04-15-2019, 09:55 AM | #743 |
Drives: 2013 Firestorm FR-S AT
Just curious, has anyone here taken this offer: https://static.nhtsa.gov/odi/rcl/201...8V772-3049.pdf
Offer ended March 31, 2019. Only good on models affected: 2012-2013 Impreza / 2013 Crosstrek / 2013 BRZ Is their Guaranteed Trade-in Program (GTP) offer as good as KBB trade-in values? |
04-16-2019, 08:43 AM | #744 |
Drives: 13 ZN6/96 EK4
I'm one of those who had their engine fail shortly after getting the valve spring recall done.
I had the recall done at Victory Toyota in Seaside, CA, and the car has been sitting at Vancouver Toyota in WA for about 3 weeks. I'm starting to get worried about my options. After speaking with them yesterday, Vancouver's service department said they were not going to cover the repairs, and that this repair isn't going to be covered under warrantee, either. They have been unsuccessfully trying to contact the dealership in CA. It seems like both of these dealerships are trying to avoid responsibility for the repair. The dealership in WA hasn't been able to give me a straight answer about what went wrong, no matter how many different people I talk to or how I try to frame the question. FWIW, my car only has 49k miles. Is anyone else going through similar hoops, or have any advice on how I should proceed? This is my DD, I have no other car, and dropping the 7k or whatever they are going to try to charge me for a rebuild/motor replacement because of someone else's fuck up is out of the question. |
The Following User Says Thank You to Edward_ For This Useful Post: | gravitylover (04-17-2019) |
04-16-2019, 08:59 AM | #745 | |
Drives: frs
The Following User Says Thank You to msaikhan For This Useful Post: | Tcoat (04-16-2019) |
04-16-2019, 09:51 AM | #746 | |
Have you contacted Toyota Corporate Customer Care? is you details noted in the registry thread? |
04-16-2019, 10:09 AM | #747 |
Rust bucket enthusiast
I got my car back Friday. Yesterday, with 76 miles on it, the engine spun another bearing.
The Following 15 Users Say Thank You to DarkPira7e For This Useful Post: | Deorio (04-16-2019), fang_gt86 (04-16-2019), gravitylover (04-17-2019), Gunman (04-16-2019), humfrz (04-16-2019), maslin (04-16-2019), mrg666 (04-16-2019), msaikhan (04-16-2019), Summerwolf (04-16-2019), Tcoat (04-16-2019), Teseo (04-16-2019), tobin (04-16-2019), tomm.brz (04-16-2019), Ultramaroon (04-16-2019), YamahaR86 (04-16-2019) |
04-16-2019, 10:12 AM | #748 | |
Even if the pick up isn't clogged there will be a blockage someplace in the system. Unfortunately finding it could involve ripping the whole engine apart. If the pick up is clear than the next place to check is the timing cover. This is where the improperly applied sealant is the most likely to have blocked channels. If it looks good then things get much more difficult to find since the sealant could be restricting flow in any number of channels. If you get no satisfaction from Toyota Customer Care then call a lawyer. Consultations are usually free and this is a case that they would probably take on without hesitation.
04-16-2019, 10:17 AM | #749 |
I haven't contacted corportate yet, that's where I'm going if I don't hear anything from the dealer that did that recall. I put my name on the registry the day my motor blew.
The Following User Says Thank You to Edward_ For This Useful Post: | Tcoat (04-16-2019) |
04-16-2019, 10:19 AM | #750 | |
It may be more economical for the current dealer to fix vs shipping the car back and forth in a non operational status. Also - have you directly contact the recall dealer? |
The Following User Says Thank You to ka-t_240 For This Useful Post: | Tcoat (04-16-2019) |
04-16-2019, 10:20 AM | #751 | |
You have been very reasonable about all this but if there is any one person that is entitled to scream it is you. What is your plan? Engine #3? God this sucks too hear.
The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
04-16-2019, 10:21 AM | #752 | |
04-16-2019, 10:33 AM | #753 | |
I am generally very much against starting legal action in cases such as this and have constantly attempted to support going through the proper channels but when those channels do not work then it is time to escalate things. The failures are from a known cause and the fact that they updated the instructions three times now means that Toyota/Subaru corporate recognizes the cause. The dealers are independent of corporate but they still need to be held accountable for their screw ups so if legal action is the last straw it needs to be considered. Nobody should have to pay $7,000 to have an engine replaced because a dealer will not acknowledge they failed in the repair.
The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
04-16-2019, 11:43 AM | #754 |
Drives: 2019 Mazda Miata RF
The Following 2 Users Say Thank You to Gunman For This Useful Post: | DarkPira7e (04-16-2019), Tcoat (04-16-2019) |
04-16-2019, 12:43 PM | #755 |
chicken tonight
Un-fucking-believable
The Following User Says Thank You to Ultramaroon For This Useful Post: | DarkPira7e (04-16-2019) |
04-16-2019, 01:07 PM | #756 | |
Got pictures back from the dealer. There are pics of the block as well, but I'm assuming this is the smoking gun I'm looking for? I had to resize the image, but there's a ton of grey/blackish jank on and near this filter. |
The Following 2 Users Say Thank You to Edward_ For This Useful Post: | gravitylover (04-17-2019), Tcoat (04-16-2019) |
Tags |
brz, failure, frs, i cant even, j02, recall, so much glue |
Similar Threads | ||||
Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
