04-10-2016, 06:32 AM | #7001 | |
Y u do dis?
I think I flooded it trying to start it and then either bent a rod or valve.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
04-10-2016, 07:48 AM | #7002 | |
Drives: 2013 Scion FRS
This is a dire circumstance. If a flooded motor means bent rods then we're all screwed.
ScreamingElectron - SnakeShit |
04-10-2016, 05:47 PM | #7003 |
Y u do dis?
It was losing fuel pressure immediately after starting, i'm told, causing these issues.
Dat Hot Lava Doe
04-10-2016, 09:28 PM | #7004 |
Running too lean, you mean?
While on the topic, anyone else have a much harder time cranking on hot starts?
04-10-2016, 10:11 PM | #7005 |
Drives: GT 86
04-11-2016, 01:25 AM | #7006 |
Must be my battery...
04-11-2016, 10:04 PM | #7007 | |
Drives: Toyota 86 with supercharger
04-11-2016, 11:03 PM | #7008 |
What's the smallest pulley you guys have run without intercooler? Thinking about upgrading while I save for IC and monitoring knock
04-12-2016, 07:31 PM | #7009 |
Drives: 2013 FRS
I just bought a Sprintex, with intercooler.
I was curious what do i need to get started? oil catch can? injectors? oil cooler? |
04-12-2016, 07:38 PM | #7010 | |
Drives: GT 86
Stock injectors and pump are fine for pump gas. Oil cooler with thermostat is very worthwhile imo . |
04-12-2016, 07:56 PM | #7011 |
Drives: 2013 FRS
04-13-2016, 07:35 AM | #7012 |
Drives: 2014 Toyota 86
04-13-2016, 10:29 AM | #7013 |
DrivinginDreams...Cloud86
Drives: Toyota GT86
My install is on the 26th and I'm trying to remember something I read in this thread about when adding boost to our cars, clamps need to be added to specific hoses that will eventually come loose and disconnect causing loss of power as there are no clamps from factory, due to not being boosted initially. Does anyone know what this would be specifically that I can tell my mechanic?
04-13-2016, 02:35 PM | #7014 | |
...Just add nauseum
Drives: 2003 (AP1) S2000
In other words, no, don't worry about it.
Inline 4 is best 4
There are many ways to displace. -Spartarus |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
