Old 08-03-2017, 11:09 PM   #7995
SleeBrzz
SleeBrzz's Avatar
Drives: 2013 Subaru Brz
Anyone else experience battery voltage drop spikes into the low 12's when starting to accelerate? Im not sure if this is normal or not but any time I begin to accelerate and the supercharger starts to whine my battery voltage drops to around 12.3v for a second then jumps back to normal at 14.4v at WOT. Anyone know something I can do to help it not drop so low?
SleeBrzz is offline   Reply With Quote
Old 08-03-2017, 11:30 PM   #7996
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
My thought would be some kinda short in the throttle control wiring. Or maybe a shit alternator? Strange.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 08-04-2017, 01:29 PM   #7997
Kodename47
Kodename47's Avatar
Drives: UK GT86
The alternator output is ECU controlled. It's normal for the values to change as the ECU determines if it needs charge or not. I wonder if it reduces load when you suddenly increase load.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-23-2017, 10:33 PM   #7998
revaholic
Drives: 2016 Ablaze Scion FR-S
Hi all, I was wondering if anyone in Ontario (Canada) has the Sprintex intercooled system. How does it do with emissions testing - would it pass?
revaholic is offline   Reply With Quote
Old 08-24-2017, 12:32 AM   #7999
SleeBrzz
SleeBrzz's Avatar
I live in Ontario and ive got the Innovate Motorsports non intercooled kit. It passed emissions just fine. I think here as long as you don't have a check engine light your good.
The Following User Says Thank You to SleeBrzz For This Useful Post:
revaholic (08-24-2017)
Old 08-24-2017, 02:16 AM   #8000
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
alright, here we go. So we put the 335 frs on the dyno-took a while because the factory clutch which was abused by the 210 immediately slipped with the 335 lol.
This is NOT the same dyno as my 210 run (280whp/220wtq) and I plan on going back for a direct apples to apples comparison.
As far as feel goes...the 335 feels significantly stronger than the 210, hands down. Driving wise it feels "the same" but a lot more power. I fear for my engine now lol.
Yes...either building the engine or a swap is in the future. Honestly, I'll probably build out the engine first, and put a tiny pulley on the 335 and see what happens. It's only money, right?
[ame="https://www.youtube.com/watch?v=PyGWBIYBBzw"]Sprintex 335 Supercharged FRS Back Again...Bigger Supercharger=More Power? - YouTube[/ame]
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
CarzCarzCarz (08-24-2017), riboyster (08-24-2017)
Old 08-24-2017, 05:07 AM   #8001
riboyster
riboyster's Avatar
You could always drop the compression a bit
Old 08-24-2017, 01:20 PM   #8002
continuecrushing
Yeah, I go back and forth on that. It just seems that dropping it seems to result in some disappointing numbers. Obviously we'd up the boost to compensate, but still...
Old 08-24-2017, 06:02 PM   #8003
riboyster
riboyster's Avatar
Yeah. Not sure it's worth the money
Old 08-24-2017, 06:31 PM   #8004
PitViper
PitViper's Avatar
Drives: 2013 Scion FRS Limited Edition
The boost lag would be murder. Probably blow out the bottom end trying to city drive it.
Sent from my LG-H910 using Tapatalk
PitViper is offline   Reply With Quote
Old 08-24-2017, 11:12 PM   #8005
riboyster
riboyster's Avatar
Ehhh yeah you're right. Just gotta get your rods hard as Shit. Not sure how much compression the block can handle though
Old 08-24-2017, 11:19 PM   #8006
PitViper
PitViper's Avatar
Not as much as we'd like
The Following User Says Thank You to PitViper For This Useful Post:
Old 08-27-2017, 05:01 PM   #8007
DIE1000DEATHS
TechNINJA
DIE1000DEATHS's Avatar
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
At those power ratings I wouldn't be too scared. WOT at low speeds is the only thing to be concerned with when in a higher gear. The rods will be stressed. If you build it, I'd only drop the compression a point.
DIE1000DEATHS is offline   Reply With Quote
Old 08-30-2017, 12:50 AM   #8008
riboyster
riboyster's Avatar
Not too sure about that man. I'm pretty sure even the 210 has bent rods in full boost at low RPM.
The Following User Says Thank You to riboyster For This Useful Post:
PitViper (08-30-2017)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
