04-04-2017, 05:02 AM | #7883 | |
Drives: UK GT86
My battery died when I did my install. Jump started on the OEM tune. One advantage of not swapping the MAP sensor, as that would not start.
.: Stealth 86 :.
04-04-2017, 10:14 AM | #7884 |
Drives: None
Well, I ran it. And nothing bad happened, lol.
It idled pretty low, but otherwise all seemed good. |
04-10-2017, 09:04 PM | #7885 |
Drives: 2015 Firestorm 08/05/15
I am trying to source a boot nipple for my sprintex 210. Am looking for the one that will fit in the back of the charger. I got the hex head plug out with no problem. Its a 5 mm. plug. Does anybody know where I can buy one. Thx Steve
04-10-2017, 11:30 PM | #7886 |
Drives: 2013 Scion FRS
Do you guys come across bad gas (car) often? Been struggling for about a month. Car has been pulling timing on every hard acceleration and even on average driving.
I've cross-referenced my old logs from when everything was dandy, and my AFR matches, my MAF matches, my calculated load matches, the oil temps match, EVERY PARAMETER IS EXACTLY THE SAME, and somehow my car is detecting knock. I've gone into the engine bay to check for loose thingies making false positives, everything is locked in. I've gotten fuel from 2 different distributors, both "92" octane. I refuel my car at 25% remaining every time. How long do you guys think it would take to clear the system of this bad gas? Is there an easy way to purge the tank entirely so I can start fresh? I have refueled 3 times since initial bad tank Thanks
ScreamingElectron - SnakeShit Last edited by riboyster; 04-10-2017 at 11:43 PM. |
04-11-2017, 03:53 AM | #7887 |
Drives: UK GT86
@riboyster you're better off running the tank nearer empty otherwise you could be allowing a greater mix % of the poor fuel, which it does sound like. However by a few re-fills I'd have expected that one bad batch should have been mixed enough to a better blend. Maybe a seasonal change or some left in storage?
Are the ambient temps increasing? Could be higher post charge temps as the Sprintex is susceptible to it. You do mention that you're running an aggressive tune....
.: Stealth 86 :.
04-11-2017, 04:22 AM | #7888 | |
Not too sure man. I think I will run the tank down lower this next time. I just recall having the problem resolve itself before at the next refuel.
ScreamingElectron - SnakeShit |
04-11-2017, 12:10 PM | #7889 | |
Drives: 2013 Subaru BRZ Limited (Black)
I suspect something more than bad gas if you've refueled 3 times. Maybe pull battery negative terminal for 30 minutes and reattach to cause car to relearn tune? |
04-11-2017, 12:56 PM | #7890 | |
04-11-2017, 01:46 PM | #7891 |
Drives: Stock
Anybody run oft with the 210 kit? Is it possible?
04-11-2017, 03:28 PM | #7892 | |
Drives: UK GT86
It's possible if you make a tune for it or get Shiv to.
.: Stealth 86 :.
04-11-2017, 08:42 PM | #7893 | |
Drives: GT 86
04-12-2017, 02:54 AM | #7894 |
Drives: UK GT86
The bypass valve is not software controlled and is only operational when in vacuum.
.: Stealth 86 :.
04-12-2017, 03:21 AM | #7895 | |
Also it already does hit full boost at any rpm. Your throttle just needs to be completely open.
04-13-2017, 02:47 PM | #7896 |
Drives: 14' Raven M/T - 02' is300
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
