12-28-2015, 11:29 AM | #799 |
Drives: Toyota GT86 euro version
12-28-2015, 11:32 AM | #800 | |
Panda Trueno
Drives: No twin now.
I mean the audio is crap, but that sounds metallic to me. Also, if you haven't checked it out.... you can't rule it out. That noise could have always existed and you just now noticed it since you changed something. You did change the way air moves through your motor as well, so...yes you could have easily changed the exhaust noises. |
The Following User Says Thank You to Summerwolf For This Useful Post: | shiumai (12-28-2015) |
12-28-2015, 11:41 AM | #801 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
the noise didn't exist before. i've had the car 3 years and am pretty in tune to all the little noises i hear on a daily basis.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
12-28-2015, 11:45 AM | #802 |
Panda Trueno
12-28-2015, 11:45 AM | #803 |
Drives: Rb25 neo brz
Try using some Chassis mics placed around and keep moving them until you find exactly where the noise is, Sounds bothersome but if you're anything like me its worth your time.
The Following User Says Thank You to -Phil For This Useful Post: | shiumai (12-28-2015) |
12-28-2015, 12:05 PM | #804 |
yes. by the way, i'm not discounting anything you've suggested - i'm just starting out with the most obvious thing that was changed right before the noise started and going from there.
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 Last edited by shiumai; 12-28-2015 at 12:21 PM. |
12-28-2015, 12:12 PM | #805 | |
etc. if i found out anything new or edelbrock responds to my PM, i'll let you guys know.
The Following User Says Thank You to shiumai For This Useful Post: | -Phil (12-28-2015) |
12-28-2015, 12:58 PM | #806 |
I thought of that as well, so it's definitely on a list of possible sources.
12-28-2015, 03:34 PM | #807 | |
It's essentially valvetrain noise that you didn't hear before, but is not detrimental to your car at all. It helps the engine breath better at low RPM for more output. |
The Following User Says Thank You to CSG Mike For This Useful Post: | CxG (01-21-2016) |
12-28-2015, 03:52 PM | #808 | |
12-28-2015, 04:31 PM | #809 |
The amount of cam advance there is, in relation to the ignition phase, which allows the noise to be audible over normal engine operation.
The Following User Says Thank You to CSG Mike For This Useful Post: | shiumai (12-28-2015) |
12-28-2015, 04:43 PM | #810 | |
Drives: '13 SSM BRZ Limited 6MT
I'm at 30k miles now. I was under the impression that if I installed it myself, there would be NO warranty on anything. So I was figuring having a shop install it, but if I do that then I'll pay the quoted $800 install fee for only 6k miles left of warranty on the limited power train, and have a 3 year warranty on the superhcarger itself. Doesn't seem worthwhile to pay a shop to do it then. But if I install it myself, will I still have the 3 year warranty on the supercharger? I can roll the dice and waive the 6,000 remaining miles of the limited power train warranty to save $800 and installing it myself. |
12-28-2015, 05:33 PM | #811 |
12-28-2015, 06:07 PM | #812 |
I was listening - i'd like edelbrock to hear it too, just so they can identify it as such and determine its a normal with the addition of the SC.
The Following User Says Thank You to shiumai For This Useful Post: | CSG Mike (12-28-2015) |
Tags |
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger |
Similar Threads | ||||
Trunk needs a bit of force to close..... | Hachiroku14 | Issues | Warranty | Recalls / TSB | 30 | 06-19-2018 06:09 PM |
X-Force 3" Exhaust | mwjcyber | Engine, Exhaust, Transmission | 19 | 03-13-2017 02:55 PM |
The force is strong with this one (2015 STi) | blackhawkdown | FR-S / BRZ vs.... | 39 | 08-01-2014 01:26 AM |
X force or Invidia N1 | JakeG | AUSTRALIA | 8 | 01-18-2014 05:16 AM |
G-force meter | mikepaul21 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 03-17-2013 02:24 PM |
