11-11-2014, 01:58 PM | #771 | |
Check you have both O2 sensor plugs seated all the way and the black/grey (on out model anyway) 02 plugs not switched |
11-11-2014, 08:40 PM | #772 | |
Drives: BRZZZ
Good to hear at WOT and higher rpm's look good, but Ive noticed today that after a fill up at my local propel station my LT fuel trim is wayy high at idle. At idle AFR is 14.69 and LT fuel trim is 18.75. On my last fill up trims got as high as ~15. Could this just be a different E85 mixture from the station? If so would higher fuel trims indicate less ethanol content? I understand that I might have to do a MAF scaling. Im just a little intimidated with editing my own tunes. Most important thing to me is knowing if Im safe to drive with these readings, if not some direction on what I need to do would be greatly appreciated. |
11-11-2014, 08:59 PM | #773 | |
differing ethanol content can cause high trims if you have cai or aftermarket intake you will likely ned to scale maf. your trims do seem high lower rpm if all you have is filter it a bit strange for them to be that high. check for intake/exhaust leaks and maybe clean maf sensor if it is an oiled filter maybe some oil on maf. were your trims ok on petrol ? and before filter install |
11-11-2014, 10:54 PM | #774 | |
Drives: BRZZZ
Will a muffler delete affect anything at all? I just installed a nameless 5" muffled track pipe, so maybe the less restricted exhaust flow can alter trims? Or am I wrong? |
11-12-2014, 03:42 AM | #775 | |
looks like you need a maf scale when your back on petrol then transfer it to the E85 tune and see how it goes. you probably only need to do the Closed loop portion ie below 3v. |
11-12-2014, 01:45 PM | #776 |
Drives: BRZZZ
Alright I'll try my best to do that. Am I OK to drive around enough to finish off my full tank of e85? Maybe just take it easy on the throttle?
11-12-2014, 01:54 PM | #777 |
11-12-2014, 01:58 PM | #778 |
Drives: BRZZZ
11-12-2014, 02:06 PM | #779 |
at low rpm ist usually just roughness or hesitation, their is only a finite amount of trim 30% but anything above 8-10% really needs sorting out as the ecu applies these trims in bands. so in your lowest band your say =12% so when you transition to next band which might be +2% your AFR is going to change 10%. Those trims are also applied when you go to open loop mode during hard acceleration WOT and can throw your AFR off from whats in the OL Fuel tables. Since its only the lowest band where your off its probably not that noticeable. Once you fix it you will probably notice better/smoother throttle response.
11-12-2014, 05:17 PM | #780 | |
Drives: BRZZZ
11-12-2014, 07:15 PM | #781 | |
Drives: Silver Subaru BRZ
Any problems with air-fuel ratio or fuel trims are caused by something at or before the O2 sensors which can include vacuum leaks/exhaust leaks(before sensors)/faulty sensors. |
11-14-2014, 03:51 AM | #782 |
Drives: s2000
After filling up gas with the stage 1 tune for awhile(91 oct), I've notice the gas meter barely stays on the top line of the gas meter and dips under it with just a few miles of driving. Before the tune, I remember the needle always goes over the top
Full line filling in full tank of gas. Is the sensor off or something? Because I filled it earlier with the empty gas light on and the pump stop at 10.5ish gallons and I was able to squeeze a few more to close to 11 gallon. |
11-14-2014, 04:38 AM | #783 | |
Drives: Neptune GR86
Because it isn't related at all.
11-19-2014, 08:44 PM | #784 |
Drives: fr-s
Hi Shiv ,
My friend just bought a GT86, we found his ecu is with ZA1JD00C where can i find the defination file or v2.04 i am not sure where to look for to download. Best regard, Jk |
Similar Threads | ||||
OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 12:29 AM |
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 10:21 PM |
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 04:43 AM |
OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
