Old 02-15-2017, 03:50 PM   #7785
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Originally Posted by riboyster View Post
How did you guys know something was wrong? Did you just notice it while looking? Or did the car act weird?
I noticed mine when looking in the engine bay. I don't think i noticed a performance difference but it was still mostly opening and closing.
stockysnail is offline   Reply With Quote
Old 02-15-2017, 04:27 PM   #7786
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Okay cool. Something to keep an eye on I guess.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 02-15-2017, 09:17 PM   #7787
Bobster
Drives: GT86 GTS
Originally Posted by xjohnx View Post
Just waiting on the map sensor and a tune that has been adjusted for the IAT sensor.
Where did you mount the external sensor?
Bobster is offline   Reply With Quote
Old 02-16-2017, 07:32 AM   #7788
xjohnx
Grip>Slip
xjohnx's Avatar
that's the IAT sensor in the picture, mounted on the map plate. I didn't end up using it though as it didn't appear to be helpful for my tuners.
Old 02-16-2017, 07:36 AM   #7789
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by stockysnail View Post
Very simple. The tricky part is positioning it properly to get the valve to open and close properly. I just threw it on and the level stayed open. Look at the valve lever before removal to see where it should be starting at. Once on there move it by hand to make sure it opens and closes. Start the car and move it or have someone else push the gas pedal so you can watch the level move open to close. If it's not opening and closing like it used to before swapping then you'll need to adjust the position a little.
mine must still be off just a hair as it will occasionaly snag/get caught. I'll have to do a little more adjusting tonight. Yay.
Old 02-16-2017, 07:24 PM   #7790
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
why wasn't it helpful to the tuner? I've been debating throwing a temp sensor in there to use.
Hell, just so I know what temps are making it into the engine would be cool (granted, it's not after the IC but still)
Old 02-16-2017, 08:21 PM   #7791
stockysnail
Just the tip
A ScanguageII will give you 80% of the reading you need. That's what I run as you can see in my build thread. The other 20% would be oil pressure and post charge temperature.
Old 02-16-2017, 10:11 PM   #7792
choi0706
Drives: t
you need to re position the IAT. its not really that accurate over there.
choi0706 is offline   Reply With Quote
Old 02-17-2017, 10:32 AM   #7793
xjohnx
Grip>Slip
xjohnx's Avatar
Yep, that's the issue i ran into. Perhaps @moto-mike can elaborate if he remembers, but it was a while back, now.
Old 02-17-2017, 10:58 AM   #7794
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
In that particular way you had it mounted it was reading the temperature of the aluminum rather than the actual air that was flowing, the open element of the sensor needs to be in the direct path of the airflow.
Xero-Limit is offline   Reply With Quote
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post:
CarzCarzCarz (02-17-2017), continuecrushing (02-17-2017), xjohnx (02-17-2017)
Old 02-17-2017, 02:51 PM   #7795
xjohnx
Grip>Slip
xjohnx's Avatar
We can blame that one on toni. Hadn't thought about that dude in a while.
Old 02-18-2017, 05:01 PM   #7796
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
Exact same thing happened to mine. I gave them a call and have a new one that should be here by tomorrow morning.
Thank you so much for posting this. I have the exact same problem and will contact Sprintex. I noticed the problem at my last track event and have been driving the car with slow throttle inputs ever since.
About how much was the replacement?
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
Old 02-19-2017, 12:25 AM   #7797
xjohnx
Grip>Slip
xjohnx's Avatar
I want to say it was $79? Overnight shipping was 35ish. Just give them a call rather than emailing though.
The Following User Says Thank You to xjohnx For This Useful Post:
MINOCIN (02-24-2017)
Old 02-20-2017, 02:30 PM   #7798
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Ordered Moto East Flex Fuel kit today! Getting excited now that I've located 2 seemingly-hidden stations nearby with E85.
Going to run stock injectors initially to get an idea of where things stand, but expecting to upgrade injectors. Figure i'll change one thing at a time, instead of 2 things at once.
ajcarson11 is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
