#7435 | |
Time Traveller
Good idea! TIP: The zip tie is your friend. Use them liberally. |
#7436 |
What Fast Freddy fails to realize that Dyno numbers are not what this product is about. This provides low end TQ for DD driving and Auto-X. It also provides a bit more top end power.
#7437 |
Drives: 2014 Subaru BRZ Limited 6smt
The Following User Says Thank You to GotBRZ1691 For This Useful Post: | jflogerzi (09-12-2014) |
#7438 |
are you Jeff Vader?
Drives: Black BRZ Limited
hokai, so - apparently i've touched off some kind of flame war. point was, the dyno operator was talking to me about how he thought it was quite lean in the lower rev ranges. that's what i was looking to discuss. good points were also made about instructions for they dyno operator. let's all just play nice.
Freddy, based on other posts I believe you live near me. Feel free to come on down and take my car for a spin, and you can give me your driving impressions. |
The Following User Says Thank You to VR46 For This Useful Post: | raven1231 (09-12-2014) |
#7439 | |
Drives: 2013 Asphalt 6spd
#7440 | |
Drives: Passat
True but 206/185 on a Dyno Dynamics is ~227/204 when corrected to Dynojet equivalency. So either the 206 was in comparison mode (which you say it wasn't) or it is equivalent to ~227 on a Dynojet. Does it make any sense yet? Not really a big deal but I was simply hoping to clarify why some of the Dyno Dynamics results in this thread match Dynojet numbers while others are ~10% lower. I honestly didn't mean this as an attack on the Phantom and don't even see how it could be viewed that way but... Sadly I see that once again any attempt by myself to elucidate a factual error or discrepancy is immediately seen as an all out attack on the Phantom ESC. Not you, of course, but several others. Anyway, maybe the below information will help explain my reasoning. Obviously we still can't expect 100% accuracy when comparing results from different dynos in different shops on different days but often with a little knowledge and the the right correction factor, it can be accurate enough to present a useful comparison. From the NASA time trials rules: "Dynamometer tests must be conducted on a Dynojet Model for front and rear wheel drive vehicles, and on a Dynojet, Mustang, Dyno Dynamics, or Dynapack for AWD cars, in a commercial facility that offers dynamometer testing as part of their business and is open to the public. All (AWD) Dyno test results using a Mustang or Dyno Dynamics dynamometer will have 10% added to the maximum horsepower reading to obtain the number that will be used to calculate the “Adjusted Weight/Power Ratio” |
#7441 | |
Drives: Passat
If by "being proven wrong time and time again" you mean that since the gross exaggerations, lies, fibs, boasts, inaccuracies (whatever) that I've correctly pointed out in this thread were excusable in your opinion because they were made by people simply "boasting" about a product they either bought or were given for free and intending to "represent", I suppose I was. LOL! Now please let me get the **** out of this thread! |
#7442 | |
Drives: Passat
I shouldn't even be in this thread at all but I like to stop in every now and then to see if the first ESC car-b-q has happened yet. When I saw VR46's dyno with auto trans, Borla UEL, HFC FP and missing baseline I thought "hey, I have a dyno for my AT with the same exact exhaust setup" and submitted my dyno sheet as a baseline for him. It wasn't until days later that I realized his dyno was probably in Dyno Dynamics (DD) mode and not corrected to Dynojet (DJ) #s. Along the way I also realized that many of the DD sheets posted in this thread as well as the entire forum are in comparison (DJ) mode and I tried to point it out for the benefit of the forum. No hidden agenda. Anyway, I agree with much of what you've said and honestly wasn't trying to argue anything about peak dyno numbers other than what correction factors are necessary when attempting to compare different dynos. I am now quite frustrated and bored with the exercise and would very much like to exit this thread so that the ESC devotees can get back to topics more relevant to their own needs and wants. BTW, thanks for being so surprisingly civil. I am not at all accustomed to it in this thread. |
#7443 | |
Drives: Passat
You certainly did nothing wrong. Flames follow me in this thread like car-b-q's follow amateur automotive electrical mods. ![]() I wish I could be more help with the lean low-rpm AFR condition. I have seen the same thing on most ESC AFR plots and many turbo apps. It's hard to avoid going lean when the boost suddenly kicks in while the ECU is still in closed loop. IMO a good tuning strategy would be a custom map (Ecutek) that dumps extra fuel based on MAP. Shiv might be able to do something similar using load. I accomplished the same using a MAP-activated AFR enrichment module on my last turbo car. Whenever boost was present the module made the AFR sensor read lean which made the ECU add fuel so that even in closed loop I could get an AFR of 12:1. But I was limited by having a locked Toyota ECU and you are not. I'm sure that a "flash" tuning solution exists for you. Thank you for your kind offer. I may actually take you up on it. |
#7444 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
You see this is nice. This is constructive and appreciative. (Maybe not the first paragraph) but if you try to help instead of being such a negative nancy maybe people would listen more. I actually think you know a decent amount about cars Freddy but the way you put people down in this thread is not helpful. (Myself included towards you) Why not try to help others without being a jerk about it and maybe more people would listen.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#7445 | |
Run full time close loop will work as well but needs wideband and ecutek atm, and speed density/boost based fueling could work also.
#7446 | |
That headunit though...
Drives: 2013 Subaru BRZ Limited SSM
No worries. People sometimes get sensitive to a little sarcasm and overreact. You may not be meaning to, but you do leave some pretty good fuel for the fire in your commentary too ![]() People just need to learn to laugh it off. After all, we're on the internet. Nothing serious happens here. I'd be interested to hear what you think of a drive with the ESC -- hope you do end up taking him up on the offer! Sent from my iPhone using Tapatalk
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300 Eibach Pro-Kit + Michelin PSS (stock size) |
#7447 |
Drives: SWP BRZ
Genesis Battery Test?
Was showing my battery guy the ESC installation the other day. He was impressed (of course) and now wants a kit for his wife's Veloster.
His comment "The design guys did a great job to get the matching of the brushless motor and drive control/charger to operate so efficiently from the garden variety sealed lead acid battery capabilities. Brilliant marketing" I remember someone was planning to test the genesis batteries (ages ago) and was wondering how they performed? Tried search thread with no luck other than @fenton and @DC2R playing with other road users ![]() |
#7448 | |
Drives: White 2014 BRZ
I've always wondered this as well. Is there nothing to be gained from using a better (higher amp-capacity) batteries than the basic AGM battery. There seems to be a sizable voltage drop when the system is activated and I've discussed this my electric engineer co-workers and they said they would use ultra-capacitor "batteries". I know it adds cost but it could be very innovative. |
The Following User Says Thank You to stevo585 For This Useful Post: | Gums (09-14-2014) |
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
