08-17-2013, 12:11 PM | #57 |
Negative Mass
Drives: Orange Metallic AVO Turbo GT86 6MT
Finally have a build thread of sorts going. Scroll to the bottom of the first post and then the following couple for a bit about the AVO now. I'll be adding more as I drive it more and get more of a feel for the car. Right now it's just one word, unbelievable.
http://www.ft86club.com/forums/showthread.php?t=44302 |
08-17-2013, 12:25 PM | #58 |
Fiebru
Drives: Scion FR-S and Integra Type R
Looks like my kit will arrive Tuesday according to the tracking page
Current Cars:
2017 White Platinum Ford Fiesta ST 2013 Raven Scion FR-S 2012 Spruce Mica Toyota Tacoma TRD Off-Road 2000 Phoenix Yellow Acura Integra Type R |
The Following User Says Thank You to Draco_PR23 For This Useful Post: | Sportsguy83 (08-17-2013) |
08-17-2013, 08:54 PM | #59 |
Drives: 2JZ FRS
08-17-2013, 09:00 PM | #60 |
Drives: 2003 Subaru Outback
18 eh? Haha totally kidding.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
08-17-2013, 10:27 PM | #61 | ||
I Love custom Turbo kits
Drives: Limited BRZ
The Following User Says Thank You to Sportsguy83 For This Useful Post: | nataku (08-18-2013) |
08-19-2013, 11:10 PM | #62 |
Drives: 2013 Scion FRS "Raven"
@Tansey86 we are happy to see you like our meaty tire set up. we will be posting a full build soon and we hope to answer all of your questions. as you can see we are also run and proudly support AVO
The Following 3 Users Say Thank You to DAMotorsports For This Useful Post: |
08-20-2013, 06:10 PM | #63 |
Drives: AVO BRZ
That is intentional I think from AVO so that once its on the car and the exhaust is in place, you can tighten everything while you lever the over pipe as high as possible for extra clearance.
08-20-2013, 07:42 PM | #64 |
Drives: 2JZ FRS
You can't get to half of the bolts clearance wise once the assembly is in place
08-20-2013, 09:16 PM | #65 |
Drives: Limited BRZ
Yeah, I had the same thing happen.
08-20-2013, 11:01 PM | #66 |
When we installed our kit, I tightened everything and did not have any problems. We did some track testing and blow the inlet gasket. Talked with Paul and a buddy of mine and found a set of locking nut plates that should fit to help stop the nut from backing out. Ill post the part numbers on Thursday once they arrive and I can confirm they work.
The Following User Says Thank You to DAMotorsports For This Useful Post: | Pitman (08-21-2013) |
08-20-2013, 11:47 PM | #67 |
Drives: AVO BRZ
We did a few mock fits and tightened everything down in stages, there was a few mm of tolerance, but in my case not enough for Perrin over pipe clearance under full load. Now with STI engine mounts, the over pipe barely moves.
The Following User Says Thank You to nix For This Useful Post: | DAMotorsports (08-21-2013) |
08-21-2013, 12:22 AM | #68 |
Drives: FRS :D
Out of the FRS game
The Following 5 Users Say Thank You to Mr.Jay For This Useful Post: | FrX (08-21-2013), ftc~brz (08-21-2013), SkAsphalt (08-26-2013), Sportsguy83 (08-21-2013), zuldajin (08-21-2013) |
08-21-2013, 01:26 AM | #69 |
@mr_jay
08-21-2013, 01:26 AM | #70 |
Negative Mass
Not really a complaint as much as an observation but, did any of you guys buy the blow off valve? I got it because I wanted that hissing when I shift (what can I say I care about stupid things like that). Anyway I don't even hear a peep out of it at any point, even if I redline and just let off completely. Is it just something that doesn't do much until I up the boost?
Tags |
avo, avoturboworld |
Similar Threads | ||||
Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 04:26 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
