go_a_way1
Old 07-08-2013, 01:52 PM   #701
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by Wild Weasel View Post
Also... it's been mentioned that the better comparison is to a 50 shot of nitrous, which is right on the money. So, having just seen this... here's an advantage that this kit has over that option...
http://oppositelock.jalopnik.com/pro...ium=socialflow
No pop-off valve?
2013 FRS
Vortech V3 11psi
Old 07-08-2013, 01:58 PM   #702
Wild Weasel
Wild Weasel's Avatar
Drives: 2001 Sunfire GT + 2007 Mazdaspeed3
Originally Posted by DJCarbine View Post
No pop-off valve?
Apparently real men don't use pop-off valves.
Wild Weasel is offline   Reply With Quote
Old 07-08-2013, 02:01 PM   #703
Robftss
Drives: VW
All things considered, it is a hybrid of Nitrous and traditional FI. It literally (edit: essentially ?) slots 1/2 way between both.
Robftss is offline   Reply With Quote
Old 07-08-2013, 02:09 PM   #704
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by Robftss View Post
All things considered, it is a hybrid of Nitrous and traditional FI. It literally slots 1/2 way between both.
It "literally" does not. No nitrous is involved, this is just an alternative non-parasitic FI option.
I apologize for my tone, but the overuse of "literally" is fast becoming a pet peeve of mine.
Old 07-08-2013, 02:16 PM   #705
Wild Weasel
Originally Posted by Robftss... Probably
DAMMIT! I'm an engineer, not an English major!!
Old 07-08-2013, 02:17 PM   #706
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
is this something that will be produced? Depending on price I would 100% get this.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 07-08-2013, 02:30 PM   #707
Pete
Pete's Avatar
Drives: 22 BRZ
I think he was just referring to the fact that you can only use it in very short bursts, but it recharges its own "nitrous". I know what you mean about "literally" though.
I agree that this doesn't compare well to regular FI, since it can only be used in such short "bursts" its not really an "always on" power solution like a turbo or supercharger. Since it only engages at full throttle that means throttle modulation for any sort of precision driving is unlikely to work well. I would guess that the most common use for this will be stop light drag racing, which it should do just fine with, if that is what you are looking for.
I can see a device like this being the #1 choice when battery technology reaches the point that you can use full boost for say 60+ seconds without a need to recharge, and modulating the throttle is possible without losing boost.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
The Following User Says Thank You to Pete For This Useful Post:
HunterGreene (07-08-2013)
Old 07-08-2013, 02:42 PM   #708
HunterGreene
Hail Magnet
You're correct, I left that part out of my reply. A good term for this (besides e-charger) would be "burst-charger."
The Following User Says Thank You to HunterGreene For This Useful Post:
Pete (07-08-2013)
Old 07-08-2013, 02:45 PM   #709
mid_life_crisis
Drives: FR-S 10 #103 AT
Fenton seems to not be ashamed to admit that his car is in serious need of a driver mod. The point being that a talented driver might find that with the latest modification that is intended to eliminate restriction when not at full throttle, the responsiveness might be improved enough to make a sufficient improvement over stock to reduce lap times.
What I'm trying to say is that it might be good for more than just straight lines.
Old 07-08-2013, 02:45 PM   #710
Wild Weasel
I understand what you're saying with regard to precision driving, but I don't want people to misunderstand how this thing is useful. You say it's not really "always on" by which I'm sure you mean that it's not increasing the overall consumption of the engine like a regular turbo. So the engine does not behave as though it were simply a bigger engine.
But from all testing so far, it IS always available when you want it, and it's definitely useful for more than just hooning. The power is immediately available any time you want full acceleration whether that means running up an on-ramp or pulling out to pass someone.
Old 07-08-2013, 02:51 PM   #711
mid_life_crisis
Translation please.
"Hooning"?
I feel like Data when they took the country star on board. "Pit woofie?"
Old 07-08-2013, 02:55 PM   #712
Pete
Pete's Avatar
Drives: 22 BRZ
...But from all testing so far, it IS always available when you want it...
It's not available if you have just used it. You have to wait for it to recharge. Thus not always on.
Old 07-08-2013, 03:09 PM   #713
Wild Weasel
This is not true. Nobody who has tested one has yet to be able to run it out.
And that's exactly the misunderstanding I expect a lot of people might have when reading about this. I did everything I could to actively try to run down the battery and simply couldn't do it. The blower was available any time I wanted it. Unless you're on the Autobahn and can hold the throttle wide open for long periods of time, the system will charge faster than you can run it down.
The only opportunity on this side of the sea to run it down might be over a few laps at a track event. I don't think anyone has tried this yet.
Old 07-08-2013, 03:11 PM   #714
Wild Weasel
Originally Posted by mid_life_crisis View Post
Translation please.
"Hooning"?
Sorry... driving like a maniac. I'm just making the point that this is useful to people who aren't idiots too. This isn't just a red-light-racer toy.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
