Old 08-08-2012, 05:09 PM   #71
bneale
bneale's Avatar
Drives: Scion FR-S
Originally Posted by 636 View Post
I run that setup, but heel toeing is still very possible. Train yourself to use two fingers on the left side of the controller. Clutch with your index, and brake with your middle finger, it's weird at first, but you'll learn fast with it.
Forget this setup. It's too stupid to use 2 fingers. I have a way better setup. I just can't remember the layout settings right now because I'm at work. But this is what you do. Thank me later because I discovered this myself one day trying to learn clutch.
This is the layout I use
LT - BRAKE
RT - GAS
X - Change View
Y - Look Backwards
B - Hand Brake
A - Clutch
RB - Shift Down (as in from 2->1)
LB - Shift Up (from 1->2)
The beauty behind this system is it allows you to downshift while braking without having to use 2 fingers. It takes time to get used too, but this system allows you to always keep your finger on the brake without having to use 2 fingers for clutch and brake.
It will take you about an hour to get used to shifting using RB and LB. But its totally worth it once you make the switch. Easy as pie.
bneale
bneale is offline   Reply With Quote
Old 08-08-2012, 05:41 PM   #72
bneale
bneale's Avatar
Drives: Scion FR-S
See my setup! You won't need extra fingers anymore!
bneale
Old 08-08-2012, 05:47 PM   #73
Allch Chcar
Drives: N/A
bneale
I've been using the Forza3 config, X for upshift, and A for downshift. LB is clutch and I usually have my index on the clutch so I can healtoe. But I'm pretty sure I mucked up the palm of my left hand with the F3 setup. If I press on my left palm in a certain spot I get a shooting pain.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 08-08-2012, 06:19 PM   #74
bneale
bneale's Avatar
Drives: Scion FR-S
I used to try and use that setup but I was never happy with it. So one day I spent some time with the Forza control schemes until I found this one.
It's perfect. You can't beat my controller config. I converted both Dragonjet, Fiat, and Rocket.
bneale
The Following User Says Thank You to bneale For This Useful Post:
Allch Chcar (08-08-2012)
Old 08-09-2012, 01:06 PM   #75
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I'm down to race with you guys also. Have you thought about trying an open B class FRS race one night to see what people can come up with?
I'm also thinking about starting a multiple make non-spec series for b class but also with power, weight and a few other restrictions. I used to run a decently successful FWD Touring cup and I was thinking about doing that again with RWD sports cars...
Any interest?
Old 08-09-2012, 09:33 PM   #76
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
bneale
Did 4 laps round the ring last night and let me say you have converted me too. By the end of lap 1 I was used to it, by the end of lap 4 I'm very comfortable with it. Definitely the best set up I've tried so far.
Flat Black VW is offline   Reply With Quote
Old 08-11-2012, 09:05 AM   #77
stedk
stedk's Avatar
Drives: GT86 Dark Grey AT
bneale: I sent you my FR. I am not sure I will be able to join you when you race ( time difference, I'm from Italy ) but I guess it could be nice to compare lap times. Thank you & ciao.
stedk is offline   Reply With Quote
Old 08-11-2012, 12:57 PM   #78
BlaineWasHere
Grip>Drift
Drives: FRS
I have a B500 set-up that has 6.4 handling and 6.7 accel and weighs 2295lbs that is pretty easy to drive hard. If you overdrive it slightly it has a little oversteer built in but if you way overdrive it'll push. I also have a similar set-up that rotates a little better but is also a little less stable on the edge.
LMK if you guys want to check it out, my GT is the same as my screen name here. If there are some pro-tuners out there I wouldn't mind some feedback as well.
Old 08-11-2012, 01:31 PM   #79
MiguelAE86
Drives: NB Miata
Is this tied to the FT86Club Club that many many many members are part of (including myself)? It would be amazing to have an Ft86Club race!
BTW, xMiguelAE86x add me in!
MiguelAE86 is offline   Reply With Quote
Old 08-12-2012, 02:48 PM   #80
Allch Chcar
Drives: N/A
We race 3-4am CET. If you are awake, join us!
The only member representing [f86c] is me. The club was down to 8 member when last I checked. I'm not sure but I believe I sent you a friend request.
-Allch Chcar
Old 08-13-2012, 03:50 PM   #81
MiguelAE86
Drives: NB Miata
The club is 10-members strong! that's definitely enough to get a club-race going.
I think this should be restructured so that anyone taking part in the club-race should actually be IN the f86c Forza Club!
Old 08-14-2012, 01:01 AM   #82
Allch Chcar
Drives: N/A
bneale
Dragonjet
BigHairyApe
Rocket Hampsters
FearoftheFiat
Allch Chcar
636
Need to add:
(Name - Gamertag)
M-17 - Victorious17
Warman - Warman31337
Cheddar - sunny 360K
Flat Black VW - WCRoss133
BlaineWasHere - (No Gamertag)
stedk - (No Gamertag)
MiguelAE86 - xMiguelAE86x
-Allch Chcar
Old 08-14-2012, 01:49 AM   #83
Allch Chcar
Drives: N/A
So we need to know who's going to be there Thursday night. If you haven't sent a friend request to Bneale or Dragonjet, please do so. Also be sure to send me one too if I haven't added you.
We're racing Motegi full.
If you are going to be a few minutes late we can wait 15 minutes but you need to message Bneale or Dragonjet.
-Allch Chcar
The Following User Says Thank You to Allch Chcar For This Useful Post:
MiguelAE86 (08-14-2012)
Old 08-14-2012, 12:35 PM   #84
M-17
Ninja Cat Mod
M-17's Avatar
I talked to Dragonjet, I'm in for Thursday's race.
And @Allch Chcar, my GT is Victorious17.
Anyway, I don't know how I'll do, but I'll try to put some more time in so I can gain more experience with Forza and hopefully keep up with the rest of you.
The Following User Says Thank You to M-17 For This Useful Post:
Allch Chcar (08-14-2012)
Scion FR-S Release Series 1.0 CSOCSO Scion FR-S / Toyota 86 GT86 General Forum 26 04-16-2014 07:16 PM
Forza 4 WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 142 10-21-2012 09:45 PM
Will Forza 4 get the FR-S and/or BRZ? cassidy0998 Other Vehicles & General Automotive Discussions 52 08-01-2012 07:56 PM
Enjuku Racing - HKS Hi-Power Spec-L Exhaust System - Scion FR-S / Subaru BR-Z Enjuku Racing Engine, Exhaust, Bolt-Ons 0 07-20-2012 12:10 PM
GT5 vs Forza 4 Dragonitti Other Vehicles & General Automotive Discussions 600 03-14-2012 03:11 PM
