with the 02 sensors
knandez17 is offline   Reply With Quote
Old 01-01-2015, 12:09 AM   #842
steve99
which cel codes ??
Old 01-01-2015, 12:31 AM   #843
knandez17
Same codes , 37 and 31.
Old 01-08-2015, 10:54 PM   #844
Tromatic
Originally Posted by Wayno View Post
Shittons:
Copy the throttle map from MT - this will save you fuel on E85
Add the soft rev limit same as MT
Use the paddles
Is there a thread on this?
Thanks! ETA: Every new tune is better than the last, good stuff. I was actually taken by surprise at how hard it pulled above 5-ish. Can't wait to try the E85.
Tromatic is offline   Reply With Quote
Old 01-17-2015, 03:26 PM   #845
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Are v2.xx Gulf spec (Middle East) maps out yet?
Downloaded the ZIP, didn't see 'em.
If not, can the v1.59 files be used instead?
Just curious. I like that these maps are based on the factory tune with the DI 'fix'. Had an ecutek tune and an OEM tune earlier that didn't have the fix and kept getting CELs on the track.
No issue since the dealer reflash so it's kind of a big deal for me.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 01-21-2015, 05:36 PM   #846
Tromatic
The 2.063 ROM is sweet!
Old 01-21-2015, 10:44 PM   #847
steve99
what is your rom calid ?? like ZA1JA01G
the v2xx tunes supported more rom types thaj v1.5x
Old 01-22-2015, 12:15 AM   #848
luv85
Drives: Grey GT
Not to be rude or anything.. but do OFT sales have any support service? Because I'm not getting any replies from these guys..
luv85 is offline   Reply With Quote
Old 01-22-2015, 03:07 AM   #849
steve99
email sales@openflashperformance.com
dont use personal message PM to shiv on this forum think he has it turned off as he get to many
or if all else fails ring on phone or gmail phone call free to usa
luv85 (01-22-2015)
Old 01-29-2015, 05:56 PM   #850
Aussie Tuner
Drives: GT86
I am sorry if this is not in the right thread.
I am a bit confused of this parameter setting.
The above A/F Learning is from a tune I am looking at
The one below is from the OEM tune.
Is this a mistake or is this done for some reason that is not obvious to me.
Aussie Tuner is offline   Reply With Quote
Old 01-29-2015, 06:04 PM   #851
mad_sb
Drives: 2013 Asphalt FR-S
are you using the correct deffs? the v2 maps require the v2 defs or the table data will not line up correctly.
That aside I think I have seen those settings vary from stock rom to stock rom (the limits on the left).
Could aslo be a fat finger in the def, assuming those two maps your comparing are using two different definitions.
Old 01-29-2015, 06:13 PM   #852
Aussie Tuner
Drives: GT86
The tunes are based on the A01I and the definitions used are the same in both
One is the factory A01I the other is also A01I based tune, so the definition files should be the same.
Makes no sense to me that one value the upper limit is negative etc.
EDIT: Yep that is what it was the definition file.....
I was told that the A01 was the same as in 1.5 set, clearly its not
Thanks for your help
Old 01-29-2015, 06:43 PM   #853
Aussie Tuner
Drives: GT86
I have updated my definition, but I note that in all of the 2.06 releases that I have, the definition for 700I is not included.
In Aus we have cars with this map, can any one help with a copy please.
Old 01-29-2015, 07:10 PM   #854
steve99
700I is a rearly old rom, looks like it was never defined by the romraider guys. They wont want to waste their time defining it either.
just flash the 700I car with A01I its the latest compatable rom for that car. Dont use an E00I its only for latest my2015 cars
if the guy has an oft then send the 700I rom to openflash guys and they will do up an oft compatable rom and def. This will actually be an A01I rom calid hacked to look like a 700I and a matching calid adjusted def.
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
