Old 03-24-2018, 07:01 PM   #8163
NIKOLA
NIKOLA's Avatar
Drives: 2013 Scion FR-S in Ultramarine
Just curious..... I haven't done a zero to 60 run yet since my area is so full of cops hiding around every corner. However, I was wondering what kind of zero to 60 times has any one gotten after installing their 210 Sprintex super charger? 80mm, 75mm or 69mm pulley? Stock exhaust or full exhaust upgrade?
Thanks.....
Currently driving a Sprintex Supercharged FR-S in Ultramarine with an Invidia N1 Catback with Catless Front Pipe, Invidia Over Pipe, Injen Catless 4:1 EL Headers, Perrin Aluminum Drive Pulley & Driveshaft Shop Aluminum Driveshaft. Also, looking to upgrade wheels someday to Enkei PF01's (17x8's).
NIKOLA is offline   Reply With Quote
The Following User Says Thank You to NIKOLA For This Useful Post:
Joeyb860 (03-26-2018)
Old 03-26-2018, 02:13 AM   #8164
Joeyb860
Joeyb860's Avatar
Drives: 2017 860 SPRINTEK
Thanks.....
I have the 69mm pulley uel no cat 2.5 mm over pipe non cat front pipe with TRD exhaust, cold air intake and stage 2 meth water kit and in 5 consecutive runs 3 were 4.2 one was 4 flat and one was 4.3.
Joeyb860 is offline   Reply With Quote
The Following User Says Thank You to Joeyb860 For This Useful Post:
NIKOLA (03-27-2018)
Old 03-28-2018, 11:56 PM   #8165
ZZJ
ZZJ's Avatar
Drives: 2017 Toyota 86
Just had mine installed today. 210 w/o intercooler on 2017 86.
ZZJ is offline   Reply With Quote
The Following User Says Thank You to ZZJ For This Useful Post:
riboyster (03-29-2018)
Old 03-29-2018, 02:13 PM   #8166
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
There is a lot to learn on this thread hahah
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 04-10-2018, 10:54 AM   #8167
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by moto-mike View Post
We've actually sold quite a few of these, he's certainly not the first. While it may sound counter-intuitive, with e85 the intake temps just really don't matter, and the lack of flow restriction on the supercharge is a big deal. Oh, and the noise
Even when we're talking 100 degrees ambient temperature and 90% humidity?
Old 05-17-2018, 08:07 AM   #8168
J1Avs
Drives: 2018 BRZ tS
Any fitment issues on your 2017? I have a 2018 tS, and the Sprintex 210 w/o intercooler is the running contender right now. Looking for something simple and safe, for just a bit more power without putting too much strain on the motor. It's my DD (when I do actually have to drive to work), and will likely AutoX it like 2-3 times per season.
If anyone else has any insight, please feel free to chime in?
Thanks!
J1Avs is offline   Reply With Quote
Old 05-17-2018, 05:45 PM   #8169
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Thanks!
I've had mine for years and still running strong with the 70mm pulley. I check the supercharger oil once a month and put a little in each time to keep it topped off. Remember to level the supercharger when checking the oil level.
stockysnail is offline   Reply With Quote
The Following User Says Thank You to stockysnail For This Useful Post:
J1Avs (05-17-2018)
Old 05-17-2018, 05:56 PM   #8170
Flint natural
Drives: Subaru brz
i am currently debating whether or not to buy one of these kits from another forum member. The kit was originally listed to have around 10k miles on it but upon further research on the specific supercharger(and all of the previous owners) i have learned that it has closer to 50k miles on it. I was just wondering what the lifespan of these things are, and if it would be a bad idea to buy a kit with so many miles on it.
Flint natural is offline   Reply With Quote
Old 05-24-2018, 02:16 PM   #8171
snk828
snk828's Avatar
Drives: raven FRS
How many miles you have on your kits ?
snk828 is offline   Reply With Quote
Old 05-24-2018, 07:53 PM   #8172
stockysnail
Just the tip
I would guess 55k-60k miles. The kit had 5k maybe from the previous owner since I got it used from a local guy's car.
Old 05-24-2018, 10:43 PM   #8173
snk828
snk828's Avatar
Drives: raven FRS
No issue whatsoever for 60K miles , it sounds very reliable runing 210 kits with stock motor. Custom tune ?
Old 05-25-2018, 12:11 PM   #8174
stockysnail
Just the tip
I had the valve break off from the mount. It's plastic to metal and the plastic decided to come off. It was an easy fix doing it myself and the part was around $150-200. The second item is the intercooler reservoir tends to spit out a little fluid when running it hard. I'm not sure if the cap just can't handle the pressure or heat or if the washer inside the lid should be revised. I just put a little fluid about once a month at the same time I put a little oil in the supercharger. My belts tend to squeak until the engine has warmed up all the way. When I put a new belt on the squeak goes away for a few weeks then slowly comes back. Haven't figure this minor annoyance out yet. I pulled some of the pulleys off to clean and re-lube them but that didn't seem to help.
snk828 (05-28-2018)
Old 05-27-2018, 10:34 PM   #8175
Kenny_LongWrench
Tacticool_BRZ
Kenny_LongWrench's Avatar
Drives: ZC6 - AW11
What idler pulley and belt size are you running? I found the Ram 5.7 pulley and appropriate belt solved my issues. Same 70mm pulley.
Kenny_LongWrench is offline   Reply With Quote
Old 05-29-2018, 01:30 PM   #8176
stockysnail
Just the tip
I'm using the NuLine Engine Pulley EP075 which is the same as the original size that came with the kit. For a belt I'm using with my 70mm is the Gates K061015RB which is just a teeny bit smaller than the K061015. I tried the K061010 but it barely fits. The K061010HD did not fit and was smaller than the K061010.
Do you have a link to the Ram 5.7 pulley? You only replaced the idler with the Ram 5.7?
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
