09-24-2014, 05:57 AM | #71 |
Drives: FT86, BMW 5, JZA80, Porsche 986S
Motec CDI mounting brackets made, made some cosmetic changes to the Racer X control arms, thermo-fans wired in, test fitted the hood to make sure clearances were all ok, and plumbed the BOV in.
600hp Built FA20 Widebody Toyota 86/FRS.. build thread
09-24-2014, 08:08 AM | #72 |
Drives: 2013 Whiteout FR-S
This build is SICK! I've been wanting to do this since I first read about the 86..
Question: Why not route the piping thru the hood latch beam to make the piping shorter? Essentially having both FMIC end tanks pointing up instead of out the sides? Wouldn't that shorten the charge piping, allowing even quicker spool? (Not like you really need that..) How is this being tuned? MoTec? |
09-24-2014, 10:41 AM | #73 | |
I just like the traditional cross flow intercooler look, plus I think it flows better this way. Again, not that it really matters, spool wont be an issue
09-24-2014, 10:57 AM | #74 |
Drives: '15 Raven FRS
Lord have mercy, I'm in love.
09-24-2014, 05:49 PM | #75 |
No Money, No Problems
This is just mental. Sub'd.
09-24-2014, 06:57 PM | #76 |
Quick question, where's the maf sensor? Did u delete it using the motec?
09-24-2014, 07:16 PM | #77 | |
We have IAT under the supercharger before the runners and a 4 bar MAP on the runners to the cyls on the left hand side of the car.
09-24-2014, 07:28 PM | #78 |
I'm at 370kw and I still have my stock maf. I do have a 4 bar map as well, I'm just wondering if the motec allows you to delete the sensor
09-24-2014, 08:14 PM | #79 | |
I am not a tuner, but I assume we all the important data will come from the MAP
09-24-2014, 08:26 PM | #80 |
Drives: Built FA20
How much money do you have in this so far??
09-24-2014, 08:28 PM | #81 |
Most tuners run the car off the map over a certain boost level, I'm just curious if they found a way to delete it entirely cause that could help drivability
09-24-2014, 08:36 PM | #82 |
Drives: 2015 Series.Blue BRZ
I think he's said he's on over $100k already. Aus dollars.
09-24-2014, 08:48 PM | #83 |
09-24-2014, 09:02 PM | #84 |
Tags |
streetfx, supercharged, twincharged, wtf86 |
Similar Threads | ||||
JET86 Twincharged complete build !INSANE! | jet86 | Member's Car Journals | 97 | 08-05-2016 12:15 PM |
Dezoris | FR-S Build | Supercharged & More | Dezoris | Member's Car Journals | 329 | 03-21-2016 04:48 PM |
Supercharged Rocket Bunny Widebody Conversion Build Thread | RWDRIFT | Member's Car Journals | 278 | 01-06-2014 12:12 AM |
Supercharged Forgestar Rocket Bunny Widebody Scion FR-S | RWDRIFT | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 102 | 03-27-2013 06:48 AM |
Supercharged GT 86/FR-S/86 vs. Turbocharged BRZ | switchlanez | Scion FR-S / Toyota 86 GT86 General Forum | 61 | 12-20-2011 11:16 AM |
