03-09-2012, 03:18 PM | #715 | ||
Drives: 4 Wheels Auto
And your second paragraph is correct. The absolute value of the acceleration is at maximum. the graph shows the directional change.
03-09-2012, 03:21 PM | #716 | |
Hmmm.. when velocity reaches maximum, its (angular) acceleration reaches 0 and then change direction. In the 6" rod with 2" crank radius example, that is at the crank angle of 73.17615.
03-09-2012, 03:26 PM | #717 |
Kuruma Otaku
How much of a difference in acceleration forces are there between say a 138mm rod and a 155mm rod, at 7000 rpm and 8500 rpm as an example. (86mm stroke).
Because titanium. |
03-09-2012, 03:42 PM | #718 |
Drives: '06 AM V8V Coupe
The peak acceleration is a fixed ratio between 2 different rods.
I don't want to add units to this since it'll have some stupid pi^2 and crap everywhere, but the ratio of peak accelerations is 1.0267. I think the rod length on the FA is closer to 130mm though, so for fun let's see what the ratio between a 130 and 138 rod are. Okay it's 1.01462. So it appears that as far as rod strength is concerned, a longer rod doesn't help too much, as peak acceleration and forces are at TDC when the rod is at angle 0 with the piston. So it should be the friction and combustion that a longer rod is good for. I don't know which one is more important though. The effect of combustion is going to affect thermodynamic efficiency, but I don't have any idea of how fast the charge burns. Last edited by serialk11r; 03-09-2012 at 03:56 PM. |
03-09-2012, 03:58 PM | #719 | |
Wiring Nerd
Drives: 1994 Supra
03-09-2012, 05:26 PM | #720 | |
Kuruma Otaku
If I remember I'll try to find an article on rod design (stiffness vs cross-section of H or I beam, etc...) I have and post up some of the math stuff that I don't understand. I would imagine as we increase the rod length, stiffness becomes more important... (I want an 8500 rpm limit on this motor...)
Because titanium. |
03-09-2012, 06:36 PM | #721 |
Okay so now that I finished my midterm and BSed my stat homework, I'll plug some stuff into Wolfram Alpha for you...
So 138mm rod, 86mm stroke gives 56.3986 mm/t^2 where 2pi t=1 revolution. 7000rpm=700/6 revolutions/second, so t= 6/700s/2pi=0.001364185s. So the acceleration is 30305m/s^2...does that look right? 3000g? :O 155mm rod, 86mm stroke would be 29516m/s^2. 130mm rod, 86mm stroke would be 30749m/s^2. At 8500rpm, 155mm rod: 43521m/s^2 138mm rod: 44684m/s^2 130mm rod: 45339m/s^2 Just a note though, if you saw the picture of the crank+pistons in the other thread, there is no way the rod:stroke is >=1.6... What would be ways of lengthening the rod without changing the block? Can you move the wrist pin up relative to the piston? Last edited by serialk11r; 03-09-2012 at 06:53 PM. |
03-09-2012, 07:00 PM | #722 |
Okay I'm attempting to quantify the differences in combustion time and...well here goes:
http://www.wolframalpha.com/input/?i...rt{9-sin^2x}-3 Blue is 1.5 rod stroke ratio, purple is 2.5(!) rod stroke ratio. As you can see, the difference in cylinder volume vs crank angle are very small! Not to mention, the piston acceleration doesn't actually change that much either... If you reduce the 2.5 ratio to 2, the lines become so close you can barely tell them apart. http://www.wolframalpha.com/input/?i...{3^2-sin^2x}-3 The scale isn't bad either, it shows about 2 crank revolutions. A lot of pages back though, I computed a 5% drop in piston skirt friction and force for a somewhat small change in the ratio, so I think this suggests that rod ratio is primarily for reducing the loads on the cylinder bore, friction reduction giving a small increase in power on the order of 1% or so as well. |
03-09-2012, 07:17 PM | #723 |
Drives: SSM LT MT BRZ
To improve the rod:stroke it is common to move the wrist pin height (compression height) up into the piston sometimes even into the ring land, special considerations like an oil ring support rail are necessary when this is done but there are no other real drawbacks, besides the price of custom pistons & rods.
03-09-2012, 07:24 PM | #724 |
From a thermal POV is the reduced friction on the skirt even worth computing, to see if there is an advantage in timing due to lower residual heat in the piston?
My gut laughs, Is there significantly less bending load on the rod due to decreased angle? Can you tell us the difference in Max angle VS perpendicular that the rod sees with a 130 and 138mm rods? (it's obvious you can, will you please?) |
03-09-2012, 08:34 PM | #725 | |
Kuruma Otaku
But while looking for confirmation on the 138mm I ran into this page by accident: http://trdparts.jp/english/parts_engine-3s-ge.html 270 PS (~266 bhp SAE) @ 8600 rpm all motor, all parts formerly available through Toyota Technocraft/TRD Japan. This was when TRD parts were legit, not re-badge so-so other parts...
Because titanium. |
03-09-2012, 08:44 PM | #726 |
Holy mother of god, 122.5Nm/L :O !
Skullworks, I think the cylinder walls absorb that heat fast enough for it to not be an issue lol. As for maximum rod angle...I don't see a very simple way yet. Give me a few minutes. EDIT: Okay, the angle between the rod and the piston is the arcsin of "x position" relative to crank center and rod length, so the max angle is at 90* and 270* crank angle, and the angle is arcsin(crank radius/rod length). 138mm crank has maximum angle of 18.16*, 130mm crank has maximum angle of 19.32*. The angle measurement isn't really what's important though, the sine is the maximum ratio of sideloading force to bearing force, and the tangent is the maximum ratio of sideloading force to net force on the piston. |
03-09-2012, 08:50 PM | #727 | |
Kuruma Otaku
Also they a lot of performance pistons are asymmetric now, too. Lighter and less friction. Edit:
Because titanium. Last edited by Dimman; 03-09-2012 at 08:52 PM. Reason: Pic |
03-09-2012, 09:32 PM | #728 | |
Pro Subie Engine Nerd
Drives: BRZ has a reserved space
I'll be going through the bottom end combinations and publishing the data when parts come to market...maybe before. |
Similar Threads | ||||
Joke Thread | VenomRush | Off-Topic Lounge [WARNING: NO POLITICS] | 27 | 07-09-2011 12:44 AM |
The Music Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 03-28-2011 11:35 AM |
engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 05:10 PM |
FT-86 to debut new GPS-track day technology for use on track and GT5! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 01-30-2010 11:30 AM |
Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
