Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
View Poll Results: How do you downshift? | |||
Nothing | 16 | 10.39% | |
Rev Match Only | 116 | 75.32% | |
Double clutch | 22 | 14.29% | |
Voters: 154. You may not vote on this poll |
08-27-2017, 10:48 PM | #57 |
Porsch-AH
Drives: 2007 Porsche Cayman S
As someone who doesn't know a thing about transmissions, the only thing I understood in this thread were the F&F references.
08-27-2017, 11:33 PM | #58 |
helmholtz resonator
Drives: '15 ultramarine
I triple clutch, so my synchros last..
08-28-2017, 12:31 AM | #59 |
Drives: 2014 BRZ Limited
08-28-2017, 12:09 PM | #60 |
Drives: 2017 BRZ
08-28-2017, 12:44 PM | #61 |
Huge E85 fan!
Drives: 2016 Scion FRS
Someone is going to have to explain to me how this will affect synchro wear at all. To get to the next gear- clutch once or twice it doesn't matter- you still have to row through the synchros. They don't just disappear because you hit the clutch an extra time. Rev matching (heel and toe shifting) will help the synchros in a small way, but double clutching- makes no sense at all
08-28-2017, 01:03 PM | #62 |
tbh i double clutch into first sometimes. i find it a little easier to get into first when i double clutch, either at a stop light or from a slight roll. it could be my imagination, but IIRC first has a more limited synchro than the other gears.
08-28-2017, 01:17 PM | #63 |
Drives: FR-S 10 Series
It doesn't matter if you double clutch or not because winning is winning.
08-28-2017, 01:29 PM | #64 | |
Drives: 2005 Toyota Camry
The Following User Says Thank You to mav1178 For This Useful Post: | JD001 (08-28-2017) |
08-28-2017, 02:42 PM | #65 | |
Hombre
Drives: 1994 Supra Turbo
Carry on!
A Toyota Racecar A Toyota......................Because.
Anyway, should not palindrome be spelled palinilap? |
The Following User Says Thank You to Silver Supra For This Useful Post: | JD001 (08-28-2017) |
08-28-2017, 03:09 PM | #66 |
Drives: 2013 Hot Lava FRS
I do the peddle dance every time I downshift to protect my synchros
The Following 3 Users Say Thank You to Slammillionaire For This Useful Post: |
08-28-2017, 03:16 PM | #67 |
Drives: 2013 Scion FR-S Series 10
I voted double clutch . I see 6 other people did the same.
Now I know who to barbecue with while drinking Coronas and saying grace. |
The Following 3 Users Say Thank You to mazeroni For This Useful Post: |
08-28-2017, 03:19 PM | #68 |
08-28-2017, 04:06 PM | #69 | |
Drives: 2013 Audi Allroad, 2017 Subaru BRZ
Rev matching will reduce wear on the clutch. Double clutching will reduce wear on the synchros (and the clutch). When you double clutch you also rev match so that the rotational speeds of the gear and the shaft are matched - result: no appreciable wear on the synchronizer rings when selecting the gear. |
The Following User Says Thank You to mnuttall For This Useful Post: | Ultramaroon (08-29-2017) |
Similar Threads | ||||
Clutches for turbos | jaime3 | Forced Induction | 14 | 04-26-2017 08:35 AM |
Sigh, clutches? | rubbercow | Engine, Exhaust, Transmission | 16 | 12-11-2016 09:21 PM |
Clutches feedback/recommendation | FullTuneZN6 | Engine, Exhaust, Transmission | 2 | 12-25-2014 06:49 PM |
Clutches... | Synack | Engine, Exhaust, Transmission | 19 | 12-16-2012 04:15 PM |
