12-15-2011, 12:03 AM | #71 | |
Rocket Surgeon
Drives: PSM GGA OMG
If you're asking what I think you're asking it's just trigonometry and it's included wheel rate. If your spring is 10deg from vertical, the effective spring rate at the lower attachment point would be k*cos(10deg). The same thing would apply to damper forces as well. |
12-15-2011, 01:14 PM | #72 | |
Kuruma Otaku
I've been reading a bit and some of the frequency formulas deal with the following: You start with 'coil rate', the basic spring. Then this is adjusted based on how it is mounted/difference from 90 degrees. Then this 'fitted rate' is adjusted based on leverage for the 'wheel rate'. As for the damping forces, if the setup is a coil-over damper then doesn't the damper just 'see' the coil rate since it is in-line with the spring? Like you use the wheel rate for your frequency, but determine your damping based on the coil rate?
Because titanium. |
12-15-2011, 02:11 PM | #73 | |
Rocket Surgeon
Drives: PSM GGA OMG
Yes but the damping ratio is also based on the sprung mass, which (from the damper's perspective) will either be amplified or reduced if the motion ratio is not 1:1. |
12-15-2011, 03:26 PM | #74 |
Kuruma Otaku
Argh, again with the learning... Thanks, though.
Edit: May be giving up on trying to understand damping... Went through Old Greg's post and don't think anything sunk in. Also been re-reading the chapter on damping in a suspension book I have. Book also contains two handy things. First is Penske's flow-chart for damping adjustments. Second is Koni's process for shock setup. So damping solution for me: Leave it stock for a while, save up for some good Koni ($$$$$) double adjustable rear dampers/front strut inserts, give Koni all info needed to recommend base valving, make strut housing to fit, install, follow Koni's setup advice, when at track follow Penske's flowchart for handling issue resolution. So the wallet will be hurting, not the brain...
Because titanium. Last edited by Dimman; 12-18-2011 at 03:05 PM. Reason: Edit... |
03-23-2012, 08:04 PM | #75 | |
Kuruma Otaku
As for the camber change, that depends on the geometry. With the struts in the front, this can lose negative camber as it travels, so resisting roll can help. But with the double-wishbone (really mutli-link with an upper wishbone) rears depending on the lengths of the upper and lower arcs the car can gain negative camber as it travels. I'm sure complicated tuning is required to optimize the roll rate to available grip and there may be tradeoffs between loading a tire (which increase its grip, up to a point) and optimizing its contact patch. As well as balancing load and contact patch side to side, front to rear, in steady state and transient movements, changing mass (passengers, decreasing fuel load). deflections of bushings, control arms (Old Greg's educating me about E there...), tires, chassis etc... Ouch... Partly why suspension has the 'black art' bit associated with its tuning. Though I get the impression, Serial, that once you've looked at a few diagrams and done some calculations you'll have a vastly better understanding than myself. Stupid physics... Are you still considering Formula SAE?
Because titanium. |
03-23-2012, 08:23 PM | #76 |
Drives: '06 AM V8V Coupe
If you have the same track but lower center of gravity yea the "leverage" does decrease because you are slightly reducing the distance from the center of mass to the tires, but with typical cars I imagine what has a bigger effect is the angle at which the lateral forces are acting on the "lever".
Haha yea, I haven't gotten around to checking out FSAE but I will sometime hopefully. |
03-23-2012, 08:27 PM | #77 | |
Kuruma Otaku
Edit: F1 High-Nose Anti-dive diagram
Because titanium. Last edited by Dimman; 03-23-2012 at 08:41 PM. Reason: Anti-dive pic |
03-24-2012, 11:49 AM | #78 |
Details coming first on facebook, big new thread coming soon here:
- drew |
03-26-2012, 12:53 PM | #80 |
i'm sorry, what?
Drives: Canada
with regards to using adjustable dampers,
the reason you want adjustable dampers is if you are going to change your balance (weight removal, weight addition, weight shifting (such as battery relocation) etc. because during movement the front of your car will oscillate at a different rate than the rear of your car. Tuning this difference between front and rear oscillation is the nut of the problem. Street cars are tuned for comfort so that even though the front wheels hit a bump before the rear wheels at regular speeds (40-80km/h), the whole chassis oscillates in unison. When you modify your car by changing chassis weight and/or weight distribution and slap on after-market springs, you are modifying your balance. While "suspension kit" manufacturers (hopefully) do the background work for you, they tailor to some middle level feeling of "good." If this is not enough for you, then suggest looking into adjustable dampers. If you are bad at math and prefer visual ques, you can and purchase some 3 way (2 way could also work) accelerometers and put one in your trunk, and one somewhere under your hood. then drive around and look at the outputs to see how damper tuning affects your car. if you're hardcore enough (i've never done it) is to attach these accelerometers right on to your control arms at all 4 wheels and record data that way, but that's money and headache.
03-26-2012, 03:24 PM | #81 |
Kuruma Otaku
^ My understanding is that the adjusters can be used to alter the speed of weight transfer (but not ultimate weight transfer). And thus how a car reacts at corner entry and exit can be modified with shock changes.
I'm checking google for Penske's flow chart on double adjusters but not having much luck... (no personal experience, though...) Edit: My god, technical shock info overload: Start with this: http://www.penskeshocks.com/files/Adjustable_Manual.pdf Tons more here: http://www.penskeshocks.com/Downloads.php (I was just looking for a damn flowchart...)
Because titanium. Last edited by Dimman; 03-26-2012 at 03:29 PM. Reason: Edit |
03-27-2012, 01:02 AM | #82 | |
Drives: 4 Wheels Auto
http://www.ft86club.com/forums/showp...&postcount=263, lowering COG has some effect to the weight transfer. Not really much. Using the BRZ/FR-S as an example, roughly speaking, if raising the COG by 50 mm (about 2 inch), the increase in weight transfer under 1.00 G braking (to the front) is about 54 lb out of 388.2 lb, compared with 334.5 lb with the current 450 mm COG. This is considering the whole car, not per wheel. I am not sure the typical spring rate is for any given car. 500lb/in? This is the number I got from Wiki. Can someone enlighten me on this? The formula is described in many places. But the thing is, the weight transfer is proportional to the height of COG, and weight, but inverse proportional to the wheelbase. If you want to reduce weight transfer: lower weight, lower COG or increase wheelbase and you can achieve the goal. However, it all depends on where you did to see how much effect it can be. |
03-27-2012, 01:46 AM | #83 | |
03-27-2012, 04:27 AM | #84 | ||
Rocket Surgeon
Drives: PSM GGA OMG
If you want to talk about weight transfer in terms of torque, it's the inertial force (mass x acceleration) acting on the CG with the pivot at ground level. Total steady-state weight transfer is completely independent of the suspension geometry and spring/damper rates. If you replaced the springs/dampers with solid steel bars you'd get the same amount of weight transfer (CG movement due to body roll happens, but it's mostly negligible in anything other than trucks/SUVs/etc). Roll Stiffness is a function of roll moment (acceleration x mass x distance between cg and roll axis) and roll rate ((wheel rate+ARB) x track width). It's usually defined as Roll Gradient (degrees/g). "Anti" geometry comes into it by reducing the distance between the CG and roll axis by raising the roll axis rather than lowering the CG. The more important aspect of roll center height is it's effect on roll inertia (roll inertia about the CG + sprung mass * distance between CG and the roll axis squared). With a higher roll center, even with identical roll gradient, you get a higher roll frequency which means sharper response (which is better, up to a point). There are a couple of downsides to a higher roll center. It puts more load into the suspensions members, causes increased jacking and reduces the response of the suspension to imperfections in the road (reduces grip). The exact same stuff applies longitudinally as well, but with pitch axis height instead. As for camber change, you lose as many degrees as the chassis rolls by, plus whatever you gain or lose through suspension travel. Higher roll stiffness will help in this regard, but only up to a point. Sooner or later you will reach a point where the grip you gain by further reducing camber loss is outweighed by the loss of grip caused by stiffer springs/bars. Where that point is is a function of sprung/unsprung weight ratio and how crappy the road surface is. Not to mention the most important factor... How much the vehicle weighs. Out of curiosity, what school do you go to? |
Similar Threads | ||||
D-4S Thread | WingsofWar | Engine, Exhaust, Transmission | 85 | 03-31-2020 04:25 PM |
AZ bs thread | sfwg | Southwest | 185 | 09-11-2012 03:11 AM |
Intoxicated thread | #87 | Off-Topic Lounge [WARNING: NO POLITICS] | 46 | 04-27-2012 07:17 PM |
The Diet Thread | Maxim | Scion FR-S / Toyota 86 GT86 General Forum | 126 | 06-14-2011 05:47 AM |
The Music Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 03-28-2011 11:35 AM |
