07-26-2016, 10:43 AM | #7407 |
Drives: 86
What kind of gains you are seeing after the WMI?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
07-26-2016, 01:09 PM | #7408 |
Drives: 2013 Scion FRS Limited Edition
Running 1000cc of 100% meth, im seeing up to 20hp.
Temps are stable and I'm running the 69mm pulley. Im going to switch so single 600cc for the supercharger then port injection for better cylinder mix since it gets so distorted from the supercharger, that it wont properly reach the cylinders. All in all, great for cooling, useless for power to cost. And youll need to run 100% meth if you dont want a mess on your hands. Ill take a photo of my throttle body when I get home. The screws looked about the same last time I took it apart. Sent from my LG-D950 using Tapatalk |
07-26-2016, 03:46 PM | #7409 | |
ScreamingElectron - SnakeShit |
07-26-2016, 04:40 PM | #7410 | |
You also lose the benefits of running methanol; -higher octane -run cooler -cleans the engine -more stable combustion cycle -more stable under high boost pressure. Where as water will help cool, but no where near as well as alcohol and you lose out on power gains and the stability of alcohol. And with that, you can run any kind of alcohol. I just get gallons of race gas (alcohol) from my local dragstrip. And if I'm in a pinch, HEET, which is at ever parts store ive ever seen, Even walmart. And it's 100% meth. You also have to caution with water, for any overflow that is blocked off from the throttle body being closed, will run down your intake pipe to your air filter... which may or may not damage your MAF sensor. Not sure if it could... but it can be a mess. My injection location. Sent from my LG-D950 using Tapatalk Last edited by PitViper; 07-26-2016 at 08:06 PM. |
The Following User Says Thank You to PitViper For This Useful Post: | CarzCarzCarz (07-27-2016) |
07-26-2016, 07:31 PM | #7411 |
Okay thanks man
07-26-2016, 07:52 PM | #7412 |
The Following User Says Thank You to PitViper For This Useful Post: | riboyster (07-26-2016) |
07-27-2016, 01:24 PM | #7413 |
Drives: 2013 Firestorm FRS
so, just got the car dyno'd! Dynojet
Put down 283whp and 219tq Thought it might put down a little more, but its pretty warm and I don't know my "e" content. I've got the delicious tuning bluetooth thing, so i'll have an android friend install the app/check my ethanol level (should be pretty high). However, I am SUPER happy with how consistent the pulls were-even the guy helping with dyno training said it was damn consistent. I'll get the dyno sheet posted shortly |
07-27-2016, 02:42 PM | #7414 | |
Drives: 2017 Camaro 1SS
07-27-2016, 03:20 PM | #7415 |
07-27-2016, 03:49 PM | #7416 |
That's a fast car man! Can't wait till I'm past 250!
07-27-2016, 03:55 PM | #7417 |
07-27-2016, 04:30 PM | #7418 |
Yeah doesn't it make 260hp with the 75mm on e85?
07-27-2016, 06:32 PM | #7419 |
Y u do dis?
I will be tuning my freshly broken in motor on august 10th, stay tuned for details.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
The Following User Says Thank You to Dream20b For This Useful Post: | brianhj (07-28-2016) |
07-28-2016, 12:10 PM | #7420 |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
