08-22-2012, 10:53 AM | #57 | |
Drives: ae86, etc..
chromoly tube rear sub frame, (massive savings in nissans) chromoly tube engine crossmember and mounts, and gearbox crossmember kevlar boot/door cards/lower dash, smaller toyota alternator, bolts cut down to mininum lenth/thread not for everyone or DD but you can go crazy when it comes to weight savings, at one point we even had ae86 carbon fiber engine crossmember made, it was stupid light, but our engineer was concerned with vibration fractures, |
08-22-2012, 11:43 AM | #58 |
Drives: MX5
08-22-2012, 01:07 PM | #59 |
Reverse Burnouts
Drives: 2013 Argento FRS
I see this being completely possible, I had a 9lb flywheel in my last car lol, helped reponse ALOT, the problem with boxer motors if the valve angle, the k20 had better flow angles vs my Celica, thats why I never saw the gains the Honda guys saw
2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
08-22-2012, 02:03 PM | #60 |
Drives: DGM BRZ Limited
I don't see how the stroke of 86mm is an issue for revs. And a low rod/stroke ratio isn't the end of the world for high rpm power. Don't expect 10k rpm efficiency, but 9k could work out.
I'm revving my SR20VE to 8800rpm with power holding until 8500rpm, using stock head and stock SR16N1 cams. It's forced induction, but it just goes to show that you can rev decently with an 86mm stroke. Also, the 4b11t, SR20, K20 and the FA all have 86mm stroke and bore. The F20c engine is 84mm stroke. It does have a long rod though. Rod/stroke is 1.54 in a B18 engine. K20 is around 1.61. SR20VE is 1.58. Just food for thought. |
08-22-2012, 09:17 PM | #61 |
Reverse Burnouts
[ame="http://www.youtube.com/watch?v=PjhocJ4QgBk"]2012 Lexus LFA Road Trip: Dyno Test - YouTube[/ame]
someone make it rev like this and ill be happy that thing gains and loses revs so damn fast....
The Following User Says Thank You to carbonBLUE For This Useful Post: | Guff (10-13-2013) |
08-22-2012, 09:45 PM | #62 |
Drives: car
Stop comparing this engine to a Honda engine. It has a fixed valve lift. That requires big compromises. And ITB's will be very expensive and hard to control with electronic throttle.
08-22-2012, 10:07 PM | #63 | |
Seņor Member
I was thinking last night that perhaps a twin throttle setup would be easier than ITBs. Similar to what Ferrari run with separate plenums per bank. We could use two stock throttle bodies and just splice the signal from the ecu to each in parallel. Although i don't know if that electronically feasible.
1974 TA22 Celica
2013 86 GT |
08-22-2012, 10:18 PM | #64 |
Drives: 2013 Firestorm FR-S
So stock the redline is 7400 rpm and several tunes are increasing the redline to ~7800. Is there any rule of thumb to knowing what is safe? I wouldn't think 400 would be pushing the bounds of safely but I don't know Boxers like I know rotaries.
08-22-2012, 10:22 PM | #65 | ||
Reverse Burnouts
really depends on g forces and what testing the engine went through before it was put in the car for example 2zz-ge one year the car had a 7200 rpm redline, the year i had, had a 7800 rpm redline and a 8400 rpm fuel cut off, i tuned it without changing any internals to 9000 rpms during the beginning before i went all out. for all we know this engine could be safe to 8400 and run reliably there every day, until further aftermarket test is done, we wont know what the engine is safe at or when the valves start to float it could be an easy modification of titanium valves/springs/retainers and see 8500 rpms reliable, ,every day for 10 years... we just dont know at this point and anyone testing it is keeping it secret till its proven to be good enough for its customers 86x86 bore/stroke is perfect for high revving, here in 2 years dont be surprised if you see a boosted 300whp fa20 with new valves/springs/retainers running 8500 rpms on completely stock block besides the valves/springs/retainers
08-22-2012, 11:39 PM | #66 | |
Drives: '06 AM V8V Coupe
You can't say 86mm stroke is perfect for high rev, but it can be brought to 8000+ if everything else allows. It appears we have a rod:stroke ratio of about 1.51-1.52, which is close to the smallest number you'll find on production engines. The actual difference between the piston motion at 1.51 and 1.7 isn't that big mathematically speaking, but OEMs refuse to let an engine with a short rod rev, something to think about. |
08-22-2012, 11:59 PM | #67 | ||
Drives: ZC6, Junk of ALL sorts
# 1. Always know where your towel is.
ZC6-CBS, is home |
08-23-2012, 12:11 AM | #68 |
Wouldn't it be crazy if they got rid of the TB and just ran dual electronic servos to open the TGVs?
08-23-2012, 01:22 AM | #69 |
The TGVs are operated by electronic servos. The plastic thing splits the intake port into 2 halves, one of which is blocked off by the TGV. Can't throttle an engine with that.
08-23-2012, 01:33 AM | #70 |
Drives: ae86, etc..
HAHAHA so we are going back to old school toyota TVIS systems, but instead of vaccume operated its now electro servo,
(granted one is for tumble and one is for verlocity but still..) it makes the car feel THAT much closer to the AE86, i love it, (i have about 6 sets of 20valve blacktop quads and 4 sets of silvertop quads and 3 sets of SR quads in my shop if anyone is wanting quads, they sell for about $100 N.Z$ so about $60 U.S, |
Tags |
9000rpm, aspirated, high, naturally, revv |
Similar Threads | ||||
Let's see your computer setup! | Hanakuso | Off-Topic Lounge [WARNING: NO POLITICS] | 81 | 11-06-2022 11:43 AM |
AutoX Parts Setup | NYC BRZ | Tracking / Autocross / HPDE / Drifting | 38 | 08-17-2012 05:42 PM |
Audio setup | 315FR-S | Electronics | Audio | NAV | Infotainment | 20 | 05-17-2012 06:23 PM |
2 car setup...feasible? | mankarn86 | CANADA | 3 | 03-30-2012 02:00 AM |
