04-03-2016, 06:27 PM | #71 |
Drives: BRZ + Ducati M796
Does this nut that everyone has issues with, is it a regular nut or a locknut? Anyone tried a locknut?
I installed a TRD short shifter on my Supra back in the day (mkiv model but 5speed) and there was either slop or it became too tight when over tightening the nut. It also had a tendancy to get loose unless it was tightened down tight. Cant recall if loctite was used but maybe a nylong lock nut and some nylon washers or something could work. |
04-04-2016, 10:26 AM | #72 | |
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
04-04-2016, 04:49 PM | #73 |
Did anybody else have difficulty getting the shift control shaft thru the adapter? I saw that there is a tiny o-ring inside the adapter where the shaft connects. I had to use channel locks to get it all the way thru to get the retaining clip on. I don't think I could get it off if I ever had to uninstall it.
04-05-2016, 01:03 AM | #74 | |
The other option could be a crush washer to keep tension. I'm not sure until I pick up this kit. |
04-05-2016, 09:41 AM | #75 | |
04-05-2016, 11:21 AM | #76 |
04-05-2016, 01:12 PM | #77 |
Yeah, it's quite difficult to jam an allen socket in there.
04-05-2016, 02:21 PM | #78 |
04-05-2016, 02:36 PM | #79 |
Could you grind down the sides of the hex bolt enough to fit a wrench on there? I know the tunnel doesn't allow much room for a bigger bolt, especially when reverse is engaged.
04-05-2016, 06:44 PM | #80 |
So a combination of crush-washer and a switch out to a hex head bolt would probably be the best choice for this issue? I'm planning to install this kit this weekend, but I really don't want to have to get back under this thing after it's done. I'd planned to use red locktite, but the thought of trying to back that bolt out if I ever needed to go back to stock makes that a scary proposition.
04-05-2016, 07:41 PM | #81 | |
chicken tonight
And who the hell specifies a socket head cap screw with a 7 mm hex? That just adds insult to injury.
04-05-2016, 11:41 PM | #82 |
There is not a whole lot of choice. It is either this or Kartboy and that one is much more expensive and seems to have vibrating issues.
04-05-2016, 11:44 PM | #83 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I will say it is worth it. The kartboy is nice, but the TRD was cheaper honestly.
04-05-2016, 11:48 PM | #84 | |
Similar Threads | ||||
trd quick shifter ? vibration noise | Pcharliep04 | Issues | Warranty | Recalls / TSB | 5 | 08-01-2014 02:42 PM |
TRD Short Shifter Quick Shifter Scion FRS | hirollaz | Transmission and Driveline | 3 | 04-15-2014 01:24 AM |
TRD quick shifter (sold) | lovebeingbleu98 | Transmission and Driveline | 13 | 04-09-2014 06:25 PM |
trd quick shifter? | tjohnson104 | Engine, Exhaust, Transmission | 6 | 01-26-2014 02:37 PM |
Quick Release or Quick Lock Steering Wheel and Theft defense too? | 1086 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-24-2014 04:50 PM |
