01-05-2014, 11:07 PM | #57 | |
Drives: Ultramarine FR-S 6MT
Mrlewistan, Still need, were you able to confirm this is the correct switch bezel? Thanks |
01-06-2014, 02:13 AM | #58 |
Driver of FR-S 1467
Drives: 2013 scion frs 001467
i ordered it. hopefully be here next week but the rep i emailed said it was what i was looking for. so im staying possitive
01-06-2014, 10:26 AM | #59 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
Good guide, thanks.
You're lucky that it's not the useless JDM plastic lens fogs the rest of the world got.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
01-08-2014, 05:32 PM | #60 |
Driver of FR-S 1467
Just got it, and yes it is the right ones
The Following User Says Thank You to mrlewistan For This Useful Post: | sid325 (01-10-2014) |
01-10-2014, 12:01 AM | #61 |
Nice! Ordered one as well. Thanks again.
The Following User Says Thank You to sid325 For This Useful Post: | mrlewistan (01-10-2014) |
01-11-2014, 03:56 AM | #62 |
Big Member
Drives: 2014 FR-S
I skimmed thru this DIY, thanks for this write up, but I'm wondering, how hard is this? It's looks pretty tricky imo.
01-14-2014, 09:25 PM | #63 |
What's the opening next to the dimmer for?
01-15-2014, 11:55 PM | #64 | |
02-13-2014, 12:41 PM | #65 |
Drives: Not yet...
When someone is doing this install, would they mind looking at the connector that plugs into the trunk release and see if there is a part # on it? They can be hard to see, but most of the Toyota connectors I have seen, all have the part # on them somewhere.
Also, is the connector that plugs into the trunk release, identical to the one that plugs into the fog light switch? |
02-24-2014, 11:30 AM | #66 |
Could anyone with this kit possibly try to find out the pinout for the switch connector? I really want to wire my lights through the stock wiring but I am not sure what wires do what on the switch.
03-29-2014, 11:06 PM | #67 |
Canadian FR-S Member
Drives: FR-S '10 Series'
I want to clarify the confusion for some people.
Part #PT413-18130 is the foglight kit that comes with a Bezel. You do not need a 10 Series VIN for this the foglights, but I do not know if you can get this bezel seperately. It is pictured below on the left-side (right-side is original FR-S bezel). You take the blank (second from left on bezel) and transfer it onto the new bezel with foglights. Part #PT413-18130-LL is for bezel-only for the 10 Series & Monogram. It is just the bezel and the only difference between this and the bezel that comes in the kit above is that it has a white print(icon) that shows headlight leveling. I have it pictured below. |
04-04-2014, 11:48 AM | #68 |
anyone know what type of connector they use on the pin from the light that goes into the turn signal socket? I've been looking but I cant find what kind it is.
08-02-2014, 08:25 AM | #69 |
Drives: Vortech Supercharged FR-S
Anyone know the bulb Size?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
08-14-2014, 02:08 PM | #70 |
Drives: 2017 86
the manual says psx24w, but mine have h11's in them for some reason. it also looks like the bulbs used in this diy were h11's as well.
i bought my car used in june with the oem fog light kit installed already, does anyone know what i need to do to get them to come on when just the parking lights are on? i've heard of splicing a signal wire to the side marker parking lights, but i don't know which one. a picture of which wire would really help. is it the wire that goes into the turn signal connector that gives them the signal?
The Following User Says Thank You to slim blanco For This Useful Post: | Figo (08-14-2014) |
Similar Threads | ||||
TOYOTA emblem... JDM vs USDM | lbroskee | Cosmetic Modification (Interior/Exterior/Lighting) | 89 | 08-15-2013 03:00 PM |
Has anyone install a light weight flywheel? | 20valvewynn83 | Engine, Exhaust, Transmission | 44 | 08-08-2013 09:52 PM |
Custom Third Brake Light Install (incl. Pics) | Skorov | AUSTRALIA | 14 | 07-27-2013 04:04 AM |
Glovebox LED light Install | Tech | DIY (Do-It-Yourself) Guides | 0 | 03-26-2013 07:21 AM |
OEM Fog Light install! ON and working! | 86design | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 38 | 07-04-2012 07:11 PM |
