02-19-2022, 06:16 PM | #57 | ||
Custom User Title
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
The Following User Says Thank You to Locust For This Useful Post: | e1_griego (02-20-2022) |
02-23-2022, 05:13 PM | #58 |
Tried a052 for the first time this weekend, played with pressures from 30-38 psi (hot) with no discernible difference other then a minor change in feel. Pyrometer seemed to prefer the high side. What pressure do y’all run?
245/40/17 Yokohama A052 on 17x9 STX prepped twin (-4F/-2.5R ish camber). |
02-23-2022, 05:31 PM | #59 | |
Drives: LP DSP / CSP '13 BRZ
The Following 2 Users Say Thank You to Eric1855 For This Useful Post: | DocWalt (02-24-2022), strat61caster (02-23-2022) |
02-23-2022, 11:55 PM | #60 |
Drives: Many
Not that I'm any good at it, but yeah 30/28 is where i usually start.
The Following 2 Users Say Thank You to e1_griego For This Useful Post: | smg1138 (04-03-2022), strat61caster (02-24-2022) |
02-24-2022, 05:24 AM | #61 |
Drives: 2016 Scion FRS
I'm a bit lower. I've ran as low as 25/25 at low grip places and 27/27 on concrete.
...but I also tend to like vague tires, "overheated" tires, shocks on soft, etc. |
The Following User Says Thank You to steverife For This Useful Post: | strat61caster (02-24-2022) |
02-24-2022, 10:33 AM | #62 |
Drives: 2013 Subaru BRZ
We found that running pressures below ~28psi created a "spring rebound" effect with the AO52's. Setting the tires entering the corner but when the sidewall snaps back (versus the tire loosing grip), the results are not good. 29/28 to 33/33 was the ballpark to play in.
The Following User Says Thank You to PointDSM For This Useful Post: | strat61caster (02-24-2022) |
02-24-2022, 09:59 PM | #63 |
Drives: 2017 BRZ series.yellow
28 in the front 26-27 in the rear when hot is what I have run the past couple seasons with A052s.
The Following User Says Thank You to Breezio For This Useful Post: | strat61caster (02-25-2022) |
03-02-2022, 01:31 PM | #64 |
For anyone on the fence, there are only four entries in STX for the Tour at FedEx next month. I'm sure everyone would be happy to see a fifth entry
Well, maybe not everyone if you win, but I'm in no danger of that
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
03-02-2022, 02:32 PM | #65 |
Drives: Many
Is anyone else signed up for Vegas Tour?
We had a good battle last year, but Kate is now gone and Mudge moved to the East Coast :sadpanda: |
03-02-2022, 02:32 PM | #66 |
Drives: Many
Is anyone else signing up for Vegas Tour?
03-02-2022, 03:17 PM | #67 | |
I would be interested in flying out there if a co-drive presented itself (my actual name is Eric Niemi)? Maybe we can get Manfred to come out as well? Same goes for the Fedex tour event. Winter's been long as usual here in Wisconsin... |
03-02-2022, 03:59 PM | #68 |
Alas, I don't have an open seat, sorry.
The Following User Says Thank You to Autoxer62 For This Useful Post: | PointDSM (03-02-2022) |
03-02-2022, 04:11 PM | #69 |
Drives: 2015 Series.Blue Subaru BRZ
2015 Series.Blue BRZ
Tein Flex Z Suspension (In the process of buying KW V3s) SPC Rear Lower Control Arms w/ STX bushings JDL 4-2-1 Catless Header Perrin Overpipe, Catted Frontpipe, and Catback Injen Tuned Intake Xero Limit EcuTek Tune Delicious Tuning Blue Coil Packs 17x9 45mm offset 10mm Eiback Spacers ARP Studs w/ Gorilla Lug Nuts Whiteline 19mm Front Sway Bar (soft setting, probably moving to stiffer setting next week) I'm keeping my eyes open for a Mann rear sway bar and maybe a larger front bar. What else do you recommend I keep an eye out for, other than seat time, because I need about all of that I can afford. I'm aiming to be at the Bristol events this year, but that's likely the only national level events I'll make it to. I'm regretting not being more social at Nats last year, so maybe I'll meet some of you in Bristol.
Connor Johnson
2015 Subaru BRZ Series.Blue Tennessee Valley Region - STX #15 Last edited by ConnorJ; 03-02-2022 at 05:13 PM. |
03-02-2022, 08:21 PM | #70 |
At the track
Drives: '14 FRS - Former e92 M3
While we’re on the talk of traveling to events. I’m interested in an L3 ProSolo event or two if anyone has an open seat for any of those later this year.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Similar Threads | ||||
The 2022 Autocross Thread | trippinbillies40 | Tracking / Autocross / HPDE / Drifting | 11 | 02-26-2023 05:13 AM |
STX setup sharing thread (2021) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 366 | 12-07-2021 01:57 PM |
STX setup sharing thread (2020) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 389 | 12-29-2020 01:40 PM |
STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 110 | 02-17-2020 11:27 AM |
STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 11:30 AM |
