Old 04-15-2018, 08:46 PM   #757
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Originally Posted by SUB-FT86 View Post
The narrow Wilwoods fit too.
Oh really? Nice. Do you have a link to the specific model?
Wise is offline   Reply With Quote
Old 04-16-2018, 09:12 PM   #758
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
It's from RR Racing and it's their Stage 1 kit.
http://www.rr-racing.com/Front-Big-B...gt86fbk001.htm
SUB-FT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to SUB-FT86 For This Useful Post:
kevaughan (04-11-2022), Wise (04-18-2018)
Old 04-16-2018, 10:01 PM   #759
poolboy54
Drives: Scion FRS. Silver with black badges
Anyone know if there are any new options for Big Brake kits besides the AP Racing Sprint?
I remember reading a few years back that the AP was the only kit that fit and even then it only had about 2mm clearance.
I'm running CTSV brakes
Sent from my SM-G955U using Tapatalk
poolboy54 is offline   Reply With Quote
The Following User Says Thank You to poolboy54 For This Useful Post:
Wise (04-18-2018)
Old 04-17-2018, 06:15 PM   #760
SUB-FT86
86 Member
The Following User Says Thank You to SUB-FT86 For This Useful Post:
jubella2 (08-28-2018)
Old 04-17-2018, 06:27 PM   #761
AutoNewb
Drives: 2014 Subaru BRZ Sterling Silver
Lol. Photos are disabled. I hate photobucket. Imgur is way better.
AutoNewb is offline   Reply With Quote
Old 04-19-2018, 01:10 AM   #762
Wise
Circle Work Clerk
Oh really? I didn't know those fit. Are you using spacers?
Also do you have any pics?
Old 05-05-2018, 07:35 AM   #763
SUB-FT86
86 Member
20180504_100351 by Moses Augustus, on Flickr
20180504_100237 by Moses Augustus, on Flickr
20180504_100331 by Moses Augustus, on Flickr
20180504_100336 by Moses Augustus, on Flickr
20180504_100224 by Moses Augustus, on Flickr
20180504_100216 by Moses Augustus, on Flickr
20180504_100309 by Moses Augustus, on Flickr
DeshuL (05-07-2018)
Old 06-15-2018, 08:24 PM   #764
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Latest purchase:
trippinbillies40 is offline   Reply With Quote
The Following User Says Thank You to trippinbillies40 For This Useful Post:
spike021 (07-10-2018)
Old 07-09-2018, 02:07 PM   #765
lc300
Drives: 2014 BRZ Sport Tech
Those of you that are on lowering springs lowered 1" with these sized wheels, how bad is the poke? I just want to confirm camber bolts are necessary up front. How's the back?
lc300 is offline   Reply With Quote
Old 07-09-2018, 03:10 PM   #766
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I don't have a set just yet... But, 17x9 +35 will fit with 1" drop springs. The poke in the front is not that bad. Camber bolts will totally help and are suggested. The rear will fit nicely with just the drop. This is for 225/45, 235/40 and 245/40 tires. A 255/40 may have issues with rubbing.
I LIKE TIRES!
Old 07-10-2018, 01:34 AM   #767
Wise
Circle Work Clerk
I'm thinking about getting my black RPF1's painted silver.
Does anyone know if Enkei has an official paint code for their standard RPF1 silver?
Old 07-11-2018, 05:38 PM   #768
Open Loop
2013 FR-S Whiteout / SSC
Hi everyone - I am on the SSC kit as my car is primarily used for autocross, but I am starting to get into track events, and I am thinking of getting a wider/lighter wheel, with potentially more rubber on the ground. I would love to get 245/40-17 RE71Rs to work on a 9 inch wide wheel.
I have about -3 camber in the front and -2.2 in the rear. I am pretty sure that the front has very little clearance with the spring on a 17X8 et40 225/45/17.
I am interested in whether anyone is running RPF1's 17X9 +35 on the SSC kit (or the same Eibach springs), and whether anything needs to be done to avoid rubbing like spacers and extended bolts.
Thank you, I appreciate it!
Open Loop is offline   Reply With Quote
Old 07-12-2018, 06:26 PM   #769
kch
Senior Misanthrope
kch's Avatar
I can't comment on whether they will fit at that alignment with the stock-sized springs, as I have coils. However, I can tell you that you will have very little margin for spacers. Pic is with 245/40/17 RS3s at around -3* front camber. You could *maybe* fit a 5mm spacer and clear the fender.
The Following 2 Users Say Thank You to kch For This Useful Post:
Open Loop (07-17-2018), Summerwolf (09-18-2019)
Old 07-17-2018, 08:25 PM   #770
TPTBOY
Drives: 13 Asphalt 6MT
Does anyone run the 255/40-17 Nitto NT01 on 17x9 et35 for track days? I have a line on a decent cheap set and want to make sure they will work well. Can someone tell me the difference in performance? Thanks for the help. I just wonder if anyone has experience with the difference between 245/40 and 255/40 before I mount them on my wheels.
TPTBOY is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 264 04-11-2018 06:57 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
